      08-14-2018, 04:05 PM   #1
ArmyRn33
Drives: 16 X5 50i
50I Oil pan upgrade DIY
I am in the process of upgrading my trans pan to the M model which is aluminum. There are several threads on DIY on this and thought I add some info. I have found out the most latest on our pans they are the plastic versions, which mine is an 16 built in may. I sourced the pan online for 286/325 shipped 2 day, and there were none in the mainland having to have it shipped from Germany for a 2 week turnaround, The fluid Lifeguard 6 I found on Ebay 7 qts for 145 and that included shipping which was a steal as most shipping was 30$. In talking with the local BMW Service Supervisor, he has seen the plastic ones cracking, I need to verify if anyone knows the exact torque settings for the 13 aluminum torx screws?
DuSh2113.50
      08-14-2018, 04:28 PM   #2
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
I hope that's a typo because cannot use Lifeguard 6 in your ZF 8 speed transmission. Lifeguard 8 is needed for all ZF 8hp transmission
exact torque settings for 13 aluminum torx screws
Make sure its aluminum as steel has diffrent torque setting
*Aluminum 4nm + 45*angle turn (Replace aluminium screws; jointing torque and angle of rotation must be observed without fail.
*Steel 10nm
Torque Sheet
VERY RARE occurrences of pan cracking, only reason it cracks is if you ran over rocks or hard physical contact of oil sump. Also most service tech overtighten the hell out of the pans bolts resulting in the screw holes cracking, i've seen a few in my previous zf 6 and 8 speed transmissions.
Also here's a service instruction guide
      08-14-2018, 04:43 PM   #3
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
op, just wondering.. what is the advantage of going with the ///m oil pain besides protection.
      08-14-2018, 05:40 PM   #4
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
This is a well known mod folks did it back in 2016 when X5M became popular. It's not for protection, it's for improving heat exchange. Aluminum f85 oil pan has better heat dissipation (better fins and plus Aluminum itself dissipates heat better than let's say steel). That is why f85 got it to begin with. Just another extra safety mod to keep oil temps a bit lower.
The irony is that ZF8 transmission is not that bad with temps (but still a good mod to have especially if you often do stop-n-go traffic in summer heat or tend to drive aggressively, tow often etc.), plus we 50i guys have extra oil cooler for it. I'm more concern about TC (transfer case) that if anything will fail (specifically due to heat) long before ZF8 transmission will. Just my opinion.
It's same TC known for barely adequate oil supply for it's clutch and internals (due to poor engineering) - the result is that it starts to slip and then you get a shudder during acceleration etc. Timely TC oil change helps alleviate issues.
bmwx1sq145.00
      08-14-2018, 06:05 PM   #5
daytonaviolet
OEM CSL Whore
Philippines
1250
good info here. i'll have to give this a try
DuSh2113.50
      08-14-2018, 07:04 PM   #6
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I love the DIY ya 50i guys are putting together. Let's keep it going. I'm gonna change my oil this weekend and add a DIY since I couldn't find one for the 50i on this forum. Found a couple through google and YouTube but we should at least have one in our thread. We need a TC oil change and a Rear Diff oil change!! Who's up?! Haha
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
bmwx1sq145.00
DuSh2113.50
      08-14-2018, 07:21 PM   #7
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Let me do some research and when I get back from vacation I will be changing the fluids. I ll try to do the TC.
DuSh2113.50
Maverik2594140.00
      02-18-2019, 12:19 AM   #8
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
I know it's old thread, but here's a pdf file I found about our ZF transmission - could be helpful to those changing oil
      02-18-2019, 02:56 AM   #9
alphaod
alphaod's Avatar
I’d like to point out out I was hella confused about this thread title. I was thinking isn’t the oil pan already metal…?
      02-18-2019, 08:34 PM   #10
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Isn't the thread just "50i oil pan upgrade - DIY"? Nothing mentioning it's not metal. Just that an upgrade is available. Or is it different now?
'06 C55 AMG (sold)
      03-24-2019, 03:17 PM   #11
mp25
Drives: 14 x5
Anyone know if the plastic transmission pan is reusable or do you have to replace the whole thing after a drain and fill. Was planning on doing it twice to clean out more of the old fluid. The pics online look like the drain bolt is plastic.
      03-24-2019, 06:36 PM   #12
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
What plastic pan? The 50i is steel and M aluminum.
'06 C55 AMG (sold)
      03-24-2019, 06:37 PM   #13
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
You ever do this. Would love some insight on TC oil change. About to hit 50k miles this summer.
'06 C55 AMG (sold)
      03-24-2019, 11:14 PM   #14
alphaod
alphaod's Avatar
The transmission fluid filter is built into the pan so you should replace it when you change the fluid.
2015 BMW X5 xDrive50i
BMW CCA 509766
      03-25-2019, 01:54 AM   #15
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
I haven't got around to it yet. I will look into it this week, when I change my oil. It doesn't look hard at all from what I remember. I ll keep you posted.
      03-25-2019, 01:54 PM   #16
pits200
While I love upgrades, this one seems very unnecessary. If you plan on tracking your x5 then sure but otherwise....
      03-25-2019, 06:52 PM   #17
mp25
Drives: 14 x5
This says plastic :
https://www.pelicanparts.com/catalog..._pg2.htm#item4
      03-27-2019, 03:25 PM   #18
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
This says plastic :
Sorry don't see what you're referring to. Can you take a screen shot? Maybe it's an aftermarket piece you're talking about but the pan for the 50i is steel. Just get under the car and look.
'06 C55 AMG (sold)
      03-28-2019, 10:21 AM   #19
alphaod
alphaod's Avatar
I thought the thread title was referring to the engine oil pan but the thread is about the transmission fluid pan hence the confusion.
The engine oil pan is steel but the transmission fluid pan on the 50i ZF transmission is all plastic, has the fluid filter built into the pan, and should be replaced every time the fluids are changed.
Hence the topic of this thread about upgrading the plastic pan to the metal one from the M.
BMW CCA 509766
      03-28-2019, 12:58 PM   #20
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ah I see the newer F15s are plastic. Didn't catch that blurb.
'06 C55 AMG (sold)
      11-18-2019, 05:13 PM   #21
supermoc
Drives: BMW X5 M50d
Is there any magnet in the aluminum pan, I don't see in the photo. the plastic comes with magnet built in the pan.
      10-25-2022, 09:23 AM   #22
zero2sixtyZ
Drives: e92 + f15
Part #: 24119503407?
https://www.fcpeuro.com/products/bmw...503407#fitment
