08-03-2018, 06:07 PM | #1 |
Rep 137
Rear brakes at 27K miles... really??
I took my 2016 X5 in for service with 25K miles on it. At 26K miles I started getting warning message to have my rear brakes checked at 27K miles. Now at 27.4K miles I have a warning that my rear brake pads need changing. If the rear brakes need changing every 27K miles, I wish the dealer would have checked them at the 25K service, especially since it is a 3 hr drive to go to the nearest dealer. Does the X5 really go thru rear brake pads every 27K miles??? My VW has 298K miles on it and I have only needed change the rear pads once. Most cars I have had the front pads wear out LONG before the rear pads do.
08-03-2018, 06:36 PM | #3 |
Rep 137
I am a one footed driver, been accused of driving like a little old lady. I don't drive it like it is a sports car, I have other cars for that. Looking at the pads... they look fine which is why I am not rushing off to the dealer. I was just surprised that I was getting warnings at 27K miles to check the pads.
08-03-2018, 06:46 PM | #4 |
Rep 845
Maybe a bad sensor?
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
08-03-2018, 07:23 PM | #5 |
Rep 196
When I bought my 15' x5 35d in January it had 23,000km not miles On it And the rear brakes and been replaced already by BMW before I picked it up.
A friend of mine who worked at bmw told me; when the auto sensing wipers are on, the rear brakes drag slightly to keep the rotors dry. Whether this is only when it is raining or not. I'm not sure, nor do I have any hard evidence to back this up. But if it is. It could be part of the reason for the early brake replacements.
2015 X5 35d M sport
2017 340i M sport 1991 M5 1988 M5 |
Russmov1328.00 |
08-03-2018, 08:02 PM | #6 | |
Rep 1,343
08-03-2018, 08:51 PM | #7 | |
Rep 1,092
08-03-2018, 10:18 PM | #10 |
Rep 7,162
I'm at 33k with no warnings in sight. And I use a lot of brakes accompanied with a lot of gas.
Russmov1328.00 Gtz1wickedest646.50 |
08-03-2018, 10:46 PM | #12 |
Rep 7,162
What would be considered low?
08-04-2018, 04:11 AM | #13 | |
Rep 2,719
08-04-2018, 04:15 AM | #14 |
Rep 826
Drives: 2017 C43 AMG
5mm and below means it's time to replace them.
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
08-04-2018, 05:58 AM | #15 |
Rep 5,066
Idrive indicators are estimates, you have to physically check the brakes to see if the pads need changing. My Idrive mentioned 3100 miles until rear brakes needed changing for the last 6,000 miles. The 3100 miles indicator appears to be the lowest it goes and a recent visit to the dealer resulted in resetting the rear brake pad wear indicator at 6,000 miles.
Also I've read that bmw is using pads that causes little brake dust at a cost of faster wear. My 2013 E70 X5 had brake dust build up after just a few miles and in my F15 it's hardly noticeable.
eeyuu24.50 |
08-04-2018, 07:31 AM | #16 |
Rep 239
Maverik2594144.50 |
08-04-2018, 07:38 AM | #17 |
Rep 1,270
08-04-2018, 12:57 PM | #18 |
Rep 2,719
Ah ok, well then... they measured mine manually and then entered new values in idrive (or whatever), added 20k (km) on my old F15 (2014)
08-04-2018, 01:21 PM | #19 |
Rep 2,388
Those "sensors" are just 2 wires that will short the circuit as soon as pads wear down enough (<3.7mm) https://www.newtis.info/tisv2/a/en/f...ion/1VnXcAI1To
They are not intelligent eye sensing x-ray technology that can see or scan and know your pads life. BMW (as many others) uses simple algorithm to predict pads life, but (like many others) it greatly underestimates pads life to stay on VERY conservative side to avoid risky situations and hence lawsuits etc. Usually techs just reset pads life counter during next visit. That's all there is. Visual check (and manual pad thickness measurement with calipers if you anal about it) is always #1 method. If pads are good - just forget about silly maintenance reminders. Why the techs at BMW didn't think about resetting this when you were there last time? Well, human factor as always and welcome to real life. I have yet to see a single dealership that does everything by the book (including other brands). I don't think they exist. You can even reset them yourself if they annoy you: |
08-04-2018, 02:03 PM | #20 |
Rep 1,270
The sensors will short circuit only at the last stage. As they wear down, the internal electrical resistance modifies, so there is an indication even before the last warning.
Resetting will not help, the warning will soon pop up again. It's a common issue when people replace the brake pads without replacing the sensors. |
DuSh2113.50 |
10-05-2018, 06:11 PM | #21 |
Rep 137
Following up on my post, I finally got my X5 into the dealer. They said the rear inside pads were worn out and the rotors were damaged on the inside and needed to be replaced as well. The outside pads were fine as were the front pads/rotors. I was surprised that pads and rotors were worn out at 27K miles, the mechanic gave two reasons for the early pad failure.
- Pads in these vehicles are softer to prevent squealing. - Rotor material is more porous than they used to be, absorb more water and rust more. My X5 sometimes sits for 2-3 weeks at a time as it is not my daily driver. The mechanic believes that morning condensate gets on the rotors, on both sides. Then the outside of the rotors gets more air flow, dry out faster and rust less. He said he has seen rotors that have appeared "to rust out from the inside" and he blames the very porous material the rotors are made of. Rear pad/rotor and brake fluid change would have cost me $1350 if the car was not under warranty. |
10-05-2018, 06:36 PM | #22 | |
Rep 7,162
