06-27-2019, 10:34 AM | #23 | |
Master of one
430
Rep 486
06-28-2019, 10:52 AM | #24 | |
M Performance Class ;)
51
Rep 204
Cold tire pressure. Front 36 PSI Rear 44 PSI Want to make sure plenty of air is in there to also protect Rim from any damage. |
06-28-2019, 02:43 PM | #25 | ||
Master of one
430
Rep 486
06-28-2019, 04:03 PM | #26 |
Rep 991
I have them too in the factory 20" staggared sizes. Nice tire. Not the ultimate grip of a high end summer tire, but good enough for some spirited driving. I like the continental dws06 i had also. Thought I'd give something else a try. Plus they were only $900 mounted/balanced.
06-28-2019, 05:52 PM | #27 | |
51
Rep 204
Thank you for contacting Toyo Tires USA. Based on your vehicles load requirement your front 295/30R22 103W XL tires we recommend 37 PSI cold. However, your rear 335/25R22 105W XL tires do not meet your vehicles load requirement. At max pressure of 42 PSI you are still over-loaded by 33 lbs. per rear tire and it is not recommended to run tires under-inflated. Sincerely, Consumer Relations Toyo Tire U.S.A. Corp |
06-28-2019, 06:09 PM | #28 | |
Rep 264
2015 F15 XDrive 50i MSport
07-01-2019, 09:09 PM | #30 |
Rep 991
07-02-2019, 12:46 AM | #31 |
Rep 264
You sure you have/had the Toyo ST III's which are Performance/Street All Seasons? I was hoping the Toyo's have a stiffer sidewall just not RF stiff, lol.
