      06-27-2019, 10:34 AM   #23
diesel733
Master of one
diesel733's Avatar
Drives: 2018 BMW M3 ZCP IMOLA RED
Originally Posted by PanthersFX View Post
Got my wheels and tires on. You guys are right about the Toyo's being great tires.
I am looking for recommendation for optimum tire pressure for following aftermarket wheel setup. Looking for best pressure for front and back for both ride, performance and tire longevity.
Running staggered setup.
Tires: Toyo Proxes ST III
Wheels: Forgestar F14 22 Inch Custom Wheels
Front: 22x10.5 with 295/30/22 tires
Rear: 22x12 with 335/25/22 tires
Thanks in advance.
I run the recommended tire pressure settings on the side of the door on my Proxes STIII. It rides good.
      06-28-2019, 10:52 AM   #24
PanthersFX
M Performance Class ;)
Drives: 2015 BMX X5 50i M sport
Really? My side panel shows details for the 19's that it came with shows
Cold tire pressure.
Front 36 PSI
Rear 44 PSI
Want to make sure plenty of air is in there to also protect Rim from any damage.
      06-28-2019, 02:43 PM   #25
diesel733
Master of one
diesel733's Avatar
Cold tire pressure.
Front 36 PSI
Rear 44 PSI
I think that's what pressure I run and had no issues with Los Angeles roads.
      06-28-2019, 04:03 PM   #26
crackerjack15
crackerjack15's Avatar
836
Drives: 2024 X5 50e
I have them too in the factory 20" staggared sizes. Nice tire. Not the ultimate grip of a high end summer tire, but good enough for some spirited driving. I like the continental dws06 i had also. Thought I'd give something else a try. Plus they were only $900 mounted/balanced.
      06-28-2019, 05:52 PM   #27
PanthersFX
I reached out to Toyo regarding recommended pressure and got some strange message about load index. I did the calculations and got well over the weight of the car. Here is what they said not sure what they are talking about since this was recommended setup from 2 tire shops and multiple people running this setup.
Thank you for contacting Toyo Tires USA. Based on your vehicles load requirement your front 295/30R22 103W XL tires we recommend 37 PSI cold. However, your rear 335/25R22 105W XL tires do not meet your vehicles load requirement. At max pressure of 42 PSI you are still over-loaded by 33 lbs. per rear tire and it is not recommended to run tires under-inflated.
Sincerely,
Consumer Relations
Toyo Tire U.S.A. Corp
      06-28-2019, 06:09 PM   #28
MizikeTSK
Drives: 2015 XDrive 50i MSport
Which of the two do you like better (Toyo or DWS)?
2015 F15 XDrive 50i MSport
      06-29-2019, 03:39 PM   #29
Keithwand
104
Drives: 22 X5 replaced 16 X5 6/22
Those are the 2 brands I am considering too. Interested to see more comments.
      07-01-2019, 09:09 PM   #30
crackerjack15
836
Drives: 2024 X5 50e
It's close, and two different tires. One being summer tire the other all season. I would say ultimately dws06 is better overall tire.
      07-02-2019, 12:46 AM   #31
MizikeTSK
You sure you have/had the Toyo ST III's which are Performance/Street All Seasons? I was hoping the Toyo's have a stiffer sidewall just not RF stiff, lol.
      07-02-2019, 07:13 PM   #32
Keithwand
104
Got d to know. I want all season.
      01-21-2021, 07:23 PM   #33
Carpe_BM
Drives: EX-BMW (2019 BMW X5 xDrive40i)
Just got my Toyo Proxes ST3's (275/40R20 & 315/35R20) delivered...excited to get rid of the RFTs!
Search this Thread:
Advanced Search
