01-24-2019, 01:12 PM | #1 |
Rep 128
Drives: 2021 540i xDrive
iDrive/Nav rebooting mid-drive...not sure what to do at this point
I've been running into an issue the past couple of months in my 2015 X5 35i - I will be driving along, and all of a sudden the iDrive system will reboot. Radio stops, nav shuts down, and the whole system reboots like you're starting the car up initially. This happens mid-ride and random times, sometimes within 5 minutes, sometimes 30 minutes into a drive, and it will happen a random amount of times in a row. Sometimes once, othertimes up to 5 times.
One of these instances the car actually reset all of my settings, saved radio stations, NAV locations, etc. Full wipe to factory stock. I've now been to my dealer 3 times trying to solve this issue. First try was to reload the iDrive software, which didn't solve it. 2nd shot was to remove my cell phone paring and remove my USB memory stick I have in the console with my music collection and see if it happened again. It did. 3rd time back, we replaced the head unit, and not 4 hours after picking up my car it happened again. I will say I'm using a Galaxy Note 9, which appears to be on the BMW approved list, as this was an initial question regarding the issue. This concern was negated though when the system reboot without it connected. Same with the USB stick. Any one have any thoughts where to go from here? It's so hard to pinpoint the issue and I'm curious if anyone has had this happen to them. |
01-24-2019, 02:13 PM | #2 |
OEM CSL Whore
1250
Rep 1,476
The fact that it's loosing memory radio stations,
Navigation locations .. I believe the unit is loosing power completely. The supply power to the brain is getting turned off. |
01-24-2019, 04:02 PM | #3 |
Rep 36
Drives: 2015 BMW X5 35D
I had the exact same issue with my 2015 F15 35D. It took a while but after recording the event happening a number of times and working with my SA, BMW eventually replaced my head unit. I would highly advise you to document it if possible and show your SA when you go in for service.
Note BMW is going to try to point to the fact that your phone may not be Running the correct version of firmware that is compatible with I drive. I actually downgraded my phone to the compatible version and still had the same problem. I do not believe it is your phone at all. Mine was happening under Bluetooth connectivity, USB connectivity, and not even having my phone connected at all. |
01-24-2019, 04:25 PM | #4 | |
241
Rep 307
It's definitely a hardware issue, probably the car communication computer (CCC). Is this what you mean by head unit? |
01-24-2019, 10:15 PM | #5 |
Rep 102
I had the same issue back in December 2017 on 2014 35i, and SA was driving the car with me for front clicking noise and idrive rebooted and that was enough for them.. they ended up replacing the head unit after testing and 2 hours had to order another unit bc replaced unit rebooted as well. Since Jan 1st 2018 no issues.
It has absolutely nothing to do with iPhone x or Galaxy note 8/9.. I had both setup. If under warranty take it back to them and ask them to diagnose it. Mine got to the point that it would just reboot since before it was sporadic. |
01-25-2019, 11:37 AM | #6 |
Rep 7,160
Been having this intermittent but since you have a new one then maybe you got a bad unit
01-25-2019, 02:04 PM | #7 |
Rep 842
my 18' would reboot randomly. didn't lose settings though
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
01-18-2021, 08:33 AM | #8 |
Rep 1
Following up on this thread
My '16 X5 has been doing the exact same thing, and they replaced the head unit. Since it was ONE month out of warranty, BMW NA agreed to split the cost of the new head unit, so I ended up paying about $1100 out of pocket. Fast forward about a week, and it's doing the exact same thing again with the new head unit. It's in the realm of possibility that it's another bad head unit, but more than likely I wasted $1100 on a part that didn't need to be replaced and now they have to find the real culprit.
So for anyone who had the head unit replaced, and if the problem persisted... was there any resolution from BMW? |
01-21-2021, 02:33 PM | #9 | |
Rep 942
Drives: 2016 BMW X5
01-21-2021, 02:37 PM | #10 |
Rep 1,180
Keep us updated. Still contemplating on different extended warranties and think it will be worth double checking this is a covered repair as part of the policy.
2018 X5 35i M-Sport
01-21-2021, 03:07 PM | #11 | |
Rep 942
Drives: 2016 BMW X5
01-21-2021, 04:08 PM | #12 | |
Rep 21
Anyway, after some googling and digging of old posts. I saw a few people mention the dealer advised them it's because of their phone's BT connection. I thought well that is silly, I've had the same phone throughout the ownership of my truck. However the next time it rebooted so many times to completely wipe all the settings (including BT pairing) I didn't re-pair my phone. No more bootloops! The only thing that changed was OS updates (going from Android 10 to 11 not too long ago plus many updates since it's a Google Pixel). I left the phone unpaired for about 1 month and the idrive was rock solid. After I got another update to my phone I decided I would once again attempt to pair via BT - however what I also though about was that it might be the SMS and phonebook sync that might be the actual issue. So this time when pairing I denied idrive the access to download messages and contacts. I don't' need that anyways thanks to the MMI AA module which I use. And well, I've yet to experience another reboot. Maybe this helps you as well. |
jmack1231300.50 |
01-21-2021, 04:35 PM | #13 | ||
Rep 942
Drives: 2016 BMW X5
01-25-2021, 06:54 PM | #15 |
231
Rep 369
It just happened to me recently on my 2018 X5, I have appointment next Monday to diagnose that at the dealer
Current
08-05-2021, 10:52 PM | #16 |
Rep 178
I think I remember there being an issue with the i drive controller (big circle thing with map phone media back option buttons)
05-01-2022, 04:49 PM | #17 |
Rep 2
I have been trying to find a way to reboot the I drive system on our 2014 X5.
Over the last several months, the USB connections n has become intermittent. Tried different iPhones and cables. Those aren’t the problem. Also, the Bluetooth connection became intermittent but now won’t say its connected for entertainment / music even though it shows iPhones connected for music in connections. Holding power button doesn’t work... none of the ‘combos’ seem to work. I’m pretty darn afraid of the multi battery complexity.... Just want to try rebooting before I bring it in for big $$$$$ Any help appreciated |
