01-23-2021, 12:15 PM | #1 |
Rep 5,201
time for new battery?
My F15 x5 has shown random error on cold starts such as chassis management and adblue error on days when temp has been < 0 degrees Celsius and this clears up when I stop and restart the car
I scanned with bimmerlink no permanent errors shows. and 105 AGM Battery charge is 48% this seems constant each time I checked it with bimmerlink. Also 5 years and 60k miles since last battery was changed. Should I a. Replace Battery b. Try trickle charger c. do nothing and wait for winter to pass If a. Go OEM or try bosch/exide |
01-23-2021, 01:47 PM | #2 |
Rep 2,511
Depends on how often your drive, but after 5 years in cold conditions it might be a good time to get a new battery so you are not stranded one day. OEM vs aftermarket part in my opinion is whatever is cheaper, as far as specs are the same.
KRS_SN13510.50 |
01-23-2021, 02:57 PM | #3 |
147
Rep 334
Id hook it up to a good battery charger and let it run its conditioning program and see what happens from there. AGM's are finicky and like alot of voltage to be happy.
Worth a shot and by far the cheaper option before replacing batteries. If it does not work, and you still have the replace them (one or both) then you'll have a tender to keep up the charging on your batteries going foward. |
KRS_SN13510.50 |
01-24-2021, 02:25 PM | #4 |
Rep 1,222
If you use a lot of the electronics/accessories, after 5 years/60K it might very well be time to change. Sure, you could probably squeeze out a bit more use, but a new battery is inevitable, and preventative maintenance now might save you headache down the road.
KRS_SN13510.50 |
01-24-2021, 09:39 PM | #5 |
Rep 979
I am a big believer in tickle chargers , my m3 still has its original 2010 battery in it and it is 95% still ...
mrfochon211.00 |
02-14-2021, 04:25 PM | #6 |
Rep 5,201
ok so it was -7 c. The car said go for a long drive or connect external leads. I took her out for a 30 minute spin. warning went away but I thought I can't be bothered with the faff of no start/ slow charging etc so called bmw they quoted £500 fit of battery and would need to take the car and leave it at the dealership for 24 hours.
Tried RAC. Got a varta 105 agm battery for £290 suppy fit n coded and registered at home in 24hours. Mrs says the turbo lag is gone and car runs faster and smoother too: |
