01-25-2021, 04:27 PM | #1 |
Rep 3
2015 F16 804372 Code
Hi,
I got this code Water Valve, Passenger side: short circuit to ground 804372 Does anybody had like this code before? Where is that located? so can check the ground wire(maybe could fix the problem) and you can see(Pic attached) I have another code for the Valvetronic,I guess I need to replace it Thank you! |
01-25-2021, 07:35 PM | #2 |
147
Rep 334
No trouble shooting measures in ISTA+?
Is "water valve" referencing your heater core or water pump / thermostat? Are you overheating? Does you HVAC system work fine? |
01-26-2021, 09:28 PM | #5 |
Rep 3
I just find out when I turn on the AC, I get cold air from the driver side but not from the passenger side( Sync is on ) and the cold(driver side ) vent blow less air than the hot vent(passenger).
