08-19-2022, 08:54 AM | #1 |
Rep 271
Defoulers for catless downpipes
Hello, I have to install catless downpipes on my F86 and can someone please give me a link for defoulers that will work with emissions? I live in NY and we have to pass emissions to get NYS inspection.
thank you! |
08-19-2022, 08:45 PM | #3 |
Rep 1,029
If the tester is not a complete gumby, he will be able to smell that you are catless.
Also you know that those thing are not a permanent fix. They still will trigger a CEL warning within like 30mil |
08-20-2022, 06:49 AM | #4 |
176
Rep 308
08-20-2022, 08:29 AM | #5 |
Rep 215
I am the resident catless expert for NY. Get the BM3 or Velos tune. You can fail one readiness and still pass. The tune will suppress the CEL, you'll fail one readiness and still pass emissions.
08-21-2022, 12:05 AM | #6 |
Rep 1,029
Ok expert, I'll bite. How do you pass an emissions test without a cat? Do they like use telepathy or measure the gas output from a different postcode?
08-21-2022, 12:39 AM | #7 |
Rep 271
I can turn off CEL using MHD tune, I just want defoulers so monitors will be ready to pass emissions
08-21-2022, 01:11 AM | #8 |
Rep 220
Hes talking about passing emissions via OBD hookup to the inspection machine, the machine will pass you. If your inspector knows that there is indeed no cat that would be a different story.
08-21-2022, 09:11 PM | #9 | |
Rep 215
On-Board Diagnostic Tests: Licensed New York emissions testing facilities will administer an ODBII test on most motor vehicles made in the 1996 model year or later. The OBDII system installed in U.S. manufactured vehicles made in the 1996 and newer model years is a mechanical issue early-warning system. The system records the vehicle’s performance by administering a specific kind of test referred to as a “Monitor”. Certain monitors test a vehicle’s primary emissions components and subsystems. While the key is in the ignition and the engine is off, a test technician will make sure the vehicle’s DLC (Data Link Connector) works properly. Then, the test technician hooks an emissions diagnostic tool up to your vehicle’s DLC using a cable to allow the technician’s diagnostic tool to communicate with the vehicle’s OBD II system. New York test personnel can check your vehicle’s engine and emissions systems, and see if any monitors state a “Not Ready” status. The test personnel can complete the test in around 2 minutes. |
08-21-2022, 09:28 PM | #11 |
Rep 215
The inspector won't care. I had a complete ahole do my last inspection. Took the tire gauge out to measure my tread on new tires lol. He was ball breaking like a clown the whole time and still passed me. Most other places have the kid in the shop hook up the OBD and do the tests, they are almost always on auto pilot.
08-22-2022, 01:22 AM | #12 | ||
Rep 1,029
Sorry I'm not an expert on American/NY. I am used to Regulations been useful/functional and not a circle jerk waist of time. ie. Emissions tests, that actually test said emissions. Question is the examiner in a cost optimized offshore region? Seems like a waist having them local if all they do is plug in an OBD cable and hit scan. Quote:
Calling yourself an expert is painting a bullseye on your back and inviting everyone to take a shot. Last edited by Chilled; 08-22-2022 at 03:06 AM.. |
08-22-2022, 09:33 AM | #13 | |
Rep 215
08-22-2022, 05:49 PM | #14 | |
Rep 1,029
I work in IT and usually the minute someone introduces themselves as an expert. That is an instant massive gumby flag, yet to meet 1 person who isn't. So the no testing for actual gas levels, is that a US thing or just NYC? But to OP's point, if all he needs to do is pass via OBD. Wouldn't all he would need to do is, reset the CEL/o2 error in the carpark. Before he hands the car over for inspection? Shouldn't the stock o2 last the inspection period without tripping the error? Last edited by Chilled; 08-22-2022 at 05:55 PM.. |
9vapors651.50 |
08-22-2022, 08:13 PM | #15 | |
Rep 220
9vapors651.50 |
08-23-2022, 01:14 PM | #18 |
Rep 220
08-23-2022, 03:02 PM | #19 |
Rep 2,342
That makes sense and You may be right. Still solved my problem though!
RomeoXantos12.00 |
08-24-2022, 05:41 AM | #20 | |
Rep 1,029
Is this the same for ISTA and a scan tool or it does not matter? |
RomeoXantos12.00 |
08-24-2022, 05:53 AM | #21 |
83
Rep 323
When it comes to the US emissions readiness check i do not know of any way to clear them and have them automatically set for ready. Some of the parameters set quickly and some take longer (i.e. evap montor)
08-25-2022, 08:39 AM | #22 |
Rep 271
My mechanic said he will pass inspection as long as there is no CEL. And I can turn it off using MHD tune. He also said defoulers are hit and miss with emissions. I am all set. Thanks a lot guys
