09-06-2021, 08:24 AM | #1 |
Rep 1,233
Recommended Tire Pressure?
I like to pump up my tires a little bit to protect my wheels from poor roads and such. But want to avoid going too high.
What are you all running for cold tire pressures on the street for spirited driving? Last edited by Blue By You; 09-06-2021 at 08:48 AM.. |
09-06-2021, 11:20 AM | #2 |
Rep 592
If MPSS's -21" and you are concerned about even wear across tread…assuming you've had a four wheel alignment, 39# front & 40-41# rear cold , with accurate gage. On my second set, ran first ones at 36# & had outer edge heavier wear at all four corners
Blue By You631.00 |
09-06-2021, 05:10 PM | #3 |
Rep 1,233
Thank you
That's where I was at and pumped them up to 40F/42R but I'll back them off a bit. Thanks
09-06-2021, 05:13 PM | #4 |
Rep 592
Check tread wear every 1000 miles with accurate tread depth gage …up or down pressure based on reading across all four or five ( on third Chardonnay so hard to remember) grooves
Blue By You631.00 |
09-06-2021, 06:56 PM | #6 |
Rep 592
Your car your decision
09-07-2021, 08:39 AM | #7 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
The lower you go the larger the contact patch and more grip. Higher you go the smaller contact patch less grip but better mileage. Extreme ends too low or high will cause uneven wear.
There is an optimal point for everyone. I like to stay on the low end in the mid 30's. This is a performance suv so i like to get max cornering grip. I'd prefer less grip using launch control as it bogs pretty badly even when tuned so I think higher pressure might be better to get it to spin just a tad but I haven't done any testing yet. Tire pressure is a really big deal. On my performance cars I stay really low as I only care about grip. Low 20's in my modded 991 Turbo S and idc that the tpms light stays on. 0-60mph in 2 flat on the street. At the factory tire pressure there is zero grip using launch control just spins wildly. That's quite a difference with just tire pressure.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
Klienfeld303287.00 cr8tive0.00 |
09-07-2021, 09:52 AM | #8 | |
Rep 1,233
Solid feedback
09-07-2021, 10:18 AM | #9 | ||
Rep 6,771
Drives: 2016 BMW i8
The lower the tire pressure the more comfortable the ride too. My X5M is in south orange county California where the roads are the best I've ever seen. So I can get away with really low pressure since the roads are great and very little risk of bending wheels. I have a home in another country in a hot/rainy environment and the roads are insane HUGE potholes all over and I have to run higher pressure on my SUV there just so the wheels wont bend. Performance has another meeting down there.
Blue By You631.00 |
09-08-2021, 11:09 AM | #10 |
Rep 1,035
But running too low of a pressure will lead to excessive tire wear on the outer edges.
09-08-2021, 12:31 PM | #11 |
Rep 6,771
Drives: 2016 BMW i8
Agreed but for those wanting max performance it's a worthy trade-off.
09-08-2021, 03:38 PM | #12 |
Rep 592
Longboarder…call TireRack and run your "underinflation gives better contact patch" theory by them. Last I knew it was true in sand and snow.
09-08-2021, 05:43 PM | #13 |
Rep 1,035
This is what we did in the military for mud, sand and snow. I do understand your theory, as they been using this method in drag racing, but there vehicles don't weigh 5000+ lbs.
09-08-2021, 06:36 PM | #14 |
Rep 592
Drag guys run treadless tires…slicks & they ARE aired to give a flat contact patch… under inflation gives a convex tread patch. You want all the rubber, treadless or not in contact with road or track.. hence the term " contact patch"
You are correct for mud/ snow/ sand though if you judiously apply power |
09-09-2021, 11:31 PM | #16 |
Rep 6,771
Drives: 2016 BMW i8
Under-inflating my Cup2's dramatically helps lap times in my GT3. Start pressure 25 front and 24 rear come in and bleed down after a few laps to maintain high 20's. Also on my 991 Turbo S low 20's in the rear gets the car to hook up on launch control 0-60mph in low 2's every time. At the manufacturer setting the tires spin wildly. So yeah, lower pressure = larger contact patch = better performance.
09-10-2021, 05:57 AM | #17 | |
Rep 417
ACID.
Longboarder3437.00 |
09-14-2021, 07:37 AM | #18 |
Rep 592
Not wanting to be an IMHO provider, attached are a series of tech pieces from TireRack on inflation..all of us need to be aware of, sorry there are / may be out of order, no page numbers, but we're all pretty smart and able to figure out where one page ends and which is the next page
09-14-2021, 11:24 AM | #19 |
Rep 592
Should be "Required" reading!
10-04-2021, 10:18 PM | #20 |
172
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Good stuff here!
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
10-05-2021, 01:18 AM | #21 |
Rep 271
Just as another data point, I'm with 640ijims and run 40/39 f/r. I hadn't checked for a while and the weather has cooled, so the starting cold pressures were somewhere around 36. Worked on a lot of cars the other week and added air to get back to my usual and the difference when cruising on the highway was very noticeable. At 40 - 41, cruising at 80 - 85 mph feels effortless, whereas just a few psi less and it feels like the car wants too slow down.
10-05-2021, 06:19 AM | #22 |
Rep 592
I excerpted TireRack articles for the post. While a long grueling read on about 7 articles, they are the treatis on inflation. Those that advocate under-inflation or over inflation , except for severe environmental activities, should read them for safety.
