      09-30-2018, 11:46 AM   #1
UT_X5
UT_X5's Avatar
44
Drives: X5 50i
X5 50i spark plug and coils
Shout out to Maverik259, Doberman16, and DuSH for sharing spark resolutions for tuned 50i.
After running with JB4 and Dinan, I switched to BM3 Stage 1. Damn it's amazing. BUT car starting hesitating/shudder during WOT. As I read, the issue only gets worse and it did. Eventually lead to drive train malfunction and the car became a violent, rolling shaker bottle.
Locked the DME and took it to the dealership to have X5M (gapped 0.023in) plugs, new coils, and X5M air filters installed.
Results are that it did the trick! Car runs smooth and pulls amazing. Dyno scheduled for next week before DPs.
      09-30-2018, 05:23 PM   #2
Live4USMC
Live4USMC's Avatar
Drives: 2014 X5 50i M Sport/2016 340XI
Are the x5m coils different than n63tu coils? How much per coil?
      09-30-2018, 06:14 PM   #3
UT_X5
UT_X5's Avatar
44
Drives: X5 50i
I just ran with N63TU coils. I got an employee discount for coils $20 a coil.
      09-30-2018, 10:07 PM   #4
perry8912
Drives: bmw x5
Is that stage 1 91 tune or 93? I’m currently running 91, but not sure if it worth it to do 93....
      10-01-2018, 08:39 PM   #5
UT_X5
UT_X5's Avatar
44
Drives: X5 50i
Currently running Stage 1 93. My butt dyno thinks it worth it hah
      03-02-2019, 10:27 AM   #6
sbkim
Drives: 2021 X7 M50i
Sorry for dumb question but I am taking the car in for plug change at the dealership. My 50i has almost 60K miles. Also experienced drivetrain malfunction but cleared up. Intermittently feels lacking power during highway speeds.
Should I tell them to change the coils as well since they are already incurring the labor with spark plugs and technically it should just be additional parts only?
      03-02-2019, 10:32 AM   #7
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
I would ask them to change the coils at the same time since they have to take the coils out to replace spark plugs. Of course double check with the SA to make sure they don't "double dip" the labor time.
2019 Cayenne Turbo
Gone but not forgotten:
      03-02-2019, 10:44 AM   #8
sbkim
Thank you! I didn't want to unnecessarily replace but seems like a good idea to change out completely with plugs, at 60K miles.
      03-02-2019, 04:14 PM   #9
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Personally I think it’s unnecessary. Those coils should last you until your next plug change.
      03-02-2019, 06:46 PM   #10
sbkim
My current issue with my 50i is when I try to accelerate while going past 70mph (for instance to pass someone), the car shuddering intermittently, almost as if I am going over bumpy road. I used my OBD scanner and there are no error codes, at least not yet. I presume its the plugs. I was going to try different gas (typically use 93 Costco) and or use Techron complete cleaner?
      03-04-2019, 10:13 PM   #11
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Plugs
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      03-05-2019, 06:30 AM   #12
mikew2069
mikew2069's Avatar
413
Plugs
^^^This
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      03-06-2019, 06:18 AM   #13
BobBeau
BobBeau's Avatar
Drives: X5 50i
Plugs
Originally Posted by mikew2069 View Post
^^^This
Not necessarily guys. I had the same problem and changed the plugs with no success. It wasn't until I changed the coils that the problem went away. Just my experience.
      03-06-2019, 11:57 AM   #14
mikew2069
mikew2069's Avatar
413
Originally Posted by BobBeau View Post
Not necessarily guys. I had the same problem and changed the plugs with no success. It wasn't until I changes the coils that the problem went away. Just my experience.
You're right, anything is possible so you never know. I'd at least just start with the plugs and go from there.
BM3/H&R/Borla
      03-06-2019, 01:11 PM   #15
sbkim
Thanks everyone. Going in for plugs tomorrow. I will keep you guys posted.
      03-06-2019, 05:11 PM   #16
alphaod
alphaod's Avatar
Just new plugs gapped to 0.23" fixed my 4th gear plus WOT stutter problems...
2015 BMW X5 xDrive50i
BMW CCA 509766
      03-08-2019, 04:16 PM   #17
sbkim
Quick update. Spark plugs were changed and car runs like new! SA said that coils still looked OK and not recommended changing. Thanks everyone!
      03-08-2019, 05:01 PM   #18
trlengle
Drives: 2016 X5 50i MSport White
Are X5M plugs the best upgrade option? I recall a mention of NGK but can't find the model and what the thought was on performance.
2016 X5 50i MSport in White
Dinan Powered
AC Schnitzer Springs
22" Varro VD01 Wheels
iND Black Emblems and Badge
      03-30-2019, 06:39 PM   #19
UT_X5
UT_X5's Avatar
44
Drives: X5 50i
Currently running X5M plugs on Stage 2 with no issues. Don’t know about NGK
      03-30-2019, 07:31 PM   #20
alphaod
alphaod's Avatar
I went with NGK 97506 Laser Iridium
BMW CCA 509766
      03-31-2019, 10:19 AM   #21
trlengle
Thanks. I went on ecstuning website and it tells me these are not a fit. Is that just because they are not a normal swap for the X5 but they do fit/work? Did you get NGK over the BMW X5M because they perform better or...
Dinan Powered
      03-31-2019, 10:20 AM   #22
trlengle
Blank
Dinan Powered
Search this Thread:
Advanced Search
