      07-05-2018, 10:59 AM   #1
Twin Peaks
N00B
Twin Peaks's Avatar
Drives: X5 50i (F15)
N63T Broken Hose!
Hi all!
I heard a whistling sound this morning when I started the X5 up and checked the ECU via torque and there were no errors. I checked the engine bay area and found the following hose broken. Can anyone identify it so I can replace it? Can the car be driven, can duct tape provide a temporary fix?
The owls are not what they seem!
      07-05-2018, 11:45 AM   #2
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Look in this same forum a few topics ago: "DIY - 50i Spark Plugs" on page two, it may refer to your problem, about replacing a broken ventilation hose.
DuSh2113.50
      07-05-2018, 12:15 PM   #3
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Yes here's Maverick's post that he warned us about that hose (part# 11158647298) and advised to replace it: http://f15.bimmerpost.com/forums/sho...2&postcount=16
It's $110 from here: https://parts.bmwofsouthatlanta.com/...158647298.html
As a temporary fix you can use a sturdy duct tape, while you are waiting for a replacement part.
P.S. Not my business, but I almost had a seizure when I saw N63T. Already second post I'm seeing this. I initially thought it's some kind of a Euro spec engine version of our N63TU lol.
      07-05-2018, 12:49 PM   #4
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Haha yep. Exactly what was broke on mine. See my post for all the info you need. Much cheaper if you order from a wholesale dealer than local dealer. Either way they're gonna have to order it most like and duct tape or better I would recommend electrical tape due to its playability and ability stretch. But be careful cuz it's very brittle stuff and will break again. Mine broke just by putting my hand under it to clean up the spilled oil.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      07-05-2018, 12:52 PM   #5
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
A few bucks less from Husker btw:
https://www.bmwdirectparts.com/oem-p...60-11158647298
      07-05-2018, 02:46 PM   #6
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
I don't know about the v8, but i just had a similar issue with the n55.
BMW should definitely up their game when it comes to plastic around the engine bay.
      07-05-2018, 06:31 PM   #7
Twin Peaks
N00B
Twin Peaks's Avatar
      07-05-2018, 06:36 PM   #8
Twin Peaks
N00B
Twin Peaks's Avatar
Great stuff guys, thanks for the links! Does anyone know if I could wrap the new hose in heat tape to prevent it from turning to dust again?
Correction: I'll pick this one up from ECS tuning... its wrapped in rubber.
https://www.ecstuning.com/b-genuine-...e/11158647298/
      07-05-2018, 06:46 PM   #9
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
This is cool, I just got the regular replacement from the dealership!
I would also like to know what can I warp it with to prevent cracking in the future?
      07-06-2018, 11:43 AM   #10
Twin Peaks
N00B
Twin Peaks's Avatar
I am using HVAC tape temporarily till my new hose comes in the mail. I'd use heat tape if I were taping it. On another note, my local dealer suggested I also replace the the entire vent piece at around $340 for that part. I'll hold off on this entire piece till it follows suite and breaks.
      07-06-2018, 12:17 PM   #11
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Yea, for $340 without labor I would wait for it to break too.
Luckily my n55 crank case vent hose came quite cheap at $33.. best of luck with your car.
      07-06-2018, 12:57 PM   #12
Stev_chu
Stev_chu's Avatar
108
Drives: 2015 BMW X5
Originally Posted by DuSh View Post
Yes here's Maverick's post that he warned us about that hose (part# 11158647298) and advised to replace it: http://f15.bimmerpost.com/forums/sho...8;postcount=16
Is happening! It is happening!! N63T engine issues are showing!!!!! No!
      07-06-2018, 05:16 PM   #13
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Its actually quite common for these crank case hose to break, they are exposed to serious heat and they're very hard and stiff lines to begin with,
My 2014 740li with N55 had the same problem the crankcase hose snapped off after when replacing my spark plug, i used heat shrink wrap and it was fixed.
      07-06-2018, 05:59 PM   #14
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Yeah, that hose is made from hard thin plastic and is right above turbos. Cats heating up to 1700F are just couple inches below this hose. If it was made from thick rubber - then it would have lasted for almost eternity.
      07-06-2018, 10:27 PM   #15
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ya this is the current replacement part from
BMW.
'06 C55 AMG (sold)
      07-07-2018, 10:11 AM   #16
spike5150
Drives: 2020 X5 M50i
Sweet. Looks like they replaced both lines on mine under warranty a while back.
      07-07-2018, 10:33 AM   #17
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Looks good. Lucky you!
'06 C55 AMG (sold)
      07-25-2018, 09:48 PM   #18
Twin Peaks
N00B
Twin Peaks's Avatar
I got it to my dealer instead of purchasing that part via ecs tuning and got it all done for the low price of $50 (Extended warranty deductible). Also, my mpg went from 9 to 11.1 and I now have a misfire on cylinder 5. Most likely a bad spark plug, but must be related to this crankshaft vent hose. Both the hose and corroded spark plugs would explain my earlier concerns when I had the maintenance coverage still lol. My next assumption is that my spark plug/s and/or coil/s will be under an extended warranty since they are giving off errors and I have not reached my 60k maintenance cycle?
DuSh2113.50
      07-25-2018, 11:06 PM   #19
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Glad to see they replaced both hose assemblies. Especially since the smaller one is about $300 for the part alone.
Did you tape yours back up and drive to the dealer? That's the only thing I was afraid of and opted to just eat the cost of the cheaper hose and I put in myself vice dealing with my extended warranty
'06 C55 AMG (sold)
      07-26-2018, 11:23 AM   #20
Twin Peaks
N00B
Twin Peaks's Avatar
Yeah, my service guy told me I could when I called and suggested it. I explained that the whistling sound is how I discovered it. Its definitely a known issue with them.
      07-28-2018, 07:33 AM   #21
frenchie1013
frenchie1013's Avatar
78
Drives: sedan
Do you know the part number for the lower hose ?
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets
2014 X5 50i
BMS stage 1, Dinan intake, F85 Knee Bolsters
      07-28-2018, 11:20 AM   #22
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Which one do you mean by lower hose? The front or the back hose?
'06 C55 AMG (sold)
