11-05-2019, 11:44 AM | #463 |
Rep 1,062
Drives: F15 xDrive50i M-sport
Great time. Is this run done with the 550i in your signature?
11-05-2019, 06:22 PM | #464 | |
Rep 36
I sure am. I was stage 1 before I got the downpipes. Pipes added a nice lil bump, more spool up sound and little extra to otherwise OEM exhaust.
From what I've read, looks like stage 2 adds a degree or 2 of timing and 1.5psi midrange. Not confirmed though. Quote:
First run I had shifter in normal position, put it in sport+, and pressed the DSC button once. Held RPM to 3k and then let it eat.
2014 550xi M-Sport/BM3 Stage II/Catless DP/Comp Exhaust 2002 RSX-S 2.4L on corn spooling 62mm=550+whp/2500lbs |
11-08-2019, 03:38 PM | #465 |
Rep 489
I noticed that launching at 2 to 2.2k stays pulling hard whole way at 3k it seems like the car doesnt run as much timing as converter locks and then starts pulling again .
Also anyone have opinions on trans tunes? Not much info and I only see mission but I want bm3 or dme tuning so I don't know if I should do mission trans tune with diff eco tune. |
11-08-2019, 03:40 PM | #466 | |
IG @bmwF9xG80
3813
Rep 7,593
Contact elg0rd0yadigg or bm3tuning they're in NYC too
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
bm3tuning70.00 |
11-08-2019, 06:01 PM | #467 |
Rep 489
I have a 18 n55 x5 that's mhd stage 2 and a 09 n54 with hydra 650 turbos torqbyte meth controller and v8bait tune on mhd with xhp stage 3 and propulsive dynamics bushings and clutches with zip kit on my 6hp . Now my 16 550i I just bought and I want go bm3 or dme tuning but I am concerned with torque limiters in 3rd and 6th and if the tunes scale l2t tables to avoid this which means less shift pressure etc. That's why a trans tune interests me cause on my 6hp and my 8hp50 it transforms the car and obviously the new m5 is using the same trans just wider gear spread so the hardware can hold a ton of power,hell the 8hp50 can to but the mission trans tube claims to increase line pressure and speed up shifts plus allows more torque transfer during shift so should be able to make shifts very firm to point of in sport feeling like dct.
11-10-2019, 11:48 AM | #468 | |
Rep 174
Do have the compressor and turbine maps? |
12-01-2019, 01:23 PM | #469 |
IG @bmwF9xG80
3813
Rep 7,593
Bootmod3 Black Friday 15% Off Sale Ends Monday Night
Contact bm3tuning if you need help Enter BF19 at check out https://www.bm3tuning.com/vehicles
bm3tuning70.00 |
12-01-2019, 03:27 PM | #470 |
Rep 115
12-01-2019, 03:31 PM | #471 |
IG @bmwF9xG80
3813
Rep 7,593
Stock Plugs and NGK 97506 are the same for N63TU they already come with Colder Plugs
bm3tuning70.00 |
01-22-2020, 11:52 AM | #472 |
Rep 50
Dyno the x5!!! What a beast!! Bm3 custom tune e30 with meth 553hp 776tq
Pulls hard, waiting get to the track.BTW with bm3 stg 2 got 476/570 and with that tune ran 11.7@118 will see what this tune brings🏁😎 |
pennsiveguy3552.00 CT335xi684.00 |
01-22-2020, 03:40 PM | #473 |
Rep 1,434
Was this done at the same place/ same dyno? That torque seems a little bit high, watch out for your drive shaft you may break it!! That’s 200 more ft-lb more then before! Can’t wait to see your new track times.
2022 x5 m50i - Dravit grey
01-23-2020, 08:39 PM | #474 | |
Rep 1,062
Are your numbers expressed as Imperial horsepower and foot-pounds of torque, or ps and Newton-meters of torque? I've read, from some questionable or at least non-authoritative sources, that the N/S63tu connecting rods start to bend at around 700 whp. I have no idea how much faith to put in that. There are so few known (at least in my extensive research online) instances of these things coming apart that it's hard to know just how far we can safely push them. Hopefully all of ours stay healthy and live to a ripe old age. Can't wait to hear your track results.
01-24-2020, 02:03 PM | #475 | |
Rep 50
Wednesday ran 11.6@117 with just 93 stg3 ots bm3 |
01-24-2020, 03:29 PM | #476 |
IG @bmwF9xG80
3813
Rep 7,593
Its going to move with Meth
01-24-2020, 06:20 PM | #477 |
Rep 276
Can you post the graphs for the runs? Good job pushing the platform!
pennsiveguy3552.00 |
01-25-2020, 07:34 AM | #478 |
Rep 1,062
Nice! I blew the doors off a current-generation Cayenne Turbo a couple of months back. Very satisfying. But yours is cool 'cause that's an actual performance car that's legitimately fast.
skoold2003791.00 CT335xi684.00 |
01-25-2020, 04:40 PM | #479 | |
Rep 1,434
01-25-2020, 04:41 PM | #480 |
Rep 1,434
Was it a newer Mustang GT with the 5.0?
02-20-2020, 06:55 PM | #481 | ||
Rep 95
TXgrown
2018 x5 50i |
02-20-2020, 08:59 PM | #482 | |||
Rep 1,659
02-22-2020, 02:18 PM | #483 |
Rep 95
Debating whether or not to pull the trigger on the BM3 or DME Tuning. Just curious if anyone has done the BM3 in Texas and if it passes emissions for inspection.
TXgrown
2018 x5 50i |
02-22-2020, 02:46 PM | #484 |
Rep 1,062
You can always flash it back to stock in about 45 seconds, do your emissions test, and then put the tune back on in another 45 seconds. Easy-peasy.
