12-19-2019, 04:23 PM | #67 | ||
Rep 659
12-23-2019, 09:57 AM | #68 |
Rep 42
Just to clarify, I did not need to use different screws during the install, the stock plastic grille screws are recessed so deep, that my torx sockets did not reach the screwhead, and that is why i drilled the screw holes to a larger diameter. This is fine because you cannot use the stock grille with the earthquake sub (the earthquake excursion would hit the grille).
12-24-2019, 09:58 PM | #69 |
Rep 659
Thanks for the info it did come in handy.
I did use some of the stock grille so I could put the cover back on. The stock grille will hit but the cover won't. I cut two corners off and bolted them back in, then I reattached the cover to those two pieces. The cover may only have two screw holding it but it's better than the sub not being covered at all I thought. |
Chris S.16.50 |
12-29-2019, 05:19 PM | #70 | |
Rep 42
12-29-2019, 07:40 PM | #71 |
Rep 659
I just purchased a 2017
There was a cover that was flush with the carpet with 4 screws holding it to the grille. Under that was the grille of the speaker held on by four 10mm bolts. This is the part that would touch the new sub as it's not a down firing sub like the stock one is. I trimmed 2 of the corners off and bolted them back down to have a spot to screw the cover back down. You can only do 2 since the carpet is offset, and they're raked so pay attention to which one goes to the front of the vehicle and which to the rear. Hope that helps |
09-26-2020, 06:14 PM | #72 |
Rep 84
Sorry to revive an old thread but for those with B&O did you measure the resistance of the factory 8" speaker? Mine were 4.1-4.5 ohms and I was expecting 8 ohms as others have said. Wouldn't I be better off going 2 ohm for the 8" underseat woofers?
2016 X6M - Minera Whitel Metallic | Akrapovic Exhuast - Dinan Intake - Dinan S2
09-27-2020, 10:01 AM | #73 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
Wow, SWMBO'd & I must be getting old.....she has me turn down the "thumper" dial!
06-28-2021, 08:00 AM | #75 |
Rep 1,195
Are there not recommend EQ settings for the B&O system? I just picked up a 2018 and the B&O system is seriously lacking compared to whats in in my 2013 M3.
06-28-2021, 09:59 AM | #76 | |
Rep 125
I'll try and grab pics of my B&O settings, which I think is only lacking in the 20-50hz range which I'm trying to mitigate. |
06-29-2021, 08:17 AM | #77 |
Rep 1,016
I don't understand this, as B&O is supposed to be the premium sound system for the X5M. Personally, I never listened to the B&O system in our vehicles, so I have no frame of reference.
But the K&K system sounds great in these vehicles in IMO. I personally didn't want to spend the extra cash, when the H&K sounded exceptional to me. 90% of the time I listen to Jazz in my vehicles anyway. So with the EQ adjusted properly, I have no complaints whatsoever.
06-29-2021, 08:45 AM | #78 | |
///M
133
Rep 184
Drives: M8C/Taycan Turbo/Roadster 2.0
I also for reference I traded my M4 Convertible and X5M for a M8 Convertible with B&W sound system. The bass on the Earthquake sub upgraded B&O X5M is slightly better than the B&W simply because the SUV interior amplifies the bass where in the convertible it is open to air obviously. Without the Earthquake upgrade the B&O can't compare at all. Outside of that the B&W is superior to the B&O and the sound quality with the top down is surprisingly good which is no easy feat. |
06-29-2021, 09:26 AM | #79 | |
199
Rep 363
With respect to B&O, I did pull fuse #129 and it's different. Better different. I listen to everything, but I can tell the highs are crisper. I haven't had chance to play with Sport and Sport+ modes, so no feedback on the exhaust note yet.
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
06-29-2021, 02:50 PM | #80 | |
Rep 125
Great to hear, I'm going to pull the trigger then! I did find some pigtails on ebay that could make this mod almost a plugnplay without needing to cut the original plug. |
06-29-2021, 03:40 PM | #81 |
199
Rep 363
Link?
2017 X5 ///M
06-29-2021, 09:07 PM | #82 |
Rep 188
Anyone try stuffing some polyfill into speaker cavity before mounting the new sub?
2016 X5M F85 Mineral White
2011 Mercedes G55 AMG (sold) 2005 C6 Corvette (sold) |
06-29-2021, 09:32 PM | #83 |
19 X5 1998 M Roadster
64
Rep 1,503
Drives: 135i Alpine White / Terra
Instead of pulling fuse #129 - can you code it out via bimmercode?
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
06-30-2021, 08:31 AM | #84 | |
Rep 125
https://earthquakesoundshop.com/product/x84sws/
I need to find a female end for this connector: https://i.ebayimg.com/images/g/7x8AA...2n/s-l1600.jpg Quote:
I did this in bimmercode, its in the regular settings not expert mode. Last edited by nishfish87; 06-30-2021 at 08:50 AM.. |
06-30-2021, 05:56 PM | #85 |
Rep 188
Anyone listen to EDM and feel as though the Earthquake subs are good enough?
Or should I skip them and add a boxed 12" in the spare tire space instead?
2011 Mercedes G55 AMG (sold) 2005 C6 Corvette (sold) Last edited by Abstracted; 06-30-2021 at 06:02 PM.. |
06-30-2021, 05:58 PM | #86 |
Rep 188
Link to Earthquake subs in new condition (not refurbs):
https://earthquakesoundshop.com/product/x84sws-kit/
06-30-2021, 10:08 PM | #87 | |
Rep 90
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
Abstracted38.50 nishfish8737.50 |
07-01-2021, 07:39 AM | #88 |
Rep 125
