05-15-2019, 03:08 PM | #4797 |
Rep 29
Coding help
I just installed a retrofit reverse camera. I just installed the e sys software, when I look at the psdzdata I cannot se the f15!
Do I need a specific version to add the 3AG to activate the new camera? |
05-15-2019, 10:00 PM | #4798 |
Rep 8,364
05-24-2019, 08:14 AM | #4800 |
Rep 1,975
Can someone post instructions for the rearm script? Can't seem to find it.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
05-24-2019, 08:49 AM | #4801 | |
Rep 40,862
Https://f30.bimmerpost.com/forums/sh...62&postcount=1
mikew2069412.50 |
05-24-2019, 10:10 AM | #4802 | |
Rep 1,975
05-24-2019, 10:14 AM | #4803 |
Rep 40,862
F025 psdzdata covers F015/F016/F025/F026/F085/F086
mikew2069412.50 |
05-27-2019, 08:36 AM | #4804 |
Rep 4
Hey I've got a 2018 X5 and I'm pretty new to the ESYSX software. Is it possible to see coding done through OBD commands? So far I've only seen guides connect through ethernet.
05-27-2019, 05:02 PM | #4805 | |
Rep 8,364
ENET = OBDII to ethernet. OBDII is car side Ethernet is computer connection |
05-28-2019, 08:32 AM | #4806 | |
Rep 4
In the past I've done this on a VW Jetta using VCDS and it was pretty straight forward once I figured out how to listen to everything. Now with the BMW I'm not sure what I want to do will even work. |
05-28-2019, 10:49 PM | #4807 | |
Rep 8,364
05-29-2019, 01:29 PM | #4808 | |
Rep 4
Do you know if security access for $2E commands is necessary? If so, any tips for the seed/key generation? I was able to figure out the VW encoding pretty quickly but I have a feeling this won't be as simple. |
05-29-2019, 09:40 PM | #4809 |
Rep 8,364
05-30-2019, 09:41 AM | #4810 |
Rep 29
Coding problems E sys, No text visible in files
Hi,
Im trying to code my F15, but i keep getting the same problem. After i read the FA and activate is there is no text in the Vehicle profile folders! Also no text in the files CAFD when i read coding data. any suggestions? Last edited by albec; 05-30-2019 at 10:21 AM.. Reason: adding picture |
05-30-2019, 10:25 AM | #4811 | |
Rep 40,862
As for CAFD Data, Trimmed PSdZData means either E-Sys has Incorrect Target Connection, or you do not use E-Sys Launcher to open E-Sys, or you use E-Sys Launcher PREMIUM but select wrong car Series or this particular ECU CAFD is not mapped in E-Sys Launcher's CAFD Mapping Database, or you have insufficient Java Memory in order for E-Sys Launcher to map it.
05-30-2019, 04:19 PM | #4812 |
Rep 29
Thanks, how do I find out which of possible issues is the one I need to to fix.
I generate the token and link it in esys under settings. Esys loads the data from the car fine |
05-30-2019, 08:47 PM | #4813 | |
Love the X5, but R1 is life!
20
Rep 69
05-31-2019, 08:29 AM | #4814 | |
Rep 4
What I'm stuck on is the module requires security access to accept my commands. It gives me an 11 byte seed and expects a 132 byte key which I think is pretty bonkers. If there is a more appropriate thread or place to be asking about this please let me know. |
06-03-2019, 04:30 PM | #4815 |
Rep 2
Hi guys I’m pretty new to coding I know how to do it but I am not a expert when it comes to the systems we’re using I believe I have EsysPlus. I’m not sure if that’s a good one or not to use I am having the same issue as albec where there in no text in the cafd file. Any help that any one could give me would me much appreciated. Thanks guys.
06-03-2019, 08:44 PM | #4816 | |
Rep 8,364
https://www.bimmerfest.com/forums/sh...d.php?t=983245 |
06-03-2019, 09:44 PM | #4817 |
Rep 2
Hi almaretto thank you for the reply. I looked at the two links that you sent me and I’m not understanding what I should be looking for. Are you saying the PSdZdata file is installed incorrectly. Thank you again for the help. I’m sorry to be a pain.
