09-07-2018, 09:39 AM | #4423 | |
Rep 10
When i picked up the car, the service guy told me that they have done a firmware update ( with a smile in his face).... Most of the stuff that i coded were back to default and I had to code them again. |
09-07-2018, 12:28 PM | #4424 | |
Rep 96
Drives: 2010 335d, 2018 540d
Not sure how I missed something so obvious.... Thanks for your help Aleksandr! |
09-07-2018, 01:47 PM | #4425 |
Rep 96
Cheat Codes appeared and I selected ‘Enable trunk close from button and fob’.
However, when I hit Code FDL, I get the error message below: What do I need to do? |
09-07-2018, 10:46 PM | #4426 | |
Rep 8,364
If you Read ECU again, does HKFM2 have a blue cafd with green check mark? You can "Read Coding Data" without issue or error message? |
09-08-2018, 01:46 AM | #4428 | |
Rep 96
I ticked the cheat code box and it saves properly but the error only appears when hitting ‘Code FDL’. |
09-08-2018, 10:13 AM | #4429 |
Rep 4
Hi Everyone,
Need a little help. I'm trying to code my trailer hitch to my F15. The problem is when I try adding 235 to my SALAP-Element for my FA. I get an error when I calculate my FA. I'm sorry i did not get a screen shot of the error. But it sound like you should have none regardless. Anyway what I'm i doing wrong. Do I need the full PSdZDATA to do this? |
09-09-2018, 10:37 PM | #4430 | |
Rep 570
09-09-2018, 10:38 PM | #4431 |
Rep 570
Does anybody know if there is a way to code the distance ACC to permanently show the cars instead of just the bars? I mean the apace isn't used otherwise...
See below pictures... |
09-09-2018, 11:35 PM | #4432 | |
Rep 846
Edited: They're working now. Thanks! Last edited by 9mmkungfu; 09-10-2018 at 10:59 PM.. |
MrTookies459.00 |
09-10-2018, 10:44 AM | #4433 |
Rep 627
Drives: X5 F15 M package
anyone know where to code ID6 with BimmerCode?
thank you |
09-10-2018, 08:05 PM | #4435 |
Rep 627
appreciate sbinshihon your kind response. I was reading that it depends on your car hardware and version.
do you know if F15-2015 is eligible for this coding ? |
09-10-2018, 09:58 PM | #4436 | |
Rep 8,364
No. Only vehicles with ID5 can toggle ID6 (eg, 2017 F15). |
09-11-2018, 05:54 AM | #4437 | ||
Rep 627
Bit of disappointment with the infotainment but that's a story for another thread |
09-11-2018, 07:30 AM | #4438 |
Rep 570
Is it maybe possible to code the KM/H to be visible at all times similar to how the mileage will automatically come on when KM/H is selected as the main Value?
09-12-2018, 09:57 PM | #4439 |
Rep 7,163
dont see it yet on the cheat sheet. Has anyone coded for MPBK on their own yet? really trying to avoid the dealer here. Alan I. or shawnsheridan I read y'all did it yourself but didn't see any more detail just that it took 10 min lol.
Any help would be appreciated.
09-12-2018, 11:27 PM | #4440 | |
Rep 846
=> Connect => Expert Mode => Coding => Read FA => Save FA => Editors and viewers => FA-editor => Go to HO-Wort and right click on "Edit," then type SBRE under the HO-Wort file => Select the FA, "Calculate FA" to verify that no errors are found after adding the SBRE. => Write (write) FA to your car. No confirmation window will appear after saving the FA to the car => Expert Mode => Coding => Read (read) the FA. You are able to see SBRE be added to the HO-Wort folder on your car. => Read SVT, and locate the "DSC" (File Folder SVT / ECU / DSC), then right-click the "DSC" folder and select "Code". Consolidation should start immediately. => Allow the coding is over, and repeat step 1 to save a copy of the new FA. => Disconnect the car's computer. |
09-12-2018, 11:53 PM | #4441 | ||
Rep 7,163
09-13-2018, 09:33 AM | #4442 | |
Rep 846
https://f15.bimmerpost.com/forums/sh....php?t=1178827 |
Maverik2594146.00 |
09-13-2018, 02:14 PM | #4443 | ||
Rep 7,163
09-14-2018, 04:08 PM | #4444 |
Rep 20
Hi - we just got a 2018 X5, and I’m new to coding. I’ve use BimmerCode iPhone app to code most of the “essential” things, but just cannot figure out if there is way to have the fog lights turn on whenever the headlights are on.
Any expert advice? Thanks! |
