06-19-2021, 10:09 PM | #1 |
Rep 41
Daily driving setup
What are folks daily driving setups? I received my 2017 x5m last week and am still getting to know the vehicle but initial impression is it is a beautiful car but a bit tame in default/comfort mode, seems like the transmission wants to shift around 2000 rpm. I am coming from a Jeep GC with Hemi and that car felt like it had more power when just cruising around. I am looking for a daily mode that is relatively comfortable but allows the engine to rev a bit and generate some power, any suggestions? I have tried spot and sport + all around but seemed a little harsh for daily driving.
Thanks. |
06-20-2021, 03:12 AM | #2 |
184
Rep 364
Drives: M2C X5M M4
My M1 button is set to sport steering, sport suspension, and sport+ engine with level 2 drivelogic in auto mode which I use mainly for commuting. I do live rurally and would probably knock the engine down to,sport for more urban.
M2 is set to Sport steering, sport+ suspension, and sport+ engine with level 3 drivelogic in manual mode and mdm on. It's hard as it's individual but that's where I'm at, I drive an M2 comp too and any engine setting below sport seems like too much travel on the throttle if I swap between the two and catches me out, the X5 sport engine setting is about comfort in the M2. |
Klienfeld303287.00 |
06-21-2021, 12:24 PM | #3 |
Rep 271
M1 - Steering Sport, Suspension Comfort and Engine Sport - Drivelogic on 2 Manual
M2 - Everything Sport+ Drivelogic 3 Manual. I pretty much drive on M2 settings all the time. |
06-22-2021, 05:11 AM | #4 | |
Rep 417
ACID.
06-22-2021, 05:15 AM | #5 |
184
Rep 364
Drives: M2C X5M M4
I'm not lowered or modified at all it's as god intended.
06-22-2021, 07:33 AM | #6 |
Rep 417
Ahhh ok so you're good. And FYI god likes low, street hugging grip babies with bite.
ACID.
///MCollection183.50 |
06-22-2021, 09:26 AM | #7 | |
Rep 271
Perhaps the difference you're feeling is a turbo engine vs NA? The only thing I usually change is the engine more to high setting as everything else makes everything too harsh or the engine is sitting at a crazy high rpm. It is annoying as sometimes you just way to give it a little more gas and are expecting a shove, but....nothing. Give it even more gas, awkward pause, downshift, neck-snapping shove. Hate that. Wish this car had the F10M5 option of having a stick shift.
