07-12-2017, 08:03 PM | #3543 |
Rep 12
@ Almaretto
I was able to make some coding changes, but still can't get the Cheat Codes to load into the launcher. What exactly should I be doing when I see the almaretto.xml file on Github? I right clicked on it, saved the link, and then placed the .xml file in the correct folder. But when I click on the xml file and open it in Internet Explorer, I just see bmw-f/Almaretto.xml at master · packetpilot/bmw-f · GitHub No lines of code. What am I doing wrong? |
07-12-2017, 11:15 PM | #3544 | |
Rep 8,364
x
07-13-2017, 12:26 PM | #3545 | |
Rep 12
The above image is what I see when I open the XML file up in Internet Explorer So, I must be doing something wrong here, any additional assistance is greatly appreciated. |
07-13-2017, 04:42 PM | #3546 | |
Rep 8,364
View post on imgur.com |
07-14-2017, 11:12 AM | #3547 | |
Rep 12
07-16-2017, 03:24 PM | #3549 |
Rep 3,803
You guys are incredibly advanced at this, or maybe I'm just old. It's both really.
I've been fighting with this all day trying to update to latest software which I finally got and I can connect now. When I go to code the BDC_ body... all the folders are blank there's no wording at all, in any language. This is the only module that I found like that. Anybody have any clue? |
07-17-2017, 09:19 AM | #3550 | |
Rep 225
I re-read the 1st page and realized I forgot to deselect Update "VCM after TAL execution" and "Update MSM after TAL execution". After I deselected those, all the folders were displaying correctly instead of displaying "." Also, my memory requirement was set at 2048mb, so I changed that to 1024mb, maybe that helped too. Options > Settings > Program: Memory Requirement. Maybe give that a try.
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone |
07-17-2017, 09:21 AM | #3551 | ||
Rep 3,803
I know I changed them ... but that was prior to deleting all the programs and reloading them. I can't recall if I checked them, the second time. |
07-17-2017, 09:23 AM | #3552 | |
Rep 40,788
If CAFD Mapping is missing, it can only be either you do not use E-Sys Launcher to open E-Sys, or E-Sys Launcher has Incorrect Car Series, or E-Sys has Incorrect Target Connections. There is no other possible cause.
07-17-2017, 09:44 AM | #3553 | |
Rep 225
Not saying it could work for him, but worth a try.
07-17-2017, 09:51 AM | #3554 |
Rep 40,788
I understand you believe this to be what worked for you, but it simply is not the case, and there was something else going on with your situation. These two Options are not related at all to CAFD Mapping, and they can either be checked or unchecked, and CAFD Mapping will work fine either way.
07-17-2017, 10:02 AM | #3555 | |
Rep 225
That time around, it was after I just had my MPPK installed, do you think that may have affected anything?
07-17-2017, 10:05 AM | #3556 |
Rep 40,788
No. MPPK would only affect DME, bot BDC Module.
07-17-2017, 10:14 AM | #3557 |
Rep 225
Ah I see, guess I'll backtrack and see what else I did differently.
07-19-2017, 06:57 AM | #3559 |
Rep 40,788
Car need KAFAS Camera, a 7E SLI FSC Enabling Code, and then it can be coded.
07-19-2017, 07:24 AM | #3560 | |
Rep 2,194
Thanks for your assistance! Last edited by Violator; 07-19-2017 at 07:31 AM.. |
07-19-2017, 09:03 AM | #3562 |
Rep 40,788
Not above 63 kmh (39 mph). For VIM with no Speed Restriction, only commercial solution exists.
07-19-2017, 09:10 AM | #3563 | |
Rep 40,788
So you need 7E SLI FSC Code and Coding, which is possible. PM sent.
Violator4587.50 |
07-21-2017, 12:30 AM | #3564 |
Rep 96
Drives: 2010 335d, 2018 540d
Setting up ICOM for coding
Hi,
I need help to figure out how to configure my software so that I can use my Genuine ICOM to code my F15. Can someone advise me, please? Thanks! |
