11-05-2017, 08:10 AM | #1 |
Rep 102
Winter wheel question
PIcked up a set of 298M wheels (made for the E70 X5M) for my F15, but now after doing futher research, I'm worried they might not fit. NOtably, the offset is 19 on the wheels, compared to the 37 stock on the F15. The center bore was always 74.1 on both models.
Has anyone tried these? Any input? |
11-05-2017, 08:22 AM | #2 |
<3 Flat Four
215
Rep 754
the lower the offset, the more the wheel will stick out when mounted onto the car. X5s have plenty of wheel gap so u shouldnt have to worry about fender rubbing issues. 37-19=18mm difference, meaning the wheels will stick out 18mm more compared to ur stocks. u will be fine, in fact, it means theres more clearance between the inside spokes and the brake calipers.
2011 335is Le Mans Blue
11-06-2017, 08:48 PM | #3 |
Rep 982
Did you check the center bore?
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53 X5M E70 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.25 bolt thread. ET 18-40 |
