10-10-2018, 01:47 PM | #1 |
Rep 62
iPhone X / Charging USB
I know its a known issue that charging via USB on iPhone doesn't function correctly due to power usage on the newer phones. However, did they fix this in any recent model years? When I test drove a 2015/2016 recently, it didn't work correctly.
I believe a SA told me that in 2017 they fixed the issue, but I forgot. |
10-10-2018, 02:22 PM | #3 |
Rep 62
10-10-2018, 02:29 PM | #5 |
Rep 62
My only thought is that connecting my iphone directly to the car increases music quality compared to bluetooth. While still keeping it simple with spotify/music app.
10-10-2018, 02:35 PM | #6 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
10-10-2018, 02:38 PM | #7 | ||
Rep 7,159
I have a 2014 and have no issues charging my iPhone XS Max I also ran an 2nd auxiliary usb directly to the head unit to replace my console phone snap in adapter.
10-10-2018, 03:03 PM | #8 |
1148
Rep 2,426
Mine seems to disconnect. I don't get audio or anything.
Audio plays fine if I use Bluetooth though.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
10-10-2018, 04:26 PM | #9 |
Rep 271
BMW fixed this issue in 2017 and some late 2016 models. Only way to test this is to plug an iphone into the USB, if it constantly beeps, then it has the old design and BMW won't do anything about it on it's own.
However, if your idrive crashes randomly (known issue for 14 and 15 models) and still under warranty, with a good SA or shop foreman on your side, BMW will replace idrive with newer design which also solved the USB issue. My replacement unit works flawlessly now, no more idrive crash or USB port issues. |
10-10-2018, 06:14 PM | #10 |
Rep 55
My iPhone X doe not charge sufficiently to keep the battery from draining when I run Waze and V1Driver (for Valentine One radar detector). My sense is that the two GPS apps consume power faster than the iPhone can be recharged when plugged into the USB port. I now keep my iPhone connected to my car by BT rather than the audio port and power it from the 12V in the console.
I drive a 2016 X5. |
10-10-2018, 07:31 PM | #11 | |
1148
Rep 2,426
BMW CCA 509766 |
10-11-2018, 07:47 PM | #12 |
1148
Rep 2,426
I got my car back from the dealer and I plugged my iPhone XS Max into my car and it looks nice it charges and plays audio now, so I guess I got the newer head unit.
BMW CCA 509766 |
10-11-2018, 09:36 PM | #13 |
Rep 536
Never had any issues. I use the oem cable. Using the USB port the charging is very very slow like 10% in an hour. So if you are using your phone, it might still discharge. I just have a 2.1amp cig light adapter which will charge almost 30-40% in an hour so I just switch the cable to that when I am using the phone for something.
10-11-2018, 10:00 PM | #14 | |
Rep 271
Glad it worked out for you. USB charging is faster now with the newer idrive although 2.4 amp car charger is still the fastest. |
10-11-2018, 11:11 PM | #15 | |
1148
Rep 2,426
I know I can send to car or use other things, the USB way is fastest. Actually seems this new unit recognized my phone faster too.
BMW CCA 509766 |
10-17-2018, 09:03 AM | #16 |
Rep 66
I brought AUKER 2.4 amp cigarette charger on the console. Works like a charm!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-19-2018, 10:02 PM | #17 | ||
Rep 7,159
09-05-2020, 01:20 AM | #18 |
Rep 1
It's a pity that an article I saw before about iPhone or iPad not charging does not list a solution in this case.
