10-14-2019, 11:50 PM | #397 | |
OEM CSL Whore
1250
Rep 1,476
iconoclast7262.50 |
10-15-2019, 12:50 AM | #398 | ||
Rep 18,685
Were you on Asphalt or Cement? It is very tough do determine on Cement since it has a lot of grooves. But, if it happened on Asphalt, then your alignment is off for sure.
10-15-2019, 11:34 AM | #399 |
Rep 1,859
Drives: 23' X7 40i M Sport
Sorry this may have been asked elsewhere so apologies in advance.
H&R recommends re-torquing the lug bolts after 60 miles of driving after installation. My question - should this be performed every time you swap out your Summer/Winter wheels, or really only for the initial installation?
10-15-2019, 11:41 AM | #400 | |
Rep 18,685
classic_erik2808.50 |
10-15-2019, 12:39 PM | #401 |
Self-Deprecating Narcissist
7263
Rep 6,561
asphalt. highway. state thruway and similar. even on freshly paved country road at certain speeds it was pulling.
r33_RGSport12915.50 |
10-15-2019, 01:15 PM | #402 |
Rep 18,685
Need to get the alignment re-check then.
iconoclast7262.50 |
10-15-2019, 01:25 PM | #403 |
7263
Rep 6,561
I did not try that. I have all systems enabled. Perhaps disabling them may be a way to narrow down the exact issue otherwise I may be needing another alignment now that the vehicle settled.
10-15-2019, 03:23 PM | #404 | |||
Rep 1,025
iconoclast7262.50 |
10-15-2019, 07:46 PM | #405 |
7263
Rep 6,561
I have not but I will try that as well. Thank you.
Kraftwerk AG460.00 |
10-16-2019, 10:42 AM | #406 | |
Rep 1,266
Hopefully it’s a simple fix and adjusting tire pressures is fairly easy to do that doesn’t require you to take it to the stealership. I’m guessing that our cars are so heavy that something so simple as tire pressures can affect steering due to available contact patch if the tires which may or may not affect camber/toe under heavy load/driving.
2015 BMW X5 ///M | Donington Grey | Aragon Brown MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby 2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown |
4
10-16-2019, 04:13 PM | #407 | ||
OEM CSL Whore
1250
Rep 1,476
donut_boi997.50 |
10-16-2019, 08:26 PM | #408 |
7263
Rep 6,561
Reduced PSI to 38/42psi and still an issue. Shut off all the nanny features and still an issue. Darting all over the highway. Going to schedule an alignment and go from there.
10-17-2019, 01:27 AM | #409 | |||
OEM CSL Whore
1250
Rep 1,476
11-04-2019, 04:37 PM | #410 |
Rep 1,179
Has anyone put a 10mm/30mm setup on a stock msport with staggered 20s? Would this be too aggressive or ok?
11-04-2019, 05:09 PM | #411 | |
Rep 18,685
But 10mm is not enough for the front.
skoold2003791.00 |
11-11-2019, 06:59 AM | #412 |
Rep 195
Will spacers help tighten the steering/suspension?
11-11-2019, 09:26 AM | #413 |
Rep 18,685
It will give you better handling since you have wider stance.
Tighter steering wheel, I don't think so. Yoo will need to go with wider tires to do that.
11-18-2019, 07:45 AM | #414 | |
658
Rep 345
11-18-2019, 08:28 AM | #415 | ||
Rep 18,685
What are the specs of your 22"?
12-28-2019, 04:04 PM | #416 |
MR. Rocket
46
Rep 398
Drives: 2010 E92 335i M-Sport
12-28-2019, 06:58 PM | #417 |
Rep 18,685
PM'ed.
12-29-2019, 10:56 AM | #418 |
Rep 46
Drives: 2020 BMW X5 x40i
Hello Ben - looking to add spacers to put rims (winter and summer) near the edge of the fender flares. 2015 X5 50i sport. Vin 0J76600
Winter - 19” 467..255x50 square Summer - 21” Double spoke 375...rear 325x30x21 & front 285x35x21 Last edited by Duckengine; 12-29-2019 at 11:04 AM.. |
