      05-25-2019, 07:14 PM   #23
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
Originally Posted by Kruppa View Post
Originally Posted by daytonaviolet View Post
just wondering if these are still your current settings? i just need to know in ~ 4-6 weeks as i just ordered my KW's today from Ben
Sorry for the long delay here, been crazy busy.
Alright so I still love this setup just as much as my original thoughts, if not more. I did mess with the settings a bunch and finally have it where I want. At first I started off too soft, which was great for around town but it was scary/floaty going fast on the highway so I had to find a balance.
When you adjust these settings you are supposed to turn the adjustments all the way to fully firm and then go backwards from there hence my descriptions below.
Front Bump: -6 from full stiff (was -8)
Front Rebound: -9 from full stiff (was -12 which was too soft, then -6 which was too harsh)
Rear Bump: -6 from full stiff (was -7)
Rear Rebound: -10 from full stiff (tried -9/-11, this is just right)
So I personally find this to be the best balance of everything. I learned a lot in my research about what bump vs rebound does to the dynamics of the car and it's been a fun process. I hope some people find this useful.
Thanks for doing the research on these. I'll give them a try soon 😇
      05-26-2019, 10:34 AM   #24
Kruppa
Drives: 2023 M5 Comp & 2024 X7
Why not just raise the driver side to make it even ?
Because it’s a little too high for my liking - the drivers side is perfectttt
      05-26-2019, 09:20 PM   #25
You might want to check the installation.
If both side are the same length from top of shock to lower spring perch, then it may be that the shock body didn't slip in all the way in to the lower fork.
      07-17-2019, 02:55 PM   #26
daytonaviolet
OEM CSL Whore
Philippines
1250
I finally got my kw's installed. Omg, the ride is awesome and smooth. I ended up with the kw recommended settings 6 for everything.
Want to thanks Kruppa for getting me to go smoother route and Ben for hooking me up 😇
Appreciate 6
      07-17-2019, 03:37 PM   #27
donut_boi
Drives: 2015 F85 X5M DGM
Want to thanks Kruppa for getting me go smoother route and Ben for hooking me up ��
Damn Fern, looking good pare! You make me want to keep mines and just install them
2015 BMW X5 ///M | Donington Grey | Aragon Brown
MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby
2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown
      07-17-2019, 07:29 PM   #28
daytonaviolet
OEM CSL Whore
Philippines
1250
Just install the kw as you already got them 🥴
      07-18-2019, 06:26 AM   #29
desertfox73
676
Drives: 2018 F83 / 2018 F85
Nice!! Looks great, isn't the ride incredible?
      07-18-2019, 09:37 AM   #30
iembeastmode
Drives: BMW X6M
These look awesome! Though one question to you all, how does a mod like this affect the stability of the car, especially if you like going fast and/or going to the track.
I mean the oem ones and the height of the car is factored in with the electronic stability control of the car right? Will chanting it, compromise this and other systems?
      07-18-2019, 01:20 PM   #31
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Looks great bro
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      07-18-2019, 03:13 PM   #32
KCTiger
Drives: 2016 X5M
What should I expect to pay in labor to have these installed? Closer to $500 or $1,500? Thanks!
      07-18-2019, 04:09 PM   #33
daytonaviolet
OEM CSL Whore
Philippines
1250
In the Bay Area ~ $900 installation/alignment
      07-18-2019, 04:11 PM   #34
daytonaviolet
OEM CSL Whore
Philippines
1250
Yes I agree 😇
      07-18-2019, 04:21 PM   #35
KCTiger
Drives: 2016 X5M
Thanks!
      07-18-2019, 05:23 PM   #36
desertfox73
676
It's better in every way. Settings will matter, though.
I've said this in other threads, but i can't believe BMW doesn't just ask KW to do their stock M suspension.
      07-18-2019, 05:43 PM   #37
daytonaviolet
OEM CSL Whore
Philippines
1250
+1
i think bmw wanted to offer EDF
      07-19-2019, 07:06 PM   #38
KCTiger
Drives: 2016 X5M
I have had a couple of drinks so please forgive me if these answers are in the posts above...
For the folks that have done the KW install, what suspension setting did you typically roll with prior to the install? I am Sport + unless my kids are in the car. I despise body roll. I ask bc the consensus is that the ride is "better" but not sure how to interpret what better means and what suspension setting it is being compared to.
Once I close my next deal at work, the KWs are going on. Might be 6 months or more unfortunately.
      07-19-2019, 07:09 PM   #39
daytonaviolet
OEM CSL Whore
Philippines
1250
when i drove alone it's usually sport+. with the family in the car, it's comfort all the way.
      07-19-2019, 08:03 PM   #40
KCTiger
Drives: 2016 X5M
And sorry for being annoying but the ARS is no longer available after the install, correct? I am pretty sure the damper control is disabled but assumed ARS too even though I haven't read that anywhere. Thanks all!
      07-19-2019, 10:29 PM   #41
daytonaviolet
OEM CSL Whore
Philippines
1250
ARS is still active as these refer to the dynamic sway bars 😇
      07-20-2019, 12:23 AM   #42
Blewx5m
Drives: 2015 x5m
Agree with KcTiger...@daytonaviolet can you explain the likes and dislikes of the stock setup vs h&r vtf vs kw? I'm looking to upgrade to the h&r vtf bc i like the adjustability of stock settings but if the KW improves the car's abilities, I might reconsider haha thanks for the input
      07-20-2019, 06:14 AM   #43
KCTiger
Drives: 2016 X5M
Ok thanks DV. I definitely don’t mind giving up EDC but was hoping to maintain ARS.
      07-20-2019, 07:50 AM   #44
Phara
Drives: BMW X5M F85 2018
I thought it was 9 click rebound for the rear axle?
