11-27-2021, 11:48 AM | #5480 | |
148
Rep 348
My vehicle has both of those options installed and functioning. I am uncertain how to best proceed? |
11-27-2021, 11:53 AM | #5481 | |
Rep 40,662
Do you have the issue with using E-Sys direct, or only when using E-Sys Launcher?
11-27-2021, 12:06 PM | #5482 |
148
Rep 348
I connect, click Read, right-click FA, choose Activate FA. Then I get the pop-up "No FP could be generated..."
I noticed my E-Sys is not configured as your directions say - "On the "OPTIONS" Tab Uncheck the boxes for "Update VCM after TAL execution" and "Update MSM after TAL execution". Did this cause me problems maybe? |
11-27-2021, 12:09 PM | #5483 | |
Rep 40,662
Again, do you have the issue with using E-Sys direct, or only when using E-Sys Launcher?
11-27-2021, 12:12 PM | #5485 | |
Rep 40,662
Try connecting and activating FA with E-Sys Direct, not via E-SysPlus.
11-27-2021, 12:54 PM | #5488 | |
Rep 40,662
.est not needed unless FDL Coding. Right now, we are only trying to determine if FA can be activated and FP can be generated when using E-Sys direct without ESysPlus. If so, then try connecting and using Launcher PRO 2.8.2 instead of ESysPlus for FDL Coding. As for MEGA Link package, you must use LATEST version of WinRAR or 7-Zip for extraction, or get from Developer's Blog: From TokenMaster's Blog: UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST Links are there: http://tokenmaster.blogspot.com/2019...r-pro-282.html
11-27-2021, 01:16 PM | #5489 |
148
Rep 348
Sorry, I did not communicate well at all.
FA can be activated and FP can be generated when using E-Sys direct without ESysPlus. I then tried to FDL, and got the EST error. |
11-27-2021, 01:19 PM | #5490 | |
Rep 40,662
So, use Launcher PRO 2.8.2 instead.
11-27-2021, 03:06 PM | #5491 |
148
Rep 348
Success. I coded the F15 for the first time.
I couldn't of done it without you, shawnsheridan. Thank You so very much! On a parallel topic, I was considering doing the software updates in ISTA before doing more coding. Are Software Updates risky in any way? It is showing 53 operations in the service plan. |
11-27-2021, 03:10 PM | #5492 | |
Rep 40,662
11-27-2021, 09:49 PM | #5493 | |
148
Rep 348
I have an ICOM, as well. My fear is that it will wipe out the configuration for things like the cameras, and such - that it will demand a calibration I cannot do, possibly. Thanks Again! |
12-28-2021, 11:00 PM | #5494 |
Enrique
Rep 21
hello opasha , its too late sorry for the hour
hope your doing well and happy holidays. im new to x5. just picked up an bmw x5 f15 2014. im having the 6WB CLUSTER AND M PERFORMANCE STEERING WHEEL NEXT WEEK (CURRENT STEERING NO PADDLE SHIFT) . i want to ask if you can help me all the process coding it or if you charge me for the labor . looking forward to your answer thanks. also tried to send PM but it said its full |
12-28-2021, 11:03 PM | #5495 | |
Rep 40,662
///d1817.00 |
12-29-2021, 12:19 AM | #5496 |
Rep 611
Much like most of our F15/F16 forum moderators lol
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
12-29-2021, 04:34 AM | #5497 |
Enrique
Rep 21
12-29-2021, 07:02 AM | #5498 |
Rep 1
Hello,
I have an X5 f15 2014 with sorround camera. I try coding to work all camera at any speed and any distance. I change in: 1. Icam SV Activation Speed Limit werte=FF SV Dezactivation Speed Limit werte=FF 2. PMA2 V_SCHWELLE_1_KMH werte=C8 V_SCHWELLE_2_KMH werte=C8 All was ok, front and back camera work at any speed and for any distance. I try to change on PMA2: D_SCHWELLE_1_KMH to werte=FA and werte=FF D_SCHWELLE_2_KMH to werte=FA and werte=FF Surround/top view camera work at any speed but only for 250 m. Any other value where i must change to keep surround view active all time for any distance? I see here in a post something about this: Abschaltschwelle_bis_09-09 Abschaltschwelle_0Kanal_vorn Abschaltschwelle_ab_09-09 But i dont know if i find them in PMA2, if are related with sorround view or pdc and what value i must set to work surround view camera for any distance. Thanks a lot |
01-11-2022, 01:48 PM | #5499 |
Rep 64
Drives: 2016 BMW X5 xdrive50i
Keep Cruise Control Enabled through On/Off Cycle
Hi Team -
I have a 2016 F15 50 without any active cruise control, just standard cruise control. I searched, couldn't find this one. My wife's 2020 Buick Enclave will keep the cruise control "on" between engine starting and stopping. This is nice, because then I just can press the little up rocker to set the cruise control speed and activate it. With my BMW, I need to first "turn on" the cruise control, then I need to go and press the rocker to set my speed and activate. I would like to either: 1. Code cruise control to be "on" automatically when the car starts, or 2. Have the car remember what the setting was before the car was turn off, and resume with that cruise control setting. Any ideas? I have bimmercode, but if I need to get more advanced for this one, let me know. Regards, Jason |
01-11-2022, 06:16 PM | #5500 | |
Rep 10
https://f15.bimmerpost.com/forums/sh....php?t=1873756 |
