11-08-2021, 09:10 AM | #1 |
167
Rep 360
Drives: 2018 LBB F85 X5M
F85 X5M - advice on some annoyances
Hi all,
I have had a couple of things annoy me recently on the X5M that I wanted to get some further information before I take it to local dealer (as under warranty). Firstly I have suffered from the well known blocked sunroof drains, I was going to look at this myself but thought I would leave it to the dealer. Is there anything specific (i.e. known problem or bulletin number etc) that I can inform them of as I know that even if common dealers do like to suggest it not being a known problem until you provide further information.... Secondly I have noticed an in and out drone type noise when in Sport+ when at low revs and relatively low speed (20-40mph). You can hear in come and go as driving when maintaing consistent throttle. I tested this and it is also the case in Sport but not in economy. Is this exhaust related and normal? Finally when using the air-con the unit itself it can get quite noisy compared to other models i have owned (F80 M3, F90 M5), are they like this generally in the F8* or are these liable for problems? Thanks
Current Car: F85 X5M
Previous cars: F15 X5 40d, F90 M5, Audi S3 8V; F80 M3 CP; F30 335d |
11-17-2021, 07:19 AM | #2 |
Rep 1,733
Drives: 2003 M3
I notice the drone as well. 2500RPM on the highway, usually 7th or 8th gear.
This happened in my F10 M5 but it was not as pronounced as in this vehicle. |
11-18-2021, 05:43 AM | #3 |
Rep 1,018
On the AC, compared to other cars, anything past 2 bars sounds like a jet taking off. So i would say its normal.
I would be ok with the noise, if only it cooled the dam car. |
05-09-2022, 02:58 PM | #4 | |
Rep 1,733
Drives: 2003 M3
