11-14-2021, 07:55 AM | #1 |
Rep 458
Long awaited for tranny fluid change
Well yall been asking, so i figured yall should receive 😁😁😁🤣, tranny fluid change, pan drop, filter replacement, and fill to spec: so my f85 has around 60k miles on it, i just recently got it so i am doing all the fluids, filters, paint correction, etc. I decided to replace my tranny fluid today, got the vehicle leveled (very important), took out the drain bolt, drained about 5-5.5qts, then pulled the pan, then filter, and let it sit and drip, then cleaned everything, reinstalled the filter, then got the pan back on, torqued new bolts to spec, then it was time to fill, so you fill fluid (lifeguard8) till it starts coming out of the fill plug, then you turn the car on and again promptly fill till fluid comes out, then with the car running you get in and hold it at 2000rpm for 30 sec, then change gears while holding the brake pedal, then get back under, undo the fill plug, fill till fluid comes out again, check temp, make sure it’s between 30-50c, then tighten and youre good to go. I will do another drain and fill in 5-10k miles, but thats about it.
Fluid that came out wasn’t abnormally dark or smelled burnt. But definitely much darker than fresh zf fluid. Ive noticed good bit of metal dust stuck to the magnets in the filter, but in my experience this is average amount, no chunks or pieces or any debris/bits in the pan or filter, so everything seems to be healthy visually as far as i can Tell. Otherwise not bad of a job at all, worst part was tranny fill and trying to catch the proper level within required temp threshold. Doing my part in properly maintaining the beast 😁😁😁 Follow me for more diy projects and stay safe out there ! PS let me know if yall need my diy on diffs and tcase fluid replacement |
11-14-2021, 08:53 AM | #3 |
Rep 458
5
11-14-2021, 01:46 PM | #4 |
Rep 1,340
Thank you, that was really useful. Several DIY write ups/videos on the f15 transmission, but none for the F85. Can you share a link to the parts? Your box says ZF, but I wasn't aware there were non-BMW branded kits available for the F85.
Please do share your DIY account for tcase & differentials. |
11-15-2021, 07:17 PM | #5 |
Rep 900
Any shifting change after the trans service, or is it just the same as before? Did you have to clear any adaptation values? I had this service done by the dealer (just as a preventative maintenance) and the shifting was not as smooth as before the change. Took it back and they said it will smoothen out with time as the trans adapts to the new fluid; well, it hasn't to date. Asked them to recheck fluid level and they reported back it's all good. This is a highly reputed dealership.
11-15-2021, 08:40 PM | #6 | ||
Rep 1,018
Its a 2x part process.
Have a quick search, there are heaps of thread of people having the same issue post oil change. After the adaptation reset, and the issues went away. Last edited by Chilled; 11-15-2021 at 08:55 PM.. |
11-15-2021, 11:43 PM | #7 | |
Rep 458
11-22-2021, 10:06 PM | #8 |
Rep 1,018
Hey question, do you know what the difference between the pan temp and the oil? It's more of a curiosity.
When I did mine, I couldn't find my IR to play with. |
08-13-2023, 06:49 AM | #9 |
Rep 1,693
dentprotony@gmail.com how does the filter attach to the underside of the transmission? Does it just pop in enough to not fall out and the circle indents inside the pan hold it from falling out once the pan is in place?
08-13-2023, 07:07 AM | #10 |
Rep 1,018
It just pops in, and is held in place by the filters o-ring. Make sure the old o-ring is not stuck in there.
08-14-2023, 09:07 AM | #11 | |
Rep 91
It wasn't until I performed a round two (simple fluid drain and fill) and following the refill procedure temperature, shift, and RPM requirements perfectly that it completely turned around. I planned to do two rounds anyway because of the inability to get all fluid out in one go. Waited ~2k miles second time and it's perfect. |
