11-23-2021, 06:50 PM | #1 |
Rep 78
Questionable Dealer Experience: What should I do?
My 2014 X5 50i (65k miles) is currently at a Washington DC area BMW service center and I believe that I am being taken advantage of. I have gotten some questionable information from them and when called on it, they deny it is a problem. Seeking some advice from you guys on how to navigate this issue. The entire situation is below.
1. Told that 6 initiation coils went bad at the same time. I took my car to a non-dealer service center for an oil change. Car suffered a drivetrain malfunction about 6 hours later. Had it towed to a BMW dealer who ran a diagnostic and found misfires on 6 out of 8 coils. They recommended that I change the coils and the plugs. I told them the plugs were recently changed 4 months ago. I find it hard to believe that 6 plugs could go bad at the same time. I was told that it is not unusual to see that happen. A friend of the family that is a mechanic for 30+ years says otherwise. 2. 200+% markup on battery replacement. Had an ambient light issue that I asked them to look at. They diagnosed it and I was told that the issue was my two batteries were going bad. The quote to replace was $1100. I laughed and told him I wouldn't be paying that. Googled the cost on BMWUSASERVICE and the cost was $485 installed. Pressed him to agree that this is the amount I would be charged. What's that a 220% markup ? 3. Told my warranty wouldn't cover things that it does. Regarded the ignition coils. I was told my 3rd party warranty company wouldn't be accepted because they had problems with payments in the past. Asked him to check. Turns out he was mistaken. Told my coils would not be covered. Asked him to check. Turns out it was covered. Quoted $1500 to change that would have been my responsibility had I not insisted. Also unsure if $1500 to change is reasonable. 4. Coincidental additional check engine light issue. I'll keep this concise. As mentioned, the issue was attributed to the 6 ignition coils. Those were replaced and on a test drive, a *NEW* check engine light code came on suggesting a High-Pressure Fuel Pump had gone bad. I asked why it did not trigger before and was told it is just a coincidence that just it went bad and wasn't the cause of the misfires. Found an X5 recall that covers the HPFP but only for the 35i. Still covered under warranty 5. 30% markup on Broken Crank Vent Tubing After fixing the High-Pressure pump, x5 was found to also have a broken Crank Vent Tubing. I can confirm that it wasn't broken before so I asked the cost. The dealer was nice enough not to charge labor for installation . I asked for the price and was told it would be $650. Given the previous shady pricing, I googled the price of the part numbers and found them for sale at various BMWs in the area for below the MSRP of $450. Prices ranged from $430 to $480. I questioned why I was charged $200 over MSRP and was told that the price they quoted was their best price but they could waive $60 off of it. I did the math and realized to have it installed at this time at another dealer would require at least an hour of installation and would be about the same. I accepted the $590 as another dealer said each dealer is free to set their own prices. 6. Poor communication and delays. Dealer did not return call from warranty company which resulted in a delay over the weekend. Service Advisor promises to follow up but I find myself constantly having to reach out to ask for an update when the time passes that I was promised. Spoke to Service Manager, he promised to call me and failed to do so as well. I know my car isn't a 2021 x5 but I expect competent service for the amount of money that I am being charged. 7. My car problem is still unsolved. After all the fixes and unexpected issues. The check engine light on my x5 came back on while the technician was testing it before returning it to me. This occurred today at 2PM and I requested an update before the service center closed. No update was given and at this point, I am truly frustrated as this would be the 4th problem I am being asked to fix on a car that as of last week was running with no signs of problems or issues. Last edited by kevoncox; 11-23-2021 at 07:38 PM.. |
11-23-2021, 07:02 PM | #2 | |
Rep 2,631
11-23-2021, 07:19 PM | #3 |
Rep 138
dealers can be hit or miss. go to another one. I have a friend that used to have a 535 and the dealer said you need to replace all coils, plugs and injectors after a valve cleaning. quoting about $5k.
11-23-2021, 07:40 PM | #4 |
Rep 78
I went to this dealer after another bad dealer experience. Im not even an anal customer. Usually I pay what ever I am told but this was so absurd, it just rubbed me the wrong way.
11-24-2021, 09:33 PM | #5 |
Rep 78
Dealer has gone on to change out last to ignition coils under an extension notice (probably should have changed all 8 but decided to get paid on it). Car returned to me, 5 miles later drivetrain malfunction returns.
11-24-2021, 10:59 PM | #6 |
Rep 24
Very doubtful the HPFP was a coincidence with the misfires. It is true the 50i are known to eat up spark plugs for lunch. You might want to at least get them checked out.
11-26-2021, 11:08 AM | #9 |
Rep 7,484
To the OP…the N63TU engine has extended warranties (10 years/120,000 miles) in regard to the 4 areas listed below. The HPFP for the N63TU has an extended warranty…not just for the F15 X5 35i:
1. Pressure Switch for Leak Diagnosis Module (NVDL)You may need to look into if your issues are from failing fuel injectors or the HPFP. If you are below 120k miles…you may fall under an extended warranty. See the info below which has the SIB (service information bulletin) numbers that your seemingly uninformed dealership is not pulling up. Good luck.
11-26-2021, 03:05 PM | #10 | |
Rep 78
11-27-2021, 08:38 AM | #13 |
Rep 74
Sorry to hear this and I know it's very frustrating and I hope you have a loaner. I get a loaner from Silver Spring for oil changes too and they don't work with 3rd party insurance.
If you want to try something else as plan b approach, you can go to S2 dynamics. Talk to Pat he is the owner. He can also work with your insurance. Good luck and hope everything works out! Last edited by crabapple555; 11-27-2021 at 08:45 AM.. |
kevoncox11.00 |
11-29-2021, 09:25 PM | #15 |
Rep 78
Just got off the phone with the dealer.
They now believe that the issue is leaking intake pipes. They want me to pay $657 to replace (not covered under warranty). Main parts for the repairs are 13717638569 and 13717638568. MSRP $55 each, although MSRP means nothing to these guys as they tried to charge me $200 over MSRP for the charge venting. Asked why this wasn't a known issue all along and was told that it must have happened after they fixed the coils and HPFP. I voiced my concerns that this seems to be a never ending list of things that just *happen* to go wrong after the *correct* problem was fixed and that I believe the previous issues that were addressed and paid for were done so incorrectly. I told them that I would like the labor for the install waived because if this was correctly dx'd the first time, it could have been fixed concurrently. |
11-30-2021, 03:05 PM | #16 | |
Insta~ f10_sapphire
158
Rep 412
Insta ~ f10_shapphire
kevoncox11.00 |
11-30-2021, 06:16 PM | #17 | |
Rep 474
kevoncox11.00 |
11-30-2021, 06:45 PM | #18 | |
Rep 78
12-01-2021, 08:14 AM | #20 |
Rep 78
Picked up car. Drove 5 miles, issue returned. I haven't blown up on anyone and as a result, the pope is considering me for Sainthood.
12-01-2021, 08:48 AM | #21 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Service center at Bmw of Silver Spring is not straight forward to deal with. They will find ways to try to charge you as much as they can. You have to be well prepared (research on prices, look at deals/coupon on their website, etc) to play against them to drive down on prices, EVERY SINGLE TIME.
They wouldn't apply their deals automatically unless you showed them. Either the SA played dumb or they had no idea what's going on. Very different than their online parts department (getbmwparts) which is straight forward and very helpful.
2019 Cayenne Turbo
kevoncox11.00 |
12-01-2021, 10:34 AM | #22 | |
Rep 5,002
Nightmare. Find a good independent. Never look back. |
