      03-20-2023, 08:18 AM   #1
alexvej1
Drives: 2023 BMW X5 45E
Rear differential seal leaking
Hi I have BMW X5 F15 and I found out that rear Drive Axle Shaft Seal a little bit leaking.
I'm DIYer and a lot of maintenance and repair do myself.
I really ask adwise what to do
1 Some people said just put a little beat of AT-205 reseal and forget.
2 I would really prefer to replace the seal .
But I read on Internet you need a special tools and sometimes it disconnect from differential.
If anybody a procedure or preform that work?
Thank you for your help
      03-21-2023, 12:10 PM   #2
Crasherr
Drives: 2018 F15, 2024 G80
Me too. I just got my inspection done today and they showed me that the rear diff has oil all over the outside. Seems to be coming from shaft seal
      03-21-2023, 01:57 PM   #3
corduroy
Drives: '16 X5 xDrive40e (F15)
ah, the rear pinion seal. Soo common on these it seems. Sorry, I never did it myself or know the procedure.
I had mine done under warranty. The shop I go to said mine wasn't serious and would be fine for a little while but eventually it'll need to be replaced. It's like a $15 part and $6-900 in labor or something like that, lol. You can get the tool, I saw it on Amazon for ~$160 (not sure if it's rentable anyplace) and I think it's a 1.5-2.5 hour job (for pros).
      03-21-2023, 10:37 PM   #4
tlow98
Would you mind linking the tool?
      03-24-2023, 08:11 AM   #5
alexvej1
One guy on bimmerfest post specific procedure how to replace seal
I also bought rear axle seal but I'll use A205 fist about 1oz
See my post here which includes procedure as well
https://www.bimmerfest.com/threads/r...#post-13813376
This is also link for seal which I bough from ebay
https://www.ebay.com/itm/36417255871...item54ca60417d
      03-24-2023, 01:38 PM   #6
corduroy
This is the one that I found. I've never used it so I can't be 100% (I *think* this is the tool)
https://www.amazon.com/Front-Cranksh.../dp/B072XJMRRP
      03-25-2023, 01:17 AM   #7
tlow98
Ok, so your engine rear main seal is leaking, NOT your rear axle pinion seal in the differential?
I think there was some confusion in here.
Dropping the trans won’t be much fun…
      08-10-2023, 12:34 PM   #8
SamSmith136
Drives: BMW X6 2018
Could you please let me know the name of local Indy place where you got the work done. I have same issue. BMW registred my car on wrong VIN and gave me wrong warranty exp date, now warranty expired.
      08-11-2023, 10:44 PM   #9
tlow98
I think you meant to link the other person?
      01-26-2024, 07:42 PM   #10
M3HNGRY
Drives: '18 AW X5 35d Msport
Got my rear pinion seal replace under warranty at 45k now I am at 80k with a bad pinion bearing. I would not replace unless it leaking alot...
rear differential leaking
