06-03-2021, 10:11 AM | #1 |
Rep 1,497
CV Axle Boot Replacement
My X5 is at shop and they are saying I have a tear in my front right outer cv boot. He quoted me $30 for the repair kit and $400 in labor Seems very high in labor cost as one of my other mechanic buddies told me it's a 3 hour job. They are also replacing the front right lower forward control arm. Seems as though they could cut me a break in some labor cost since they'll be doing both at the same time. Anyhow, any of you guys had this repair done? This is at an indy shop and not dealership.
06-03-2021, 10:21 AM | #2 |
147
Rep 334
I've rebooted CV axles on my old 06 Tundra to put some "higher angle" boots on. They fail with usage, turning, and stretching as well as the elements. If you've caught it recently, I'd just reboot it and call it a day. If you have any noise coming from the joint its to late and should be replaced. Re-man or aftermarket are $100ish.
$400 labour is nuts. Its really not hard to remove a CV. The rebooting can be messy and a bit of time consuming sure, but its a $20-$30 kit as mentioned and you only need one specific crimp tool for the bands. Depends on the the break down the of labor, how much is rebooting the CV vs the LFCA? Move to remove for sure. I dunno what the shop rate is but I'll assume thats around 4-5 hours of work billed. I agree, assuming the vehicle is in good condition, I'd ballpark that at 3 hours for a good tech doing the work. |
06-03-2021, 11:19 AM | #3 | |
Rep 1,497
06-03-2021, 06:35 PM | #4 |
SPC
7
Rep 73
i am in the same boat. i am getting $450 just labor charges from most places. Only this one place gave me labor charge of $350 but they said i have to get boot kit from them and they are charging 80 dollar for boot. I already have boot kit from fcp euro it was 10 bucks.
06-03-2021, 10:29 PM | #5 |
Rep 5,002
Lots of parts on these cars are less than $20. Almost none of them are cheap to pay someone to replace the item.
I don’t think those mechanics are gouging. A couple hours of shop time is expensive. Unless you find someone on CL to come out and do it for you and then you have no warranty... It seems like anything less than 3 hours is unlikely. I’m guessing yiu won’t be saving much anywhere you turn |
06-04-2021, 08:37 AM | #6 | ||
Rep 1,497
06-04-2021, 09:27 PM | #8 | |
SPC
7
Rep 73
06-05-2021, 07:54 AM | #9 |
Rep 1,497
I wish I was that confident in my DIY skills to pull this off.
I see! See I saw none of that, but mechanic said they must have caught it right after it ripped. I haven't used this shop a lot, so I'm not fully trusting in them. Being a cv boot that you don't see unless the car is on a lift makes this one of the repairs I question if really needs repaired or if I'm just padding the wallet of the shop. Regardless, I paid full price and I'm not happy about it I told the owner the outer cv boot repair is a 3 hour job (as I had my buddy who is a mechanic check) and he hemmed and hawed and said yes but this required some extra work. I looked him in the eyes and could tell he was lying. I paid it but I won't be using this shop again. I had called to talk about the repair and never got a call back. In fact, they close at 5:30 on Fridays and didn't get a call until 5:15 that my car would be ready by 6:00. Also, I had mud all in the wheel wells where they had parked it in their additional gravel parking lot (which had puddles from a lot of rain). Little shit like that sets me off because if it didn't register not to drive my car through a puddle then their attention to detail is shit in my book. Fuk that place! |
06-05-2021, 09:50 AM | #10 |
Rep 182
06-05-2021, 11:31 AM | #11 | |
Rep 95
When you establish loyalty, it's common practice to take care of your customer. Realize, everyone is asking for a discount. |
tlow982188.00 |
06-05-2021, 10:45 PM | #12 | |
Rep 182
06-06-2021, 10:20 AM | #13 | |
Rep 1,497
06-06-2021, 12:10 PM | #14 | |
Rep 182
06-06-2021, 04:38 PM | #15 |
Rep 1,497
06-06-2021, 11:22 PM | #16 |
Rep 628
Turn your wheel all the way to the outside. Should be easy to see then.
Honestly, those prices quoted aren't bad. The shop I was at would have come in similarly and also required parts bought at the shop. It's a huge hassle dealing with customer purchased parts when something fails. BMW repair (any luxury car) is expensive if you're paying others. It's a harsh reality. It's why I do all my own work. If I couldn't work on BMWs, I couldn't afford them. |
06-07-2021, 10:25 AM | #17 | |
Rep 1,497
06-07-2021, 11:11 AM | #18 | |
Rep 628
With shops (stealers too) I try to keep them focused on the actual reason I brought it in. "Hey, I have a creaking sound, please diagnose that." If they come back with anything, "Will that cure my creaking?" If the answer is anything but yes... "Please focus on the creaking, might address the other issues after that is cured if it makes sense to." But, yeah it's always a hassle unless you really know and trust your shop. Finding a good mechanic is as difficult as finding a good dentist or body shop. Once you find one, stick with them, and the more they see you, the rates usually get once you're a "regular." |
M302_imola842.50 |
06-07-2021, 01:58 PM | #19 | |
Rep 1,497
12-25-2021, 08:56 AM | #20 |
Rep 8
I just rebooted my outer CV joint yesterday. I couldn't find a YouTube tutorial for our cars but the E70 is pretty much exactly the same from what I can tell. Was really not that bad, especially if you can get under the car. I recommend taking the entire axle out and putting it in a vice if you can as that makes hammering the outer joint off ten times easier and quicker (helps if you have another person to assist). Also, I used the BMW replacement boot kit which is fine however I tossed out the outer clamp after spending half an hour trying to attach it and used a regular crimp type clamp. The BMW one is like a squeeze type that as far as I can tell requires a special tool...WHY DO YOU DO THIS BMW? Anyways, now that I've done it once I think I could do it in ~2 hours the next time. Would have saved a ton of time if I had removed the entire axle and used a different outer clamp in the first place.
RareForm0.00 |
12-28-2021, 08:14 PM | #21 | |
Rep 1,497
04-29-2022, 03:38 PM | #22 |
Rep 9
Hey all - I see a ton of posts here about doing this repair DIY style, but I haven't read /how/ yet. Yes, I know that unless you've got a split boot you have to take stuff apart, however this is the part that is a mystery to me. I don't feel like blindly whacking on the CV.
I picked up a universal split boot, and the regular old hose clamp it came with was too large to fit inside the knuckle. I've got the Beck Arnley regular boot, but again, I'm having a challenge finding details on the disassembly. I've already had the front end apart once to replace the control arms and strut, and I guess I can do it again if needed. Or, does someone have a good solution for a split boot with better clamps. Last idea, I could take the clamps from my B/A kit and crimp them on the split boot I already have. Car is sitting idle now anyways, waiting on the EGR recall parts. |
