04-30-2022, 03:10 PM | #23 | |
147
Rep 334
A worm clamp style will be far too thick to fit.
What you want are CV boot clamps. Much thinner and use a specific tool to crimp it down and hold it tight while increasing clearance. As for the DIY, here you go. This is for the left, all it says for the right side is that you have to remove the strut before you do the shaft. One sheet is on the rebooting of clamps and the other two are for replacing the CV. Quote:
2015 BMW X5 x35i | M-Sport | Alpine White
05-02-2022, 10:38 AM | #24 | |
Rep 1,497
07-27-2022, 12:14 AM | #25 |
Rep 15
You need a LOT of tools
Just so that everyone is aware,.. you need some pretty expensive tools to do this job. For those of you that have already done it, how did you torque your axle nuts to 315 ft./lb.? That requires a massive 3/4" torque wrench that are several hundred dollars. Your 1/2" torque wrench will NOT do it. Not to mention the 12 point 36mm or whatever socket. How about re-installation of the axle shaft - most require an axle puller (Bav Auto #B8800102) as the fit is VERY tight. Sure, you can use a block of wood and beat the crap out of the axle to get it to go into the hub but then you're playing with fire on your new boot. Of course you'll also need the appropriate extensions and torx sockets as well.
Lets not also forget that you'll need a new axle nut as well that will need to be staked/tabbed once you've torqued it appropriately. Generally, this is done with an air hammer/air chisel. Oh.. if you live in the rust belt then you'll likely also want a gear puller and/or a good air supply behind your air hammer to assist in the removal of the axle from the hub. This is a DIY job IF you have the right tools already. Otherwise, you'll be dumping several hundred dollars into your tool box - and that's buying them at a discounted price from Harbor Freight/Princess Auto. |
07-27-2022, 11:41 AM | #26 | |
Rep 661
You are correct on the cost of tools. And to get that 36mm spline nut, I had to invest in a Milwaukee High Torque Impact Wrench. And instead of running the exact torque to factory spec, I just referenced the opposite side and count the pitch to thread the spline nut in. I have mechanic friends, and they basically said they never followed a factory torque spec when tightening up those spline nuts; they have high powered air tools and they just vroom vroom it in as much as they can get can call it. You're also looking at breaking loose the ball joints from Thrust Arm, Control Arm, and Steering Joint. After everything's loose, you can just hammer-tap the Axle out with a correct pry bar. No need for slide hammer unless it's really jammed or rusted badly. Most of my efforts when I did the job, was spent on getting the CV out of the wheel bearing. Mine's got 185k miles when I was doing it, so it's fused in there quite hard. On passenger side, I ended up using this tool to get the CV loose from wheel bearing hub: https://www.cpooutlets.com/otc-tools.../otcn6980.html When I did mine, I replaced the whole CV axle. If you locate the correct boot, please do share that info. For the life of me, I could never find it. And I'd love to stock a boot or two for the next rainy days. Happy Motoring.
07-27-2022, 12:08 PM | #27 | |
Ground Clearance?
232
Rep 1,651
07-27-2022, 02:47 PM | #28 |
Rep 661
I actually couldn't agree more. Hence, I always advocate to do it yourself or stop complaining.
08-01-2022, 11:11 AM | #29 |
Rep 1,497
Not work for free, but when the book says 3 hours and you're already under there doing a front control arm you typically cut the customer a break on some labor. That and the fact I had spent over $1500 with the shop 2 weeks prior. Doesn't matter, that shop is dead to me now.
