      05-11-2019, 11:14 AM   #1233
Hellrot
241
Drives: 16 M235i
Is there an option to have the iDrive map auto zoom in on a turn as your speed slows. I thought I saw this once but am unable to find it now in BimmerCode?
      05-13-2019, 07:55 PM   #1234
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
2018 BMW M550i  [0.00]
Try: Expert: HU_NBT > 3000 > NAVI_AUTOZOOM > AKTIV
      05-23-2019, 03:24 PM   #1235
ixlr8
Drives: 2016 X5 35i
I was looking for the nav to do the auto zoom and I tried coding that and it didn't work. It was also the first time using Bimmercode so I am not sure if I did it correctly. Some things worked, some didn't and this is one of the ones that didn't. Maybe there is something else that also needs to be coded. IDK
      05-23-2019, 09:13 PM   #1236
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Does not work on NBT.
      05-24-2019, 09:19 AM   #1237
ixlr8
Drives: 2016 X5 35i
Sorry, I have no clue what NBT is.
      05-24-2019, 02:19 PM   #1238
Almaretto
Almaretto's Avatar
2376
Next Best Thing Head Unit. Found on 2014-2016 X5.
2017-2018 got NBT2.
2019 has MGU.
Maverik2594150.50
      05-24-2019, 02:57 PM   #1239
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1255
Drives: 2017 F85 X5M
Idrive Info
Maverik2594150.50
      06-01-2019, 06:37 PM   #1240
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Originally Posted by mrfochon View Post
Originally Posted by lshiroda1 View Post
I can't find the line in expert mode to change color for ambient light. Can anyone give more detailed info ? thx
In BDC - 3070.
Search for ensemble_layer...
if your software is compatible you can change 8 ensemble, 3 layers. Lots of Video online on the topic as well.
I can confirm this worked flawlessly for me, now I'm not sure if it depends on software version as previously mentioned I will post up my version when I get home to confirm. This however took me 30 seconds to code within BimmerCode:
- BDC > Expert Mode > search for line 3070
- Within 3070 > scroll down to the desired Ensamble which will have up to 10 layers below it, F15 utilizes only the first 3
- Example I changed my last 3 Ensembles as I was not using those color patterns, Layer 1 will be top led bar, 2 door handle, 3 lower area AND when I get home I'll also look into the top 2 LEDs in the ceiling panel that fire down that have the ability to change color as well, depending on color pattern, which could be coded as a higher Layer.
- After you select the color desired just code and that's it
Update: Currently on Software 002.255.073, Just checked BMW.com and 003.255.081 is available, contemplating upgrading not sure if I some codes will get relegated..
Update2: Nothing changed after update, all coding as is.
Originally Posted by mpowered5 View Post
Just wanted to confirm it does work. Press the Button and on the bottom of the dash "steering wheel heater activated" and deactivated. Just like every other car does..
I can confirm this steering wheel heater code works as well.
Hey maDjzo your ambient lights looks very bright, brighter then mine, did you code that too?
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      06-01-2019, 10:39 PM   #1241
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
In BDC - 3070.
You can't code brightness. It's probably just the camera.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      06-02-2019, 06:16 AM   #1242
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
In BDC - 3070.
Nope, it's a combination of exposure on my end and also Ivory interior, ambient lighting will always pop more against a lighter surface.
      06-08-2019, 02:00 PM   #1243
MissVito
MissVito's Avatar
218
Drives: '24 X5 M60i, M240ix
Who can code for me in FL?
I'd like some things changed in my '14 X5, such as: close tailgate and/or windows & sunroof w/remote, 4-5 blinks for lane change signal, autofold/open mirrors w/ignition off/on, change ambient lighting choices, and, if possible, turn off turn signal sooner when coming out of a turn (damn thing stays on too long and makes it look like I'm going keep turning).
I'm tech savvy, but I'd rather have an experienced coder do it for me because sometimes what seems simple turns out to be a bigger hassle than anticipated.
Anyone in FL? I almost got the coding app but at the time it didn't seem to do anything worthwhile for my car.
OMT, can the dealer tell if the coding was changed? Does it affect warranties? What about when I sell it? I'll be ordering the 2020. Thanks!
      06-08-2019, 02:10 PM   #1244
MK2018
MK2018's Avatar
231
I just had my 18 F15 at the dealer, they updated software and they didn't say anything about any coding which I had quite few
Current
Past
2016 GMC Yukon SLT
      06-28-2019, 06:11 AM   #1245
GIANITALY
GIANITALY's Avatar
Spain
38
Drives: 2016 X6 M/MPPK
  [0.00]
Can someone send me please the most updated list codes excel ?
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS
RACECHIP XLR
      08-04-2019, 12:28 PM   #1246
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
I have recently got my car back from dealership and they had updated software to TN.003 and noticed all of my MODs were erased. I was able to get almost everything back from via BimmerCode except for 2.
1). Turn off iDrive after engine off, doors open doesn't work. I know have to push the button twice now to completely turn it off.
2). Ambient light, I was able to code it to Dynamic Blue but I do not see Lilac as option. Am I missing something? is Lilac a value? From everything I have read on here and cheat sheet sounded like it's a drop down or select value. Again, I don't see Lilac.
Lastly, any additional update on being able to code Dazzle LED via BimmerCode? easy mode or expert mode?
thank you everyone...
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      08-05-2019, 08:24 AM   #1247
Biggs87
United Kingdom
20
Drives: 2017 BMW X5 40D (F15)
Does anyone know if it's possible to code the ambient lights to be brighter on 2017 X5 F15
      08-05-2019, 12:51 PM   #1248
MK2018
MK2018's Avatar
231
No
Current
Past
2016 GMC Yukon SLT
      08-08-2019, 07:17 AM   #1249
ed116
does anyone know how to code a) eco pro on start up b) sport + on 2015 x5 c) ambient lighting d) auto close mirrors on lock or on/off)
does anyone have the proper posts wihtout having to go through 57 pages? I have BimmerCode with the adapter evreyone recommends off amazon
      08-08-2019, 08:24 AM   #1250
BimmerTy
///M
BimmerTy's Avatar
Drives: 2015 F15 X5 50i M Sport
I coded d) with bimmercode app. You have to change the amount of time the lock button is held down to the minimum.
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
      08-09-2019, 12:26 AM   #1251
Almaretto
Almaretto's Avatar
2376
a) https://f15.bimmerpost.com/forums/sh...postcount=2373
b) I have done with E-sys VO coding. Never tried FDL code.
c) https://f15.bimmerpost.com/forums/sh...&postcount=206
d) One of options listed in BDC.
      08-20-2019, 01:45 PM   #1252
MizikeTSK
Drives: 2015 XDrive 50i MSport
Is there a list of what can't be coded on NBT with latest Firmware? I know so far that the 3x blinker is one of them. I don't want to waste money on the app and BT adapter if I can't code what I want.
2015 F15 XDrive 50i MSport
      08-20-2019, 03:10 PM   #1253
CatalinP
Drives: BMW X5 F15 2014 3.0xd
5x blinker maybe... 3x is the default setting.
      08-20-2019, 04:42 PM   #1254
MizikeTSK
Yeah, sorry that's what I meant. I 5x blinker was one of the options I wanted to enable but now can't because of firmware. A list of other options I want are and hope not affected by latest firmware.
Trunk open/release from cabin and fob
"M Sport" Start up splash
Warning message delete at start up
Video in Motion/USB
Disable Fog Light when turning
Puddle lights in reverse
maybe a few others. I'm not planning on going crazy with it so Don't need the E-Sys option.
