11-21-2018, 05:19 PM | #4577 | |
Rep 8,364
Make sure to unpair and repair devices. In Bluetooth configuration there are two menus. One for labeling phone 1 or 2. Another for functions like office, media, etc. |
11-22-2018, 06:52 PM | #4578 | ||
Rep 627
Drives: X5 F15 M package
And office does not show any sms or email. Any suggestion ? |
11-23-2018, 02:58 PM | #4580 | |||
Rep 627
Email have not shown up. That being said I have thousands of unread email and phone is not counting anymore... joys of iOS. Still waiting to see any calendar alert. Have not done the 6NS since I am on Mac and VM does not run launcher premium. If anyone have had success there will be glad to get help. Even in person, drinks on me Stay tuned. |
11-23-2018, 06:36 PM | #4581 | |
Rep 8,364
11-24-2018, 12:57 PM | #4582 |
Rep 147
Jg425
I was looking through the expert settings in the headunit portion. HU_NBT 3000 HMI would changing any of the three below to Aktiv allow sport+ to be activated 1) traction control 2) M-vehicle 3) M- drive systems What are your thoughts? I am new to coding so don’t feel too comfortable making too many changes. |
11-24-2018, 01:14 PM | #4583 | |
Rep 45
11-27-2018, 10:55 AM | #4584 |
Rep 21
Wondering if anyone could clarify for me how to code/enable BT audio streaming?
I've added/enabled enhanced BT 6NS, that part seems to work fine (phone popped up asking for message access, etc). And I see that the option for BT streaming is now available. But my phone doesn't show the media profile so streaming doesn't work. I have disconnected and removed the BT profile from the phone and car and reconnected so it's not that. Is there maybe something else I need to enable in coding? Thanks! |
11-28-2018, 07:10 AM | #4585 | |
Rep 213
Drives: 2019 X3 m40i
Enhanced Bluetooth (6NS): Add 6NS to your FA. VO Code HU_NBT. Then follow these steps after for your iPhone to pair properly (thank you @skalberti): Then you have to remove all bluetooth devices and re add them. And then configure them like Shawn said. Now for text messages to show up, go to the bluetooth menu on your phone, look for your last 5 of your vin. Hit info incon on the right. Check and make sure "show notifications" and "sync contacts" are checked on. Now whenever you're in your car and someone texts you an envelope icon will appear on your idrive. Now you can use Siri hands free and ask her to read your new texts. Then she'll give you the option to reply if you want. To get emails to show up, after your in your car and the phone is connected, double tap the home button and close the mail app that's running in the background. If it's not running in the background go ahead and click on the mail app after your phone has connected to your car. Now emails will show up and they can be read to you. Keep in mind, the idrive will only alert you of messages received while connect to your car. If you received a message before you get in your car, it won't display it after you connect to your car. Also, if you're having issues with Phone 2 not showing up, try this: "Options-scroll down-Configure bluetooth, and tick Telephone 2 and Office. You can then assign the 1 or 2 to each paired telephone." For anyone who loses their OFFICE menu in your iDrive, go to HU_NBT / MACRO_PIM / make sure it is set to aktiv. @abhiku's for some reason got deactivated (not sure what happened or how), but it needs to be aktiv for the OFFICE menu to show. If for some reason, your OFFICE is having issues, make sure all the ones in HU_NBT below are set to aktiv - this will give you the full functionality to make your OFFICE (6NS) to work correctly: EMAIL_EIN_AUS SMS_EIN_AUS CONTACTS_EIN_AUS CALENDAR_EIN_AUS TEXT_NOTES_EIN_AUS AUDIO_NOTES_EIN_AUS REMINDER_EIN_AUS TASK_EIN_AUS PIM_BILDER_EIN_AUS REMINDER_TRIGGERS_EIN_AUS MACRO_PIM |
11-28-2018, 07:43 AM | #4586 |
Rep 100
Is it possible with Bimmercode to add the fuel gauge as shown below the speedometer in the following link for a 2015 cluster? Mainly the digital gauge at the bottom is what I would like to equal the look opposite the tach.
https://proxy.duckduckgo.com/iu/?u=h...pid%3D15.1&f=1 |
11-30-2018, 04:35 AM | #4587 |
Rep 147
Where can I find what specific codes actually do. These specifically found in expert mode in HU_NBT:
1) traction control 2) M-vehicle 3) M- drive systems Any help or info would be appreciated. Thanks I have been trying to get sport+ to work. It shows on the dash but can not be selected. I was hoping that someone who is more knowledgeable with coding would know what these codes mean and perhaps be the missing link that allows sport+ to be selected. Sport+ seems to be available on M models so I thought one of these may work but would like some advice before I try. Last edited by Jason73; 11-30-2018 at 05:20 AM.. |
12-07-2018, 02:39 PM | #4588 | |
Rep 21
12-08-2018, 04:06 PM | #4590 |
Rep 2
coding questions
I would first like to say thank you to all those that have contributed to this thread! I have been reading it over the years and trying to follow along with all the detailed instructions. I now have a few questions that I'm hoping someone could help me answer.
I am using e-sys 3.28.1 and psdzdata 4.15.12. I patched the jre folder with the jre8. I have a 2014 F15 diesel with Xenon lights and adaptive lights (522 and 524). I have surround cameras 5DL which includes a front camera. I do not have KAFAS in my ECU. 1) I wanted to see if I could add VLD, NGHB, and or HBA. I followed the directions for NGHB. I did not have 5AC or 5AP. I removed 8S4. When it came time to VO code, I did so for BDC_BODY, HU_NBT, and both TMS. I did not have KAFAS, FLA, or LHM. I then FDL coded: LUT_FLC_FORWARDLIGHTING_Y C_AFS_ENA to turn on VLD and tried to turn on HBA. It used to show up under 'lighting' in my settings but not sure if it ever worked. My question is, I know I can probably just get VLD enabled based on my hardware right? Will HBA work with the front facing camera or does it need the KAFAS camera which I don't think I have. Since I do not have options for FLA or LHM, NGHB will not work correct? 2) I used to tinker with the ambient light colors: GROUP_0_FARBE_ENSEMBLE_1 now the values just say 'unknown' instead of the color names for all in this group. I initially thought this may be an issue with psdzdata but i am using the most current version I believe. Any thoughts? Sorry for the noob questions! Last edited by eudaxia; 12-08-2018 at 10:57 PM.. |
12-09-2018, 06:34 AM | #4591 | ||
Rep 648
Drives: 2016 F15, 2015 F83
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 12-09-2018 at 08:58 PM.. |
12-09-2018, 07:32 AM | #4592 |
Rep 627
Even for 2015? Read somewhere it will work on 2015 not on newer cars.
But glad to be corrected. |
12-09-2018, 07:53 AM | #4593 |
Rep 43
Hello everyone, I have recently started coding my F15 M50D eu spec 2014. I have several questions: 1. I have coded all the cameras sections while driving. Is it possible for the rear view camera to turn off automatically when driving forward, with the option of turning the rear view camera on by pressing the PDC button while driving? 2. Is it possible to extend the display time of the M50D emblem on the kombi hud (I have 6WB)? I tried via D_Kombi HUD_STARTUP_TIME but without any success. 3. I have adaptive LED headlights, anti dizzle on. I turn right and you can see how the whole stream of light turns to the right, when I turn left, the stream "stands" in the middle and only the "illuminate the left side" turns on or is it normal? Thank you for your response.
12-09-2018, 07:57 AM | #4594 |
Rep 21
12-09-2018, 11:04 AM | #4595 |
Rep 32
I bought a Virginized 6wa cluster from eBay. I tried to get it coded to my f15 but the coder could not get rid of the check engine light. We got an error saying he couldn't connect (see pic for code error)
Does any one know what this error could be? The coder thinks the 6wa was not Virginized properly. Side note he did get it connected as a 6wb. Also of the features work but he couldn't get the headuinit to talk to cluster so he couldn't clear the check engine light. Someone please help! |
12-09-2018, 06:52 PM | #4596 | |
Rep 8,364
12-11-2018, 02:31 AM | #4597 | |
Rep 43
12-11-2018, 11:14 PM | #4598 |
Rep 8,364
