06-04-2019, 06:16 PM | #4819 |
Rep 40,951
PM sent.
06-06-2019, 04:11 PM | #4820 | |
Rep 213
Help with issue
I'm trying to remove SAT from X3, and I get this error when I try to VO code, and even FDL code certain folders. Basically, the two I'm supposed to code keep giving me the error. I can code other folders except for the ICM and EGS...See picture for detail. |
06-06-2019, 07:33 PM | #4821 | |
Rep 40,951
06-06-2019, 11:31 PM | #4822 | ||
Rep 213
06-08-2019, 12:23 AM | #4824 |
231
Rep 369
If you want to change colours you have to use expert mode
Current
06-08-2019, 05:16 AM | #4825 |
Rep 11
hello, I am new member. I installed E-SYS 3.27.1 on my computer, which version of E-SYS launcher pro can i use and where can i find a FreeToken.est and pin. In addition to the above, I still have to install any programs on my computer before I can do Coding. thank you so much
06-08-2019, 11:55 AM | #4826 | |
Rep 40,951
06-09-2019, 01:39 PM | #4827 |
Rep 592
Using the bimmercode app over Bluetooth obd2 and changing the ambient color coding in expert mode..
I go from frint control module to what...is there any walkthrough on this using the app? |
06-10-2019, 01:45 PM | #4828 |
"Salud"
13923
Rep 4,686
Drives: F01 & F15 / Mineral White
Just wanted to chime in say that I got my X5 coded Saturday with damn near everything. Amazing!
Also, I have all the ambient light colors available now. It doesn't show all the colors in iDrive but I have Purple, Pink, Green, Yellow, etc. |
BimmerTy192.50 |
06-10-2019, 08:44 PM | #4830 |
231
Rep 369
I have successfully changed colours with BimmerCode
Current
06-11-2019, 05:41 AM | #4831 |
Rep 26
Drives: mini
esys, Adding to VO without launcher
Hi
This may be in the thread but its a lot of reading now. I've just reinstalled esys V 3.27.1 with PSDZ data 4.17.13as per the installation instructions pdf. However i will not be doing any FDL coding through esys as i have bimmercode on my phone for that. All i need to do is save my factory data and thren add 6NS and 3AG to my VO, I was just about to do this when i read at the end of the instructions NOT to open esys without going through the launcher(which i havent installed due to the token problems and the fact i wont be coding FDL's). So my question is is it okay to use esys for saving my factory VO and SVT settings before adding 6NS and 3AG and then saving a copy of the new VO. I will then tweak the otherbits via bimmercode. Thanks in advance. |
06-11-2019, 03:18 PM | #4832 |
Rep 29
I'm having trouble getting my reverse camera installation working, I have added the 3AG to the VO and activated all the reverse camera functions in the HU, but still no luck.
When I select reverse I get the right layout but no picture and no possibility to adjust the camera settings! Any ideas? |
06-12-2019, 02:19 AM | #4833 | |
Rep 481
If camera works only for one second, code the FDL value in navi module: VIDEO_WATCHDOG_REARIEW to nicht_aktiv Might work for you as well. |
06-12-2019, 03:45 AM | #4834 |
Rep 26
Drives: mini
Camera Install
Hi, Ive not got that far yet, started the install yesterday but got rained off by the great British summer weather.. all back end done just to sort the dash side out. I have read somewhere that some of the BMW retrofit kits were supplied with crossed wires in either the can or hbas lines(cant remember which) and swapping them over sorted out the issue which was similar to yours. I think it was on an X3 thread somewhere. So double check connections end to end.
06-12-2019, 04:14 AM | #4835 |
Rep 481
So the tokenmaster gave sign of life. Now I was using Launcher premium 2.8.2.155 with rearm script, but should I switch over to the new (free) Launcher PRO 2.8.2? What is the difference or what is better? Would the PRO version still need the date fix and rearm script?
http://tokenmaster.blogspot.com/ |
06-12-2019, 04:43 AM | #4836 | |
Rep 111
06-12-2019, 01:39 PM | #4837 |
Rep 19
06-12-2019, 01:47 PM | #4838 |
Rep 40,951
PM sent.
06-12-2019, 02:32 PM | #4839 | ||
Rep 29
Any other ideas? When I select the camera I get the option, but when I try to adjust contrast or brightness nothing happens I have no option. I have coded all I could find with the text camera, do I need to add or code any other cafd files? |
06-16-2019, 07:43 AM | #4840 |
Rep 26
Drives: mini
Camer
Hi Albec
Did you buy the genuine kit from BMW? If not have you put a 120 ohm resistor accross the can line on the camera side. |
