07-17-2018, 11:23 AM | #749 |
Rep 132
So it's kind of closer to a BRZ than a old day supra
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold) 2018 BMW M2 LCI (current) |
07-17-2018, 11:33 AM | #750 |
Rep 9,160
Well it's six inches longer than the four seat BRZ and four inches shorter than a four seat Mk4. So really, it's just more of a two seater Mk4.
07-17-2018, 12:16 PM | #751 |
Rep 1,702
PER: Carscoops
https://www.carscoops.com/2018/07/20...r-engine-well/ "After discovering a document from German transmission manufacturer ZF that showed that the A90 Supra will be powered by not one but two engine options, Road & Track got a confirmation from none other than Supra chief engineer Tetsuya Tada that this is indeed happening. The document revealed that the lowered-powered version of the 2019 Toyota A90 Supra will use the BMW-sourced turbocharged 2.0-liter four-cylinder B48B20 engine producing 262hp. The six-cylinder version is packing the single-turbo 3.0-liter B58B30 unit with 335hp. Both variants will be paired to an eight-speed automatic transmission, at least according to the discovered document. Tada elaborated on the four-cylinder Supra, saying that it will be lighter and with much better weight distribution and a sharper-feeling turn-in. The Supra’s chief engineer also added that, for customers planning to swap in a 2JZ engine, “please buy the four-cylinder. It will be cheaper.”" |
07-17-2018, 12:23 PM | #752 |
Rep 9,160
That would seem to ignore any iron block talk. I wonder if Toyota will follow BMW's model of offering smaller brakes and possibly a weaker transmission in the four banger, or if the only difference will be the motor.
07-17-2018, 12:48 PM | #753 | |
Rep 2,335
07-17-2018, 12:50 PM | #754 | |
Rep 2,335
Toyota Is Benchmarking the Supra Against the Porsche Cayman
420Coupe222.50 |
07-17-2018, 12:50 PM | #755 |
Rep 443
i would think that would be the Z06 version; even then though i would think low 100s.
07-17-2018, 12:53 PM | #756 | ||
Rep 9,160
Further, with all the patent data floating around for six cylinder C8's it would seem that they could offer one at a pretty cheap price point while leaving the Zora plenty of room at the top. Since the C7 is pretty long in the tooth, it would seem like we'd have seen a C9, or whatever, front engine replacement at least once if the C8 wasn't just going to supersede it. Either way, 335hp and 3,200lbs isn't going to get it done against a Cayman or a Corvette. |
07-17-2018, 12:58 PM | #757 |
Rep 2,335
All I know is that C7 isn't even all that old. Your typical Corvette has like a more or less 8 year life-cycle. The C7 is only reaching half of that and supposedly the "mid engine Corvette will debut next year at Detroit. So imo this also adds on to some of the report that this car is not replacing the front engine Corevtte, but instead will be a new separate model and become Chevy's new flagship.
07-17-2018, 12:59 PM | #758 |
Rep 1,930
Great now there is a bmw 4 cylinder option on the new supra. The Japanese sport car glory days are over(gtr needs a refresh). The domestics seems to be stepping it up more with "fun cars"
07-17-2018, 01:00 PM | #759 |
Rep 2,335
07-17-2018, 01:05 PM | #760 |
Rep 2,335
Dimensions
A90 Wheelbase 2,470 mm (97.2 in) Length 4380 mm (172.4 in) Width 1855 mm (73 in) Height 1,290 mm (50.8 in) A80 Wheelbase 2,550 mm (100.4 in) Length 4,515 mm (177.8 in) Width 1,811 mm (71.3 in) Height 1,265 mm (49.8 in) Differences Wheelbase -80 mm (-3.2 in) Length -135 mm (-5.4 in) Width +44mm (+1.7 in) Height +25 mm (+1 in) G29 Z4 Wheelbase: 2,470 mm (97.2 in) Length: 4,320 mm (170.1 in) Width: 1,861 mm (73.3 in) Height: 1,303 mm (51.3 in) Differences Wheelbase: None Supra = Z4 Length: 60 mm (2.3 in) Supra+ Width: 6 mm (.3 in) Z4+ Height: 13 mm (.5 in) Z4+ |
07-17-2018, 01:07 PM | #761 | |
Rep 9,160
But more realistically, power will be higher than stated, as that's just the nature of German turbo mills. 718s is 350/3150. |
07-17-2018, 01:10 PM | #762 | |
Rep 2,335
So the same as the Cayman S, but like $10k-$15k cheaper. |
07-17-2018, 01:13 PM | #763 | |
Rep 9,160
07-17-2018, 01:15 PM | #765 | |
Rep 2,335
Five Generations Of Toyota Supra Together For The First Time
http://media.toyota.co.uk/2018/07/fi...he-first-time/
420Coupe222.50 |
07-17-2018, 01:21 PM | #766 | |
Rep 2,335
EDWYER1675.00 |
07-17-2018, 01:22 PM | #767 |
Rep 9,160
Assuming either of us will live to see that day.
And I can see a low spec, JP model with a liter of gas in the tank weighing that little, bit doubt a US spec one will come in anywhere near that weight. I'd love to be wrong, but with BMW listing weight of a soft top Z4 at over 3,300, I just don't see it happening. |
07-17-2018, 01:28 PM | #768 | |
Rep 2,335
That's the thing, Moto has said this car is just not a reskin Z4. His comments were "the unibody is very different from a Z4 and is significantly lighter." |
07-17-2018, 01:31 PM | #769 | |
Rep 2,335
1. Hardtop 2. Less weight 3. Cheaper MSRP as hinted by even this forum's insider and mod. 4. Some people may like the styling over the Z4. Different strokes for different folks. |
EDWYER1675.00 |
