      04-06-2016, 05:43 PM   #1
taken
Drives: 2016 X5 xDrive50i
Installed JL Sub/Amp Today
I had my shop install a new JL ProWedge CS110LG-TW3 today along with a JL XD 600 amp I had in my last SUV. The amp was mounted right under the OEM amp which made it easy to tap the factory sub feeds for signal. To secure the box to the driver side trim, I had them use flat stock and carpet it. Then I supplied a ceiling flange painted black, a piece of 3/8" threaded rod, and a black metal knob. (Cost about $8 on Amazon...) So, instead of it being permanently secured, the knob can be screwed off and the box moved to gain access to the spare tire and batteries. Lastly, I had them install my amp's remote control knob in the dash under the ignition. Came out very clean and I can't believe something less than 5" deep can put out this kind of sound. Simply amazing upgrade to the factory system.
Regards, Rodney
2016 X5 xDrive50i
Appreciate 6
      04-06-2016, 06:14 PM   #2
aw305
aw305's Avatar
Drives: F97 X3MC Alpine White
How does it sound? No signal processor needed?
      04-06-2016, 06:18 PM   #3
taken
Sounds AMAZING. No signal processor needed at all. Just a simple PAC lineout converter. I can't believe how well it fills all the gaps in the factory system. And, with the remote control knob I can tailor it to any source as they all need different amounts of gain.
Regards, Rodney
2016 X5 xDrive50i
      04-06-2016, 06:41 PM   #4
Mexecutioner
Drives: 2015 X5 xDrive35i
looks pretty cool, I've been thinking about adding something like this for additional bass extension.
      04-06-2016, 06:43 PM   #5
taken
Thanks, I was really hoping for a hidden option but it seems impossible. Every hidden space on these vehicles is full. I did read here where a member had an installer do the previous generation JL StealthBox in an F15. They had to relocate the accessory battery and downsize it to fit it's new home along with grinding out all it's mounts. Not what I wanted to do in a brand new car. So, I sucked it up and lost my 5" of cargo space to keep the project from going nuclear...
Regards, Rodney
2016 X5 xDrive50i
      04-06-2016, 06:50 PM   #6
Mexecutioner
It is a great approach, and if you ever need to haul something big you can easily remove it. The knob idea is genius!
      04-06-2016, 06:52 PM   #7
taken
Thanks again! The install was the dealer. The knob was all me...
Regards, Rodney
2016 X5 xDrive50i
      04-06-2016, 07:44 PM   #8
bjcarls
Drives: 22 Tahoe, 22 R1S, 23 Z07
Anyone use the spare tire space?
      04-07-2016, 07:24 AM   #9
taken
I posted my thread on the other forum too and a member there did just that. See post #6 in this thread.
http://www.bimmerfest.com/forums/sho...d.php?t=906192
Regards, Rodney
2016 X5 xDrive50i
      04-10-2016, 12:43 AM   #10
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
i gotta say that's a clean setup and what's cool is it can removed effortlessly
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      04-10-2016, 06:33 AM   #11
taken
Thanks much! I don't anticipate removing it often but if I get a flat and need to get to my spare, it's a twist of a knob. The installer was going to use to screws to secure the strap to the box before I came up with the knob idea. Sure I could keep a Phillips head screw driver in the car to do this but for $6 in parts, I think this was the better setup...
Regards, Rodney
2016 X5 xDrive50i
      04-10-2016, 08:42 AM   #12
Terp335
116
Drives: E90 2011 335i M Sport
I agree. Nice looking project.
      04-19-2016, 02:42 PM   #13
spike5150
Drives: 2020 X5 M50i
having one installed today - looking forward to better sound on the low end.
      11-06-2018, 09:38 PM   #14
Alos
Drives: X5M competition
Have any of you mounted it in the spar tire space and than closed the cover? Does it mufffle the sound ? Or just as good ? I was gonna do amp rack and 12 in jl micro box in the spar well ? But depending On doing what he did above just don’t want to loss trunk space? Any ideas or what have others done. I really don’t want to cut any holes in the initial factory floor
      11-17-2018, 06:50 PM   #15
Alos
Thanks for all your help guys. Got it all done with the main power control and bass control knob perfectly placed.
Wavy1175.50
      03-09-2019, 06:20 AM   #16
desertfox73
676
Drives: 2018 F83 / 2018 F85
How does it sound? Is it muffled with the bass coming from under the cargo cover?
      03-09-2019, 09:28 AM   #17
Alos
Sounds great no issues.
      03-09-2019, 10:05 AM   #18
trlengle
Drives: 2016 X5 50i MSport White
Yup. I used spare tire space. Fully concealed and sounds great. I used a 12" sub with knob.
2016 X5 50i MSport in White
Dinan Powered
AC Schnitzer Springs
22" Varro VD01 Wheels
iND Black Emblems and Badge
      03-10-2019, 01:29 AM   #19
hufington
hufington's Avatar
3121
Drives: 2022 X5 m50i
Looks great.
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      03-10-2019, 09:09 AM   #20
Eurogreek
Drives: BMW X5 3.5
What did the setup cost to do this for both of you? I’m really leaning on doing this in the spare tire area but really worried about the vibration of the cover over it. I had a local shop quote me $2200 for the amp, sub like this, bass knob, instal.
      03-10-2019, 08:18 PM   #21
Alos
Shop around and do your research. The install cost me around 250 and that's with high gauge wiring. The amp I looked on Facebook marketplace and someone was selling brand new with high discount same with sub. I ordered the jl knob from crutchfield. The harness I got with the Loc from technicpnp. I think all in all little over 900. And you don't really get much vibration from cover there is enough space between cover and sub with grill. I have a 12" as well.
      10-26-2020, 06:52 PM   #22
SupersixM
SupersixM's Avatar
202
Drives: Bmw X6M
Old thread, but when you installed the JL amp, did you have to move the other oem amo or readjust it in anyway? I got the same set up you have siting around for years brand new and I'm thinking of installing it.
