09-05-2014, 10:37 PM | #2 | |
Rep 3,990
LED: 1) You can code a lot of settings with these lights: a) anti-dazzle (recently figured out by skalberti 100%/deeply discussed between myself and other knowledgeable members) b) coding brightness of HALOS c) some nifty features for cornering lights and and high beam low beam timing changes figured out by CatFlap. 2) The turn signal is the eyebrow - it is a switchback LED that shifts from the LED white (solid) to LED amber (blinking). 3) LED has a deeper field of vision. Bi-Xenon: 1) No coding except for having the fogs on with the high beams from everything we have all tried in regards to LED coding. 2) Turn signals have individual halogen bulbs in the corners (I changed mine to WeissLicht Spektrum LED amber bulbs and coded the startup burnt bulb test off to eliminate flickering). The LED eyebrow is just solid white LED that does not change. I'm sure with coding and some modification, someone could change this to act like the LED lights, but no one has yet. 3) Bi-Xenon are very bright and give a broader field especially peripherally from the many discussions in these forums. That's what it seems like. I'm sure others can add more since I know I probably missed a few things .
09-05-2014, 10:52 PM | #4 |
Rep 3,990
No problem.
Bi-Xenon: notice the full round bi-xenon (one left one right) and the corner turn signal amber halogen bulbs. LED: notice how the high beam and low beam are split in half and no corner turn signal amber bulbs.
09-06-2014, 01:58 AM | #5 |
Rep 1,133
I got a chance to shoot some GoPro video comparing my 2014 535 and 2015 X5, both with LED headlights. My car seems to perform better than the X5. I'm gonna have to dig a little deeper on this. In the second video (the X5) its putting too much light on my 535 in front. My wife was driving and she said that if the windows weren't so tinted that it would have blinded her. The black box doesn't seem to appear as well as my 535
535 X5 |
09-06-2014, 02:28 AM | #6 | |
Rep 3,990
1) It could be because the F15 LED's are brighter/newer/stronger that they could be emitting it in this way perhaps? 2) Maybe because the X5 is just that much taller that the pattern is like this? However, as far as technology is concerned, the X5 should be adapting to the above scenarios accordingly and not blind anyone in front the way it still seems to be doing in your videos. So, I assume the VO coding you did did not work? Thanks for making these videos .
09-06-2014, 11:31 AM | #7 | |
Rep 1,133
Well you have a point about the height of the lights. My 535 is only 10 months old, so I don't feel like there's a brightness difference between the two. When I was following the X5 in my 535, notice when I passed my wife the right headlight shut down. Then after I passed her you could see the headlights moving pretty well for the oncoming cars. I'm just wondering if I'm missing something new that needs to be coded that wasn't needed on my 5? We need to get some others with the F15 to post their videos for comparison. Thanks for taking the time to watch those long boring videos! |
09-06-2014, 01:00 PM | #8 | |
Rep 3,990
I really wish someone would chime in with more info because it seems like a lot of people are coding this into their cars but not providing any feedback. ljx*****n said that it was working on his, but I don't know if it's working 100% after your videos.
09-06-2014, 02:57 PM | #9 | |
Rep 1,133
Ya go to 4:10 in the 535 video. After I pass my wife you can see how much the lights moves as I approach oncoming cars. I went ahead and posted in the bimmerfest coding forums asking for people to watch the videos and compare to how their lights are working. Hopefully some others will post videos for comparison. http://www.bimmerfest.com/forums/sho...d.php?t=795160 |
09-06-2014, 03:16 PM | #10 | |
Rep 3,990
09-08-2014, 11:03 AM | #11 |
Rep 424
European (UK) LED's in Action
Made a series of videos in my X5 traveling across country to London early this morning. I have a new HD camcorder and had the settings on 1080p HD so have had to reduce the quality somewhat to make the file size a bit more reasonable. You can clearly see the active element of the headlights in action.
This is my first attempt at down-converting the AVHCD video files - let me know if it's OK and i'll post more! I eventually catch up with a truck about 1 minute in...you'll see the anti-dazzle working then. https://www.dropbox.com/s/efyfe742hf...D%27s.mp4?dl=0
X5 F15 - gone after 5 months!
09-08-2014, 11:27 AM | #12 | |
Rep 424
https://www.dropbox.com/s/ct88fwnowu...s%202.mp4?dl=0
09-08-2014, 11:30 AM | #13 | |
Rep 1,744
09-08-2014, 11:49 AM | #14 | |
Rep 1,886
09-08-2014, 11:57 AM | #15 | |
Rep 1,886
Bottom line: rear amber turn signal/blinker/indicator is safer, there is no DOT rule/regulation that bans this.
09-08-2014, 12:05 PM | #16 | |
Rep 1,744
09-08-2014, 12:57 PM | #18 |
Rep 424
Thanks, will post more soon!
09-08-2014, 01:15 PM | #19 |
Rep 1,886
In front, they run white as daytime lights, and blink amber. Sorry for not clarifying that before.
09-08-2014, 01:22 PM | #20 |
Rep 2,091
So at the end of the day, if I am not planning on doing any sort of coding, is it worth spending the $1900 extra for the lighting package versus staying with the standard bi-xenon? I really don't care all that much about the LED front turn signal at this point as I have my toy car and don't want to tinker with the X5 at all. I pretty much have settled on my final build and just trying to figure out if I should go with the LED or not.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
09-08-2014, 01:28 PM | #21 | |
Rep 1,744
Edit, it looks like F15 has a tiny amber bulb at the edge, I think these are normal xenons, not LEDs, right: DRL: Driving Lights/Low Beams with amber indicators available, much more subtle compared to E70 which had a super big ugly amber at corners: |
09-08-2014, 02:07 PM | #22 |
Rep 1,886
Golden Horn, hmmm mine with LED is returned and a replacement is not arriving for another four weeks. Meanwhile, it looks like all white with daylight running and tiny amber with low beams on:
All white: All White with S. Carolina plates and from 3:40 to 4:20 here All white in Motor Week review from 0:50 to 1:15 but you see the amber at 2:23. It looks like a tiny amber lights up with low beams, but not with daylight driving. At 3:15 low beams are off, day light is white, and no amber. |
