09-10-2014, 09:03 AM | #1 |
Rep 28
Factory 20" wheels and tires? Rotate?
Are the factory 20" wheels and tires uni-directional? Can you at least rotate the backs from side to side. I know they are larger rear so rotating to front is out of the question.
09-10-2014, 12:02 PM | #4 |
Rep 28
09-10-2014, 12:08 PM | #5 |
Rep 18,715
If you are running staggered setup, you don't need to rotate them.
If you are not on staggered setup, then, yes, you can rotate them. Make sure you are following the tire spec whether it is directional or not.
09-10-2014, 01:48 PM | #6 |
Rep 28
Rotate
Factory 20's are staggered I believe which means no rotation?????????
09-10-2014, 01:48 PM | #7 |
Rep 18,715
Correct.
09-10-2014, 01:52 PM | #8 |
Rep 3,307
Holy question marks batman. Give people more than a couple of hours reply..
Is there any advantage to rotating side to side? Front to back (when not staggered) I get, weight distribution and all that. But does it really matter going from side to side if they're both on the back? I'm not sure it's necessary. But I'll check our tires later. |
09-10-2014, 02:46 PM | #9 | |
Rep 132
2015 X5 xDrive 35d Luxury Line
2012 X5 xDrive 35i Premium - Retired |
