04-17-2016, 10:45 AM | #1 |
Rep 106
Mirror dip on when selecting reverse
Anyone know if you can alter where the mirror sets to when you select reverse gear?
I find it dips a little too far for me as I'm 6'5". I want to see more of the road behind me and less of my 469M's! It's a nice function but i find myslef slipping down in the seat whilst reversing to get a better view of where im heading. And No I dont have the rear view camera option as I hate using camera's! |
04-17-2016, 12:27 PM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
Just to add to the original question... does anyone know if you can make both sides dip? I became very used to this on my RR-SC and really utilize the feature.
04-17-2016, 01:57 PM | #3 |
Rep 5,066
Passenger side tilts down based on how you set up the mirror at default.
Driver side mirrors do not tilt down. The idea is that ( in the USA ) cars usually parallel park on the right hand side, thus only the right side tilts. Not sure if it can be coded or not though.
04-17-2016, 04:24 PM | #4 | |
Rep 106
04-17-2016, 05:22 PM | #5 |
7266
Rep 6,561
one way streets, parking lots, narrow driveways, garages, etc. all places the driver's dip comes in handy.
04-17-2016, 05:52 PM | #6 |
Rep 774
04-17-2016, 06:52 PM | #7 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Or just change your back up camera view to top view
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
04-17-2016, 07:53 PM | #8 |
Rep 38
Passenger mirror tilt in reverse is set to a default angle which can be coded from what I've researched.
BDC_BODY Module: 3110 > ASP_BORDSTEINAUTOMATIK_DELTA I've seen ppl say their factory default is set to 3B which is roughly 54 degrees and I've read that changing it to 4B sets it at roughly 75 degrees. With that info I'm guessing there would be a 2B which would reduce the angel it lowers. Give that a try and see if that resolves your issue. UPDATE: Just tested it and it works. Default was at Werte 3B. At 4B it increases the amount it tilts in comparison to 3B and set to 2B it decreases the tilt amount. Based on what you're suggesting with having to hunch down to get a better view, you'll want to try setting it to 2B. I didn't bother setting it to 1B to see if that does anything, but if you have time you may as well give it a try. Last edited by kryptik.m5; 04-17-2016 at 08:23 PM.. Reason: Update |
04-17-2016, 09:00 PM | #9 |
Rep 5,066
And I think thats where BMW said... use the top view or surround view cameras
04-18-2016, 01:13 AM | #10 | |
Rep 106
04-18-2016, 02:24 AM | #11 |
Rep 289
I fully agree! it tillts toooooo much on reversve, far more than previous E70 did.
(I am also quiet tall - 6,4") only need to find a coder here |
04-18-2016, 04:31 AM | #12 |
Rep 144
no need to code. when this happens, i just switch the button that controls which mirror i want to adjust, on drivers left side.
after i move the button to the other side, the right mirror doesnt fold down in reverse. dont know if its supposed to be like this or if its a glitch... |
04-18-2016, 04:45 AM | #13 | |
Rep 289
the point here is, that some of us want this feature and use this feature. but on this F15 the reverse angle tillt is badly set, too much........... |
04-19-2016, 08:04 AM | #14 |
7266
Rep 6,561
unfortunately with park assist the default view cannot be saved as top view so you parking becomes more of a chore than it should be by changing screens and adjusting visibility etc. it is easier to park my full size RR than it is the x5 simply because both mirrors dip and that too offers surround view and top view and rear view camera. it's such a simple feature it should be an option to code or default. it was my main gripe with the Q7 as well. their surround view camera system was awful. it only offered 45 degree view, or an illustration of your vehicle or reverse camera. i can't think of any point in my life where i need 45 degree curb view to see what is there.
04-19-2016, 08:31 AM | #15 |
Rep 5,066
I can understand your frustration, but everyday I park rear end first and I have four concrete columns I have to navigate through... I just use the topview camera by a simple push of the iDrive knob after putting the transmission in reverse.
With that said, I think BMW should have put in the settings to set which view to be default.
04-19-2016, 10:10 AM | #16 | |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
....Life is too short to drive boring cars
04-19-2016, 11:08 AM | #17 |
Rep 774
In my opinnion it works like described here. Then you might have to press the memory button on the seat for it to stick.
04-19-2016, 11:12 AM | #18 |
524
Rep 2,146
Sorry, I just tried on my F15 and when it is tilted it does not adjust the position, the control button does nothing..........
04-19-2016, 11:37 AM | #19 | |
Rep 38
Now, if you want to do it the manual way, the only way to accomplish this is to adjust the mirror tilt manually, turn off the auto-tilt feature, and back up. Then to restore it to your preferred settings (assuming your setting is saved in the seat memory) just hit the button for your saved seat setting or manually readjust the mirror via control buttons. Essentially the OP requested a method to have the auto-tilt in reverse angle default reset to something more usable so that he doesn't have to do it manually as described above with auto-tilt turned off every time he's in reverse or use up 1 of 2 of his seat memories just for reverse. At which point, coding seems to be the only way to resolve his issue. It would be nice if BMW did have the angle setting as a selectable option within the iDrive menu though, as well as the option for which mirror or both to tilt while in reverse. Wishful thinking... Last edited by kryptik.m5; 04-19-2016 at 12:05 PM.. |
04-19-2016, 11:44 AM | #20 |
7266
Rep 6,561
i have the automatic parking option and the default view is set to that even if you set it to top view. once you cycle the ignition it goes back to the the park-assist feature and view not top view. it is unfortunate but at this point it's not really an issue i concern myself with... it really is a "1st world" problem and more of an annoyance than anything else. i can live with it but would prefer to not to.
