09-26-2017, 07:49 AM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
456
Rep 2,000
Drives: 2011 E92 M3 DCT/ESS 625 kit
Dash cam power connection ?
Does the passenger side fuse panel have constant 12v and accessory power. Searching and it seems like the fuse panel only has constant 12v fuses. Not sure if I want to keep my camera on all the time. Not sure if this will drain ur battery.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
09-26-2017, 08:23 AM | #2 |
Rep 2,384
Check out blackboxmycar.com
That is where i purchased all my accessories to have my dashcam run based on power levels. I use their magicsafe unit with my Blackvue DR650S hardwired through the car into fuse box using their add-a-fuse, and it shuts off when the battery reaches a certain voltage level to protect the battery as well as allow the dashcam to keep recording and capture footage when I exit the car for several hours. They have a live chat at blackboxmycar and are extremely helpful, even for non-customers. |
Installsplus455.50 |
09-26-2017, 12:50 PM | #3 |
Rep 536
power tap into rear view mirror. search the threads for power tap for radar detectors - i followed a link on this forum to do it.
09-26-2017, 02:01 PM | #4 |
456
Rep 2,000
So I take it the fuse panel at the passenger side door well only has constant power. Anyone know if there is an acc fuse?
09-26-2017, 06:02 PM | #5 |
Rep 2,384
If you don't want the dashcam to run AT ALL while the car is off, you can tap into the sunroof also. I did make a thread for this regarding radars, as my radar is hardwired into my sunroof. Power cuts off to that as soon as ignition is switched off.
However, I do really recommend checking out blackboxmycar and speaking with them as they can have you set up to have it operating while the car is off for a few hours on the battery until it reaches a safe level to cut itself off of power. |
09-26-2017, 06:44 PM | #6 | |
456
Rep 2,000
09-26-2017, 07:28 PM | #7 |
Rep 2,384
09-26-2017, 07:33 PM | #8 | |
456
Rep 2,000
10-09-2017, 08:51 AM | #9 |
53
Rep 301
I tapped into the cigarette lighter socket power feed. There is a wire easily accessible once you remove the passenger side center console front lower trim piece which is easy to do. Then just run your wire forward and up under the passenger footwell area and up the A pillar to your camera. Works great and since cigarette lighter stays on for about 10 minutes after car is shut off, it records me walking away and what happens around the car for the next few minutes too.
2002 E46 M3 Convertible (MT) >> 2008 E92 M3 Coupe (DCT) >> 2020 F87 M2 Competition (MT)
10-09-2017, 08:58 AM | #10 | |
456
Rep 2,000
05-18-2018, 07:56 PM | #11 | |
Rep 40
05-19-2018, 02:05 AM | #12 | |
Rep 142
See: https://www.newtis.info/tisv2/a/en/f...ocket/L19xVL4z |
05-19-2018, 03:32 AM | #13 |
Rep 166
To go back to OP's original question, I power my dash cam from OBD2 fuse for permanent 12v and PDC sensor fuse for switched 12v. Camera records constant when driving, then either in response to a knock, or one frame per second (you choose) when the car is parked. Set a value for minimum battery voltage and the camera will shut down to save battery if need be. Note I'm RHD, so not sure if fuse boxes are in the same locations
05-21-2018, 07:50 PM | #14 |
Rep 40
This is my first car with keyless entry. I just figured out that once I open the door and sit inside, all accessories are powered up, including cigarette lighter. Unlike older car, I need to insert the key and turn to 'ACC'.
05-22-2018, 10:52 AM | #15 |
Rep 256
I have mine hooked up for ACC power only since the cam has a battery in it. I used an add a fuse with I believe fuse 36. Fuses 36 & 37 are charging ports (Cig lighter, USB,...). Fuse 38 is sunroof. Check this DIY out: http://f15.bimmerpost.com/forums/sho....php?t=1132110
2014 X5 50i
07-14-2018, 07:34 AM | #16 |
Rep 60
My previous car I used a rubber spatula to snake the long dash cam cord from the mirror to the A pillar, behind the glove box and into the cigarette lighter socket in the forward lower console. Will that work on the x5? I don’t want to screw with wiring or fuses and I don’t use the lighter socket for anything else.
I have the smokers package. What is that? Ashtray and cig lighter ? |
03-14-2020, 06:16 PM | #17 | |
Rep 3
03-14-2020, 06:44 PM | #18 |
1635
Rep 2,995
