05-22-2018, 11:58 AM | #23 | |
Rep 467
05-22-2018, 07:57 PM | #25 |
BMW Aficionado
1344
Rep 1,817
For the adults in the room:
CID_Touch --> aktiv CID_APIX_MODE --> apix2 CID_COLOR_DEPTH --> 24 CID_COM_MODE --> mii CID_DISPLAY_RES --> 1440_540 CID_DISPLAY_SIZE --> 10_25 |
daytonaviolet1248.50 |
05-22-2018, 10:38 PM | #26 |
Rep 467
02-22-2019, 10:27 PM | #27 |
1635
Rep 2,995
This just happened to me tonight. I was sitting in car for a while, engine off, stereo on. Started the car to leave then shortly after i got the no signal. A minute later idrive rebooted. Weird.
02-23-2019, 01:53 AM | #29 |
1148
Rep 2,426
This happened to my iDrive a couple times. Last time while under warranty the dealer saw it so I got a replacement head unit. Never happened again.
I also had the older iDrive with USB problems that got resolved with a replacement unit.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
HJ478.00 |
02-23-2019, 01:19 PM | #30 | |
Rep 271
Yes, this is the only solution to the idrive crash problem, see my post above. Don't let dealer feed you other BS, insist they replace the idrive if you are still under warranty, it's a known issue. Otherwise, it will happen more frequently. |
HJ478.00 |
02-23-2019, 01:22 PM | #31 |
Rep 2,388
You might be right, but my experience is different. I got that error couple times a year ago, but since then nothing - it's working perfectly. And I know for sure it was a low voltage issue as I had different battery at that time. Of course my single experience is not statistics.
HJ478.00 |
02-23-2019, 01:48 PM | #32 | |
1635
Rep 2,995
Reading on other bmw forums with same no signal issue, they say bmw does a istep update to fix the issue. What is that? |
HJ478.00 |
02-23-2019, 02:19 PM | #33 |
Rep 271
That makes sense because the HUD gets the data from idrive.
My issue was not the battery since mine was new and X5 was also hooked up to dealer power supply when they were trouble shooting. It has been a year since they replaced the idrive, works flawlessly now. |
