02-15-2018, 04:41 AM | #24 |
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
HP
02-15-2018, 12:05 PM | #25 |
Rep 1,180
Max HP: 77
Max TQ: 81 Peak HP: 360 Peak TQ: 392 Those are the numbers from Dinan measured on 93 octane. I am usually on 91 or 92 so prob a bit less than the above. More specs here: https://www.dinancars.com/product/d4...eries=&mid=X5/ I'm very happy with it so far. It's very smooth and not peaky. There are charts on the site showing the HP and TQ curves. I plan to do some dyno runs in the spring with the tune on and off (you can turn it on/off with the Dinan app). I got it when it was on sale and was also able to negotiate a bit more on the price and install with my dealer.
2018 X5 35i M-Sport
07-12-2018, 10:33 PM | #26 |
Rep 271
I got these from ebay, plug and play, working great, very bright, no error, no hyper flash:
https://www.ebay.com/itm/CAN-bus-Amb...53.m2749.l2649 Actually, just noticed that these do hyper flash when starting the car. Search continues... Last edited by jch1511; 07-15-2018 at 01:52 AM.. |
07-29-2018, 07:36 PM | #27 | |
Rep 32
Hi! Do you mind to resend the link for the bulbs you purchased please? I would like to buy them. Thank you. |
07-30-2018, 07:04 AM | #28 |
Rep 3,523
Hi!
Do you mind to resend the link for the bulbs you purchased please? I would like to buy them. Thank you.[/QUOTE] Looks like my choice that I picked on Amazon last Jan. is no longer availble. But these look to be identical. Mine are still working and look great, and still NO error. https://www.amazon.com/GFJMC-Pieces-Error-Signal-Lights/dp/B01HCYX1Y8/ref=sr_1_1?ie=UTF8&qid=1532950597&sr=8-1&keywords=py24w+led+amber |
pinoyx5er23.00 |
08-17-2018, 03:44 PM | #29 |
Rep 271
I confirmed that these will do hyper flash/strobing as well, they all do.
The only way to avoid issues when swapping to LED turn bulbs is to simply code them out. |
08-22-2018, 04:41 AM | #30 |
Rep 3,523
09-03-2018, 04:09 AM | #31 | |
Old Time Newbie
51
Rep 85
But these look to be identical. Mine are still working and look great, and still NO error. https://www.amazon.com/GFJMC-Pieces-Error-Signal-Lights/dp/B01HCYX1Y8/ref=sr_1_1?ie=UTF8&qid=1532950597&sr=8-1&keywords=py24w+led+amber[/QUOTE] Installed these LEDs on mine few days ago. 5mins max. Plug and play and NO hyperflash(had it coded with the other settings/mod prior) With the cost, I don't think u can go wrong. Thanks! |
01-04-2019, 04:35 PM | #33 |
Rep 1,247
I'd like to change mine out as well, but I am not sure what you guys mean by "coded out" - I know you mean fix it with coding, but every post I find about LED turns just says "coded out". I have Carly - can I do it with that or is this some special coding that needs to be done?
Or where can I read up on what that means? Sorry - been through 6-7 posts that say the same thing and this was the most recent!
01-04-2019, 09:43 PM | #34 | |
Rep 2,388
So if I'm not mistaken you can turn it off in Carly under lights module (don't remember the proper name of module), it has a long list of options and you need to scroll down until you come to corner lights (of whatever they are called in Carly) and turn off startup check option. |
unluky7524.50 |
01-04-2019, 10:03 PM | #35 | ||
Rep 1,247
Awesome, perfectly explained. Thank you very much!!!
DuSh2113.50 |
02-21-2021, 08:28 AM | #36 | |
Rep 2
I got some 55w LED H7's off amazon and fitting-wise, they were a simple plug-and-play swap, however the ECU complains of bulb failure. I couldn't find the code anywhere online so had a play and I've just managed to code this out with the following changes to BDC_Body: Code:
FL_R_KALTUEBERWACHUNG: nicht_activ FL_R_WARMUEBERWACHUNG: nicht_activ FL_R_KURZSCHLUSS: nicht_activ FL_R_IS_LED: activ FL_L_KALTUEBERWACHUNG: nicht_activ FL_L_WARMUEBERWACHUNG: nicht_activ FL_L_KURZSCHLUSS: nicht_activ FL_L_IS_LED: activ The error's immediately went once i applied the code, though i have only just done it so will report back in a few days if i see any issues |
