      06-30-2018, 10:59 AM   #1
jero1213
Drives: F15 MSport
E53 rims in F15
Hello F15ers,
I just was a quick question; I've done some research but cannot find the exact answer since I can't find the measurements for the e53..
but i was wondering if a rim from the E53 (sports package), 255/55/18 will fit an F15 x5. I can see that in the spec sheet that it is standard size for the f15, whereas for e53 it is for sports package.
thanks in advance
      06-30-2018, 11:23 AM   #2
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
There are sites where you can check wheel size fitments, namely willtheyfit and wheel-size.
As for looking into E53 for wheels on an F15, I am perplexed, to say the least.. As most of us wait for the G05's new styles for 22s!
      06-30-2018, 01:20 PM   #3
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Originally Posted by jljljl View Post
Hello F15ers,
thanks in advance
Yes they will fit. Same 5x120 bolt pattern, same width rim 8.5jx18 and almost same offset (difference is 2mm or 0.08inch). 255/55/18 is also an option for F15 as well. I'm guessing you are using it for winter only? Otherwise I don't see why you would ruin the f15 look with old small rims.
https://www.wheel-size.com/size/bmw/x5/
      06-30-2018, 01:52 PM   #4
yewlock
yewlock's Avatar
Drives: X5
Just make sure the centre bore is the same to avoid vibration.
DuSh2113.50
      06-30-2018, 03:42 PM   #5
ptm1nh
ptm1nh's Avatar
Vietnam
202
Drives: Blue Cars
E53 has 72.5mm center bore, so you'll need a hub adapter to convert it to 74.1.
http://www.bmwforums.info/bmw-wheels...olt-sizes.html
DuSh2113.50
      06-30-2018, 06:46 PM   #6
jero1213
Drives: F15 MSport
Hey thanks guys for the replies
to answer why use an e53 wheels, yes, it's mainly for the winter rims.
I plan on purchasing an f15 with M sport package, but i dont think winters come with it ..
I knew the bolt size were the same, i knew that the f15 did take a 255/55/18, but i wasn't sure about the center bore, for some reason i couldn't find info on the e53 bore..
thanks guys
      06-30-2018, 06:46 PM   #7
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Good catch! I looked up everything except hub bore.
ptm1nh202.00
      07-01-2018, 12:14 AM   #8
ptm1nh
ptm1nh's Avatar
Vietnam
202
Drives: Blue Cars
I learnt my lesson the hard way
http://f15.bimmerpost.com/forums/sho...php?p=23400038
