07-02-2018, 09:10 PM | #1 |
Rep 22
Wheel Fitment Question
Guys, I am looking to replace the standard wheels (18inch) on my Wifes 2015 X5.
I have found a set of 19 inch 467M wheels with 255/55/19 tires on them. (square set up) I want to make sure they will fit. I was struggling to find the factory offset of both the new 467M wheels and the standard 18 inch wheels on the vehicle to compare. My wife's x5 is NOT an M-sport and for that reason does not have fender flares. My fear is that the 19inch 467M wheels are going to stick out or not fit. ANY help is appreciated. I have done several searches and have not found any conclusive answers. Thanks
Ask me about Brakes
07-02-2018, 10:01 PM | #2 | |
Rep 2,388
They will fit and won't stick out. I have 20 inch 315mm rear tires and they were not sticking out. Had to add 20mm spacers to get a bit aggressive stance. |
07-03-2018, 05:56 AM | #3 | |
Rep 22
What I am looking for is a wheel that will fit like the original X5 18inch. I dont want it too look aggressive. I just hate the 18inch thats on there.
Ask me about Brakes
07-03-2018, 06:28 AM | #4 |
Rep 22
The 467m wheels are 19x9 with 37m offset
Where the 18's on the car are 18x8.5 with a 46 offset i believe. Not sure if this helps anyone in getting me an answer
Ask me about Brakes
07-03-2018, 07:11 AM | #5 | |
Rep 2,388
Will that 15mm difference make it stick out? Not at all. To prove it here's pics of 467m on X5 without fender flairs - like you want. The only pics I've found googling - but you can see that it's far from sticking out (it's not even flush if you ask me). Now the only thing is that - you said you want 467m to sit inside exactly like your 18 inch set - that's not going to happen. 15mm difference is there either you want it or not. It's just physics. You can't expect a wider rim with lower offset to be exactly like your narrower rim with higher offset. P.S. Also 255/55/19 tires are not oem specs (255/50/19). You can still use that tire size if you want, I'm just saying. |
Imakebrakes127.00 |
07-03-2018, 02:49 PM | #6 | ||||
Rep 22
Awesome. Thanks I appreciate the help.
Ask me about Brakes
