      04-04-2018, 05:49 PM   #1
fromkrypton
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
H&R parts number
Help needed.
Could someone please tell me the exact H&R part numbers for 5mm spacers and the proper extended bolts that would fit on a 2015 X5 35d.
I usually get all my stuff from shipped to my address in the USA but unfortunate circumstances are preventing me from crossing the border for the next little while.
I would like to try to get them locally.
Thanks
      04-04-2018, 05:54 PM   #2
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
      04-04-2018, 06:13 PM   #3
fromkrypton
Drives: 2015 X5 35d
Originally Posted by menelaos View Post
1075740-51201412
Thanks!
From a Canadian distributor I found 1075740 5mm spacers.
But nothing comes up for 51201412
      04-04-2018, 06:30 PM   #4
menelaos
menelaos's Avatar
1226
Originally Posted by fromkrypton View Post
Thanks!
Sorry, it's 512014125
I have the feeling the number after the dash represents the size of the lug nut.
      04-04-2018, 06:40 PM   #5
fromkrypton
Drives: 2015 X5 35d
Thanks!
Appreciate the help but 512014125 still comes up with nothing. Could you send me a link to it? Even when I google H&R 512014125 nothing comes up.
      04-04-2018, 06:43 PM   #6
menelaos
menelaos's Avatar
1226
https://www.ebay.com/itm/192209766828
      04-04-2018, 06:52 PM   #7
fromkrypton
Drives: 2015 X5 35d
Ok ya I'm tired. The part number for the spacers works great.
What's the part number for the extended bolts?
      04-04-2018, 06:55 PM   #8
I believe you can't pull up the lug bolts part number online. They only have it listed in their catalog.
PM for Everyday DEALS!!
      04-05-2018, 12:37 AM   #9
mkdan2004
Drives: BMW X5 F15
Are extended lugs needed for 5 mm spacers? I went with 4mm Eibach spacers for the front and they did not come with extended bolts. I used the original one and seems to be ok. Should i be worried?
      04-05-2018, 08:55 AM   #10
fromkrypton
Drives: 2015 X5 35d
I gave up and ordered from Ben lol
r33_RGSport12971.00
      04-05-2018, 12:21 PM   #11
Yes, you need to be worried.
Proper threading needs 4-5 full turns.
With 3mm on my G30, I only have 4.5 turns.
In your case, I would say that you only have 2.5 to 3 turns, which is very dangerous. Especially on the SUV weight.
      04-06-2018, 04:54 AM   #12
mkdan2004
Drives: BMW X5 F15
Thanks for the reply. I just measured the threading on the original bolts. It is 25 mm and the overall length of the bolts is 50 mm. I have a set of bolts with 30 mm threading and overall length 50 mm from my previous car. Do you think i could use these instead? Would that be the proper way to secure the front wheels? If not, could you help me with the exact specifications for the proper bolts that should go with 4mm spacers?
      04-06-2018, 08:06 AM   #13
Hmm, how can be the old bolt is 30mm thread with 50mm overall length still.
Post a picture of them side by side.
Also, make sure it is the same bolt diameter and thread pitch.
What I use for 5mm spcer is 35mm thread since stock is 27mm thread.
      04-06-2018, 02:35 PM   #14
theove
Drives: X5 4.0E
I have ordered the black spacers.
EAN code: 4048419131720 (3075740B)
EAN code: 4048419132161 (1075740B)
r33_RGSport12971.00
      04-07-2018, 08:55 AM   #15
mkdan2004
Drives: BMW X5 F15
I tried to use the bolts from my previous car but they do not fit. The diameter seems to be just a bit larger (could not tell by placing them side by side). I did took a picture before my attempt.
On a side note, i took the front wheel down and then secured in place all over, this time, counting the turns. I got 6 complete turns + the extra tightening at the end using the original bolts. My question is: how do you count the turns? I started counting since the moment the bolt was secured in place (could not just pull it out, had to unscrew it). Is this what you mean by turns?
I am going to buy longer bolts anyway. Here is the picture of the bolts i tried to use. Left is the original, regular bolt, right is the original "anti theft" bolt, middle is my Mercedes bolts which sadly do not fit.
      04-07-2018, 09:03 AM   #16
See that mercedes bolt, it looks like it have the same diameter, but the thread tightness is different. That's called thread pitch.
Also the cone shape by the base if the top hex part, you have to pay attention on it to.
Porsche, BMW, Volvo, and some others, are using different design.
If you are not using the correct one, the wheels most likely are not secured properly.
To count the turn, you mark 1 point of the hex, turn it clockwise to tighten until you see the mark again. That's 1 full turn, you may miss by 1/2 turn during initial bite, which is fine.
menelaos1226.00
      04-07-2018, 09:05 AM   #17
Oh, and Benz usually using galvanized or chrome finished bolts, while BMW uses black bolts.
      04-07-2018, 06:56 PM   #18
theove
Drives: X5 4.0E
Standard size is M14 x 1,25 x 27mm
Cone is 60 degrees
Important is the 1,25. This is the thread pitch. Most use 1,50 and that will damage the thread on your bolt and your hub on the car.
      04-14-2018, 11:47 AM   #19
theove
Drives: X5 4.0E
I love the black ones. Have black wheels.
r33_RGSport12971.00
      04-16-2018, 12:09 PM   #20
It does looks nice.
I would stock them but last time I order couple sets, took them months to fulfill the order.
Besides, if you are still running stock rotor, silver would also match well since the rotor hat is silver.
      01-18-2020, 04:34 PM   #21
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
Hey, could you share the part number of these and where you got them? Also, are they 5 and 15?
      01-18-2020, 05:08 PM   #22
It does looks nice.
They should offer a ‘rust’ color to match OEM rotors.
r33_RGSport12971.00
1norseman398.00
