      06-14-2022, 06:30 PM   #1
bmwpower603
Drives: E36 m3 coupe 08 e90 M3
N63 mixture control
I recently purchased a 2014 x5 50i m sport.
And I am trying to track down the issue. I’m getting the mixture control deviation to rich. I did notice today that when sitting stationary I can kind of smell fumes. (As I did with my s63 x5 m) Sometimes if I sit and let it idle a while, a Puff of smoke comes out after taking off.
I did some investigating. And saw that the intake pipes were cracked. So I replaced those. And still have the code.
Could this be related to the airbag light and electrical?
Could this be the oil return lines under the turbos clogged up?
      06-14-2022, 06:54 PM   #2
bmwpower603
      06-20-2022, 03:56 PM   #3
bmwpower603
Solved
Replaced both HPFP.
      06-21-2022, 02:11 AM   #4
Chilled
Chilled's Avatar
Australia
365
Drives: F85 X5M
How did you end up landing on the HPFPs? What else did you try?
      07-01-2022, 10:54 PM   #5
bmwpower603
I popped the drain plug. And it (the oil) smelled like gas.
And my friend who is a master tech at BMW said it’s common. And since it is “mixture control” that is coming up for a code. Which relates to the HPFPs themselves.
The mixture control can also be related to injectors. And Low pressure fuel pump.
I counted both of those out of carrying out the bmw diagnostic step by step test plan for each fault entered.
