11-03-2017, 11:25 AM | #1 |
Rep 1,702
Updated: Fire hazard: BMW recalls 1.4M vehicles due to risk of under-hood fires
Featured on BIMMERPOST.com One of my friends has an N54 335i. He called BMWNA and told them that he's worried that the car would catch fire in the garage and set the house on fire. They were totally understanding and told him that there isn't a remedy for the problem yet (not really one in sight either). However, they also told him to drop his vehicle off at the nearest dealer, they would contact the dealer and set everything up. The dealer would either put him in a loaner or a rental. So he did. He's in a rental now and up until they fix the issue. He's assuming that cars that are replaced with rentals will get fixed first since it's costing BMW extra money. Makes sense to me. Just wanted to give the guys with the affected vehicles a heads up. Fire hazard: BMW recalls 1.4M vehicles due to risk of under-hood fires DETROIT — BMW is recalling more than 1.4 million cars and SUVs in two U.S. recalls due to the risk of fires under the hood. A spokesman for the German automaker says the risk of fire is very low in both cases, but the vehicles should say outside "in an abundance of caution." In both recalls, repairs are expected to start on Dec. 18. The largest of the recalls covers over 740,000 328i, 328xi, 328i xDrive, 525i, 525xi, 528i, 528xi, 530i, 530xi, X3 3.0si, X3 xDrive30i, X5 xDrive30i, Z4 3.0i, Z4 3.0si and Z4 sDrive30i vehicles from 2007-2011. Also included is the 2008-2011 128i. All have 6-Cylinder engines. Documents posted Friday by the U.S. National Highway Traffic Safety Administration show that a heater for the positive crankcase ventilation valve can overheat and cause the valve to melt, increasing the risk of a fire even when the vehicle is not in use. No injuries have been reported. Dealers will replace the heater. The heater is designed to prevent the valve from freezing in cold temperatures, BMW spokesman Hector Arellano-Belloc said. But irregularities in manufacturing can cause corrosion can lead to overheating. The other recall covers nearly 673,000 cars including the 323i, 325i, 325xi, 328i, 328xi, 330i, 330xi, 335i, 335xi and M3 from the 2006-2011 model years. Also covered are the 2007-2011 328i xDrive, 335i xDrive and 335is, and the 2009-2011 335d. Wiring for the heating and air conditioning system can overheat and cause connectors to melt, also increasing the fire risk, even when vehicles are unattended. Four drivers reported injuries. BMW says a wiring connection can corrode and in rare cases cause fires. Dealers will replace the wiring and connectors. The recalls total about 1.4 million vehicles, but some are included in both, BMW said. https://www.usatoday.com/story/money...res/828690001/ NHTSA document/report for affected 3-series vehicles in HVAC wiring recall (includes production date ranges: https://static.nhtsa.gov/odi/rcl/201...7V676-9625.PDF Other document/report for affected vehicles in PCV heater recall: https://static.nhtsa.gov/odi/rcl/201...7V683-7475.pdf Last edited by mirob; 01-18-2018 at 12:18 PM.. |
11-03-2017, 02:55 PM | #2 |
224
Rep 382
BMW recalling a million vehicles
11-03-2017, 03:04 PM | #3 |
Moderator
7515
Rep 19,368
Interesting that USA Today misrepresented the fact that, since there is overlap between the two recalls, only a million distinct vehicles are actually affected. Of course, there is nevertheless 1.4 million issues to address with said vehicles, so sure, that's important to report too.
11-03-2017, 10:43 PM | #4 | |
Retired BMW Genius
2898
Rep 3,404
11-04-2017, 07:19 AM | #5 |
Rep 4,821
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
11-06-2017, 06:35 AM | #6 |
Rep 816
So basically if you're driving a 7-12 year old car it may start having electrical problems.
Is this really breaking news? Glad they're having a recall, but I wouldn't bad mouth BMW for this one.
MilehighM3915.00 dancing__narwhal141.50 |
11-06-2017, 07:21 AM | #9 |
Rep 4,128
Drives: M235i & G30 540i
Wow that headline sounds so bad. 1.4 million vehicles recalled due to risk of under hood fire.
Then you read the story and these vehicles are 7 - 10 years old and only now showing a problem? This is probably more of a precautionary measure by BMW than an issue.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
11-06-2017, 07:40 AM | #10 |
7908
Rep 11,785
1M Tex240.00 balloonsalesman47.50 |
11-06-2017, 08:11 AM | #11 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
NHTSA document/report for affected 3-series vehicles in HVAC wiring recall (includes production date ranges): https://static.nhtsa.gov/odi/rcl/201...7V676-9625.PDF
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
11-06-2017, 08:33 AM | #12 |
Rep 435
Why not Europe too ? Do you really think they use different wiring in Europe ? No, its just that the EU does not have the necessary power to force BMW to do this recall.
RENT-A-GOAT462.50 ///M Power-Belgium63404.50 |
11-06-2017, 08:56 AM | #14 | |
Rep 6,759
That’s exactly a scenario that could happen, and BMW wants none of that on their hands. These aren’t electrical gremlins, as in your AC only works if you jiggle the knob, this is serious and potentially life threatening. It’s very good that BMW decided to own this issue and get it done right.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
8
bradleyland1503.50 SportySpice204.00 M3 Adjuster7907.50 Rupes1055.50 Sefano3252.00 TBN54426.50 Soles330i14.50 lab_rat394.50 |
11-06-2017, 09:08 AM | #15 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
I wouldn't give them a pass either. And no, it's not normal for cars to have electrical issues after 7yrs that result in fire. lol
4
11-06-2017, 09:24 AM | #16 |
Rep 176
Guys,
I am not a 100% sure but earlier this year i had to change the evaporator on my 2008 328i coupe. While they were doing this change they noticed that «*something a part*» had completely melted and i had to change this piece. It was an extra 500$. All this was done at the dealer. If it turns out related to this recall, would bmw reimburse me? Im in Canada. I can eventually look in my receipt and give you guys more details on prt numbers and all if it helps. Thanks |
11-06-2017, 09:28 AM | #17 | ||
Rep 4,128
11-06-2017, 09:47 AM | #20 |
Rep 562
Drives: 2011 1M VO
Seems Mike (Roundel tech writer) is right again when he complains about the harness being reduced to practically copper vapor to save money and a little weight.
11-06-2017, 10:36 AM | #21 |
766
Rep 554
Drives: 2020 F82 M4 6MT
Looks like my E92 335i is affected. Fine with me as long as it gets repaired in a timely manner this time!
When should we expect parts to arrive to fix our cars? |
11-06-2017, 10:42 AM | #22 |
Rep 3,456
Drives: Harrop E90 M3
The gauge of the wire is not the cause of the issue, is the connection is slightly loose and causes heat buildup. Water ingress into the blower motor from improper repairs, namely the windshield replacement, makes the situation worse.
