01-14-2020, 09:26 AM | #1 |
Rep 31
X5 F15 check head Unit ( NBT )
Hi
With ISTA or Esys, is it possible to check the Head Unit ( NBT) ? or with another software? Last edited by Marc412; 01-14-2020 at 10:17 AM.. |
01-14-2020, 10:17 AM | #3 |
Rep 31
I have a poor radio reception , radio is playing vey poorly.
I have already check the Amp and the antenna with ISTA , it says they are OK. So i guess , it could be dommage in the Head Unit. This is what i would like to diagnosis the radio head unit. Other ideas to fix this problem are welcome Last edited by Marc412; 01-15-2020 at 02:33 AM.. |
01-15-2020, 02:39 AM | #5 |
Rep 31
the antennas have also been checked with ISTA. The test result is O.K for antenna and amplifier
What is strange is that I receive different radios correctly, and at times there is a reception cutoff with a small boom, boom noise, boom, with no reception radio, like if there is no antenna connected. And reception will restart after a few minutes. |
01-15-2020, 02:50 AM | #6 |
Rep 31
01-15-2020, 03:30 AM | #7 |
Rep 1,260
Try asking on this forum: https://cartechnology.co.uk/forumdisplay.php?fid=61
01-16-2020, 12:15 PM | #8 |
Rep 31
It seems that if i disconnect the purple connector going to the head unit the reception is better. This looks stange?
According to the document , it is ANT FM2 and also: Signal line for the Diagnosis, AM/FM/HF signal, HF signal for Diversity function The resistance of the rear window antenna is about 7 ohms. Is it good? Ista diagnosis gives no defect. Is it a problem with the head unit? |
01-16-2020, 02:37 PM | #9 |
Rep 7,477
This isn't an answer but just an anecdote...my 99 e39 540iT had horrible static when listening to AM radio stations. One day I was loading CDs into the CD player that was located in the left rear cargo area and somehow/someway the wiring that ran in that area (above and behind the insulation) was slightly moved.
The radio happened to be on in all its static glory...and in that brief instant...the static went away. Hmmm, I thought...so I reached up to intentionally move the insulation and wiring and it went away again. So I peeled back the insulation to see a large bundle of wires and again, when pushed up higher (away from the CD changer, amp and other electrical components...the static ceased. So I took some electrical tape to secure the wiring higher up...and from that day forward...my 540iT never had a static issue with AM stations (nor any other stations). All that to say...what happens if you wiggle that wire or connector? Could it be getting interference from some other component nearby? In the diagrams below...you can see that the antenna is built into the rear left cargo window of the Tourings and SAVs of that time...plus there was an amp/receiver and all the electrical audio/telephony components in that corner...and somehow the wiring had dropped low enough to pick up interference.
