      01-17-2020, 07:52 PM   #1
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Diesel exhaust smell
The is a 2014 x5 35d new to me with 38,000 have owned many diesels over the years. I’m just curious if any other owners have noticed a diesel exhaust smell in front of car or while in traffic ?
      01-18-2020, 02:43 AM   #2
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Check the whole exhaust piping, also make sure the cat is still in place.
      01-18-2020, 12:31 PM   #3
Clifton
Clifton's Avatar
Drives: Cars with tires
Take it to the dealer and have them check the valve cover breather hose.
The cabin air intake is up under the hood and it is likely that it is pulling in fumes from a cracked, loose or disconnected breather hose.
See the following thread for similar issue with fix: Click Me
Regards,
Clifton
      01-19-2020, 12:21 AM   #4
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Dealer has said no problem all hoses look good
      01-19-2020, 05:03 AM   #5
Cranswick852
Drives: F15 X5M 40d
UK 2014 40d with 70k Miles that I've owned since 2016. Never had any hint of diesel or any exhaust smells under any conditions. I fear there's something amiss with yours that needs checking out
      01-19-2020, 08:03 AM   #6
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
The only time ever i had this was a few days before the egr cooler cracked. Have you had yours replaced under recall?
      01-19-2020, 07:21 PM   #7
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Egr
Dealer states egr is fine . I’m just wounding if it is cracked.
      01-20-2020, 04:24 AM   #8
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
Was yours replaced under recall? Dealer should be able to tell.
i had no symptoms bar poor mpg and a diesely exhaust exhaust smell in the cabin coming from air con area.
One day i switched to sport mode with gear lever into sports shifter and gave it a rip soon the drivetrain warning came on and car stalled due to cracked egr.
Im not saying you should do the same.
      01-20-2020, 08:58 AM   #9
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Egr valve
Dealer say does not need done .
      01-20-2020, 09:22 AM   #10
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
https://www.consumerreports.org/car-...for-fire-risk/
r u sure?
      01-20-2020, 11:07 PM   #11
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Dealer
[QUOTE=KRS_SN;25706615]https://www.consumerreports.org/car-...for-fire-risk/
r u sure?[/QUOTE
I did take it back to dealer and they said could smell diesel exhaust in engine area .Should not be smelling fumes the shop Forman said . I am going to call bmw again ask them to replace cooler and egr module and intake manifold per bmw recall . Dealer said befor if not leaking they do not replace . I disagree with if there is a recall it should be done
KRS_SN13433.00
      01-21-2020, 02:55 AM   #12
Cranswick852
Drives: F15 X5M 40d
EGR replacement was not dependent on discovering a leak, but the recall did not replace all EGR coolers.
They did a visual inspection to determine if the cooler was one of the affected batch and if it was they replaced it irrespective of condition. If the cooler wasn't from the affected batch, then no replacement. The issue was that a certain batch, fitted to some vehicles over a certain period, were at risk of leaking, which then caused risk of fire.
Any dealer should be able to inspect the car and tell you if your vehicle is affected.
      01-21-2020, 04:39 AM   #13
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
2014 x5 diesel
Im pretty sure thats an affected batch.
Bulletproof and excellent car and engine but emissions regulations mean they had to hastily put in a crappy egr system.
They all have faulty egr coolers which are likely to break.(I think the coolers from 2016 are supposedly defect free)
so bmw inspects them and if they look ok they discharge their duty of care and say look we inspected them they look ok
But
they might break 2 months later and bmw say 'not our problem ' we discharged our duty of care.
You have some symptoms exhaust smell in cabin and in engine bay
It may or may not be a faulty egr cooler but if it is and bmw do nothing tell them you are worried car will stall in the highway or catch fire and both of these are hazards. Be polite and stress on the rosk to yourself and family.
They checked my egr cooler with an endoscope after waiting 2hrs for engine to cool down.
If your car is in an affected batch has it had this work done?
best wishes.
      01-21-2020, 04:41 AM   #14
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
forgot to add bmw may impound the car until egr cooler is available if it is not in stock and unless you have an extended warranty are not obliged to give you a courtesy car.
      01-21-2020, 09:08 AM   #15
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Cooler
Mine was inspected and was determined ok and no parts where installed
      01-21-2020, 11:56 AM   #16
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Hose bad
Looks like i have a hose with rot causing the problem going to crank case
655 parts labor
      01-21-2020, 12:52 PM   #17
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
655 parts labor
great to hear you got to the bottom of it and fix isn't that expensive.
      01-21-2020, 02:20 PM   #18
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Fix
Absolutely i had thought maybe this was the problem .. Now if they can fix rattle in roof and tail gate it will be perfect warranty is paying most of cost ..
KRS_SN13433.00
      01-21-2020, 02:38 PM   #19
Cranswick852
Drives: F15 X5M 40d
Pleased to hear your problem has been resolved.
For anyone visiting this post, EGR Coolers came from a number of suppliers. The recall inspection determines which cooler is fitted to your vehicle. If it's from a specific supplier(s), they replace it, regardless of condition. 60-70% of vehicles subject to the recall have the suspect cooler. Details from relatives who is BMW mechanic working in a dealership.
In UK at least, they'll provide you with a courtesy car during recall work even if your vehicle is out of warranty. My X5 was out of warranty when inspected, parts were on back order and they wouldn't release my car, but they did give me a new 6 Series with only 500 miles on the clock. Had the loaner for 3 weeks
      01-21-2020, 06:46 PM   #20
Clifton
Clifton's Avatar
655 parts labor
Glad they finally zeroed in on valve cover breather hose. The cracks they can develop are easily overlooked, but your symptoms should have clued in the techs. The breather hose is on the same side as the intake for the cabin.
      01-24-2020, 05:52 PM   #21
swainbmw
swainbmw's Avatar
520
Drives: 2022 x5 40!
Egr
After breather valve hose replaced ,and retested with smoke test another leak was found and it was the egr cooler this time . What the chances that the oil cooler needs replaced? Or the intake manifold needing cleaned ? Or replaced ?
      01-24-2020, 05:59 PM   #22
KRS_SN
KRS_SN's Avatar
United Kingdom
13433
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
refer to my previous posts mate. I shall say no more to avoid repetition as it gets boring. EGR cooler needs replaced end of.
