01-20-2020, 09:30 AM | #23 | |
Rep 1,449
Ceramic would have been so nice
No. Try not. Do. Or do not. There is no try.
-Yoda |
Bobby_Drake388.50 |
01-26-2020, 07:02 PM | #24 |
497
Rep 328
Just did this install over the weekend. Installation is a breeze. For the AC panel you don't have to pull the knobs as it's a direct replacement if you get a panel from the F series. Pull the dash trim and the panel is held by 2 torx bolts up top. You'll need to pry out the small plastic trim below it where the usb connection is to fully remove. Just a heads up so you don't make the same mistake as I did there's a number of iDrive controllers and the later models have silver trim between the buttons and the buttons are different. Sure you could probably fix this with coding but I preferred the silver trim on the controller as it matches the other interior pieces. See attached for reference and you can also see the older shifter.
0-60Motorsports792.00 |
01-26-2020, 08:00 PM | #25 |
Rep 449
Looks great! Lucky you got the ceramic unit from F series. I wasn't able to find one for decent price so I went with 7 series and had to cannibalize it to get to ceramic parts
01-27-2020, 12:50 AM | #26 |
Rep 3,151
That is a great touch. Looks beautiful.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
01-27-2020, 07:06 AM | #27 |
Rep 1,061
It's too bad that BMW does not sell a ceramic repair kit as they do for the silver knobs:
https://www.ecstuning.com/b-genuine-...t/61319393931/ This also gives some clues as to the parts needed to swap over if you don't want to disassemble the dash (though that is not hard). |
04-04-2020, 08:18 PM | #29 |
Rep 148
i have a 2014 550ix with ceramic im going to sell so im thinking to swap them before i sell it...it does look identical i hope it works
