10-23-2021, 05:06 PM | #199 | |
Rep 24,678
It's all legal for the FIA anyway ...
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick60090.50 |
10-23-2021, 05:08 PM | #200 | |
Rep 7,429
Remember different wing configurations will change the level of downforce generated and how much load the rear suspension will see. Generally when you see 300 kph speeds you aren't running the highest wing level because the drag is too high. Therefore a smaller wing means a smaller load and thus 300 kph will not generate enough load to bottom out the suspension, however on the straights where speeds are higher than in the corners you can generate even more down force to meet the loads required to squat the car. This can also be tuned by tuning the damper so when you run a smaller wing less force is needed to cause squatting. Also your logic would imply that flexi wings don't work unless they're GPS controlled because they'll flex in high speed corners - but they don't because they're precisely tuned for the speed and load they will encounter specifically on the straights. Smaller wings will need to be able to flex easier than larger wings because they don't generate the same amount of down force for instance. Another counter point is that it took the mercedes in the video alot more than 1m of running on the straights before it squatted, if it was gps controlled it should have squatted earlier to have even faster acceleration. But it didn't, so easily with critical thinking I am able to adequately debunk your myth of mercedes having gps controlled suspension. Again maybe you should indeed stick to fantasy because the egineering seems to complicated for you to handle. BTW: rake doesn't matter for the squatting suspension, its whole design is to eliminate rake angle on the straights to stall the diffuser and thus reduce drag, then on the slower speed cornering sections reimplement the rake angle to get more volume under the duffuser for more down force generation. This design allowed mercedes to jack up the rear of the w12 (and if you add high rake to a long wheel base car you get immense amounts of drag along but this clever suspension trick eliminates it) and allow it to still retain fast straight line speeds. Redbull could have this in their rb16b if they wanted to and it wouldn't upset the car because it wouldn't be used where downforce generation is required, however it isn't easy to do so it might take too much engineering investment on behalf of redbull to get this done this season.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-23-2021 at 11:06 PM.. Reason: clarification |
10-23-2021, 05:10 PM | #201 | |
Rep 7,429
Or maybe they're just learning to setup their car better - again the importance of understanding a car.
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
Killed by Death12473.00 |
10-23-2021, 05:10 PM | #202 |
Rep 19,556
MV
///M Power-Belgium63388.00 |
10-23-2021, 05:14 PM | #203 |
Rep 19,556
Yup I'll go with set up like you say and the saving antidote but most of all the best driver.
10-23-2021, 05:14 PM | #204 |
Rep 7,429
Loved that, but wished Perez got it instead.
Hope Perez gets it in Mexico though.
Blindside_1376709.50 |
10-23-2021, 05:16 PM | #205 |
Rep 184
I hate to be critical, but is it just me or did Danica Patrick look like she gained a lot of weight? No longer a hottie! Her outfit sucked too.
Her interview skills were lacking too… Back on topic, should be an entertaining race tomorrow!
Previous BMWs: '87 325is; '06 X3; '09 X3; '11 328i x-Drive; '12 R1200 RT; '13 128i; '13 X3 35i MSport
Other/Current: '19 Porsche 991.2 TT; '21 Jeep Wrangler JL80A; ‘23 Lambo Huracan EVO RWD |
10-23-2021, 05:19 PM | #206 | |
Rep 7,429
Max is Max, super consistent all year and hasn't made any mistakes. So give him a fast car and he'll be fastest, pretty simple logic. Finally RB have given Perez a car he can drive fast too and he's near in the top.
10-23-2021, 05:23 PM | #207 | |
Rep 19,556
10-23-2021, 05:24 PM | #208 |
The WEEBM3
469
Rep 782
Age does that to you, it sucks getting old!
BMW E90 Alpine White Slicktop Stripped 6M 03/2008
IG: @Richneerd |
10-23-2021, 05:25 PM | #209 |
Rep 7,429
Yeah I'm so glad they didn't sack perez for next year that would have been disappointing.
10-23-2021, 05:27 PM | #210 | |
Rep 3,530
Didn't notice weight gain, still cute & poster worthy Last edited by Killed by Death; 10-23-2021 at 05:34 PM.. |
10-23-2021, 06:05 PM | #211 | |
Rep 24,678
The 16B has a new floor . Checo ran it already in Turkey ... That's why he could get into a fight with HAM . Remember the pitlane incident where HAM pushed Checo into the pitlane ! Checo with the new floor, was the Red Bull's test mule in Turkey . Today MAX ran it too . That's why the 16B looked so planted today for both , and the full potential of the HONDA PU can be used . Checo got always the same machinery , but he struggled the whole season with the 16B's rear end . The new floor is a great job from Newey ! Today Checo looked more confident with the new floor than MAX is .. That's because Checo ran more km's and already 2 races with the new feeling and floor in the car . MAX's addaption with a new feeling in a car is lightning fast anyway .. Did you see the Wolf's face after the QF ? To me it looked like a thunderstorm ... And BTW : (finally) Congrats for Checo !
M5Rick60090.50 |
10-23-2021, 06:10 PM | #212 | |
Rep 19,556
10-23-2021, 06:14 PM | #213 |
Rep 19,556
The Newey floor is spectacular and thank the Lord he wasn't injured more seriously, at his age injuries can take longer to heal.
///M Power-Belgium63388.00 Killed by Death12473.00 |
10-23-2021, 06:16 PM | #214 | ||
Rep 4,445
Merc has pace
Merc has significant pace advantage on the straights and are hitting terminal velocity much quicker than the RBRs With a slipstream the Mercs could hit 350 kph during the race. Mercs struggle with cooling in the Texas Heat. Post qualifying, Hammy said it will be a good race into Turn 1. Foreshadowing for a collision? Toto keeps referring to DNFs this week and the last time he repeated the DNF mantra was Silverstone. I just put down flyer bet for a Bottas WDC.
///M Power-Belgium63388.00 M5Rick60090.50 |
10-23-2021, 06:30 PM | #216 | |
Rep 7,429
Also I wouldn't label it the "newey" floor. Sure he's the technical lead, but one man doesn't get the job done. There's a bunch of super talented engineers that our the grunt work in to turn a sketch into reality. They have to turn the sketch into a CFD model, fix any errors with the design so it works better in real life and with the other bits on the car. Then the wind tunel guys have to test it and further refine it. So it's more team work than one person at the top. It's also super demoralizing for the people who work on the car if you just give one person credit. It's a team game. So I'd call it the RBR floor, just like how no one calls it the Allison dampener or das etc.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-23-2021 at 06:38 PM.. |
10-23-2021, 07:14 PM | #217 | |
Rep 10,663
Drives: M4 CS. Former G82, x2 F82, F80
UNFORGIVEABLE doesn't she know better? The weight thing can be controlled though I'll give you that. |
10-23-2021, 07:30 PM | #218 |
Rep 4,445
She has an interesting monotone vocal delivery. No inflection whatsoever, for comedy put her in the booth with Crofty.
10-23-2021, 07:59 PM | #219 |
Rep 24,678
5
10-23-2021, 10:12 PM | #220 |
Rep 7,429
The real story is that ferrari is actually coming back and beating mclaren.
Blindside_1376709.50 Killed by Death12473.00 |
