      05-08-2019, 12:47 PM   #1
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
35Diesel - Service @130k+ miles
Hi there,
I'm at a little over 130k miles now and want to do some preventative maintenance... and wanted to see if there is anything I am missing that I should consider including... Your input is appreciated!
Transmission Oil Pan / Filter $76.72
https://www.rmeuropean.com/Products/...a-52fcd88a9a20
Transmission Fuild (7L) $22.02/each = $154.14
https://www.rmeuropean.com/Products/...7-dc39b465919a
Oxygen Sensor $87.75
https://www.rmeuropean.com/Products/...8-7e1325d617a5
Drive (Serpentine) Belt $32.92
https://www.rmeuropean.com/Products/...0-e5093f852a3d
Rear Differential Fulid 1.5L $20.95/each = $41.90
https://www.fcpeuro.com/products/75w...red-line-50104
Front Differential Fluid 1L $14.49
https://www.fcpeuro.com/products/gea...ly-99991754600
Transfer Case Fluid 1L $29.06
https://www.rmeuropean.com/Products/...4-0dbf7592eea3
P.S.
Engine Oil / Filter, Air and Cabinet Filters, Fuel Filter, Coolant and Brake Fluid was recently done.
      05-08-2019, 02:19 PM   #2
Marekbmw
Drives: 2015 X5 35d, 2015 740Li
Looks good, may want to add power steering fluid change as well to the list.
      05-08-2019, 02:22 PM   #3
MrTookies
MrTookies's Avatar
Aren't F15 electric power steering and don't need fluid?
      05-08-2019, 02:47 PM   #4
CanadianLurker
Drives: 2018 X5 xDrive35d
Depending on when it was last changed, you should also change out the brake fluid while you're at everything else you're already doing.
      05-08-2019, 02:49 PM   #5
MrTookies
MrTookies's Avatar
:-) Thanks - Just changed that
      05-08-2019, 03:57 PM   #6
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
carbon cleaning of intake manifold and intake valves
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      05-08-2019, 03:58 PM   #7
MrTookies
MrTookies's Avatar
Originally Posted by CHECKERED View Post
coolant?
What about it?
      05-08-2019, 05:30 PM   #8
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Looks like you have all maintance stuff covered, while your servicing your vehicle inspect the chassis, drive shafts and suspension components for wear. If you haven’t yet perhaps replacing the water pump and thermostat at 150k miles would be your next major service. Great job keeping up with maintance it’s no easy task.
MrTookies457.50
      05-08-2019, 05:33 PM   #9
MrTookies
MrTookies's Avatar
Would you say that is a preventative thing or just order the thermostat and water pump to have them ready when they fail?
      05-08-2019, 08:53 PM   #10
Marekbmw
Dealership keeps it stock. Check for leaks and leave it if none.
MrTookies457.50
      05-08-2019, 09:47 PM   #11
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
It’s preventative,150k miles is about most modern mechanical water pump and thermostat lifetime anyting beyond that is on borrowed time. It makes it hard to discern when it fails (unless it leaks) since we have an idiot light for overheating by then it’s a little too late when it comes on, you could access test/hidden menu every time you start your vehicle to monitor your water temperature but it gets annoying doing it after a while.
MrTookies457.50
      06-25-2019, 10:58 AM   #12
MrTookies
MrTookies's Avatar
@Mr.47 Just wanted to pick this back up, So we are only speaking about the primary water pump right?
      06-26-2019, 09:51 AM   #13
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Correct, the primary water pump, picture for references.
MrTookies457.50
