2010 2011 BMW 5 Series Forum F10 Manual Trans for 2012 550? |
11-08-2011, 02:15 PM | #1 |
Rep 173
I'm kicking around the idea of ordering a 550, and I would like a manual trans. BMW's site does not show the option, but I have found a low-mileage, used 2011 550 with a manual trans. Is it still available for the 2012 MY?
Thanks!
'11 550i with 6-Speed Manual
Lots of Old Cars That Nobody Cares About |
11-08-2011, 06:47 PM | #2 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
yes, the website is wrong. Trying to find one isn't easy though. You're better off ordering the one you want.
11-08-2011, 06:53 PM | #3 |
ALLDAY
55
Rep 220
The option doesnt show because manual transmission is STANDARD. If you want automatic you have to specify you want the automatic. If you go to the website and look under the specification it will say manual trans
2017 X5M
11-08-2011, 06:56 PM | #4 | |
ALLDAY
55
Rep 220
http://www.bmwusa.com/Standard/Conte...s/Default.aspx Performance and efficiency 4.4-liter, 32-valve 400-hp V-8 engine with TwinPower Turbo technology, piezo direct fuel injection, 4 overhead camshafts, and Double-VANOS steplessly variable valve timing Direct ignition system with knock control Electronically controlled engine cooling (map cooling) Brake Energy Regeneration system 6-speed manual transmission
2017 X5M
11-08-2011, 07:49 PM | #5 | |
Rep 1,346
11-08-2011, 09:49 PM | #6 |
Rep 173
That makes sense. Thanks for clarifying. I just assumed it would have both options listed to choose from. That's what I usually find on other sites. I have found a manual 2011 with 12,000 miles and most of the options I want in Dallas for mid-$50's. I'm waiting for an email back on it, and as much as I like having a vehicle exactly like I want it I like someone taking the initial depreciation hit even better. It has the stock, ugly sport (non-M) wheels on it, but I'll change those anyways and lower the car as well. As crazy as it sounds, I'm gonna get rid of my 2010 ZR1 for the 550. I have multiple toys, and I miss having a BMW since the M3 is long gone. The ZR1 is a blast, but I also miss the practicality of a car that I can enjoy on a regular basis. The Dinan stage 2 tune will bump the power to 500 HP and retain full warranty, and that's hard to beat! It's the classic apples and oranges comparison, but I've had four C6 Corvettes and I'm over them until the C7 is released.
Thanks again for the help.
11-14-2011, 10:14 PM | #7 |
ALLDAY
55
Rep 220
Yes I know that, for some reason it shows up auto, but the standard transmission is 6MT. the only way to get a view of the 6MT would be to go under the 535 configuration. But the 6MT is available for the 550. When you order through your dealer just make sure you point it out to him the you want the standard 6MT.
2017 X5M
11-15-2011, 01:03 AM | #8 |
Rep 1,346
Nope, the 535i configurator defaults to automatic as well, hence the confusion.
